Collabora Impress slideshow background in fullscreen
Hello! I have problem with presentations. I have a lot of file in format 4:3 and play them fullscreen of files in TV screens in format 16x9. Is it possible to change background of empty space form white to black?
In LibreOffice this empty space is black, but i preffer to use Colabora Office.
I am ok also if it’s possible autmatic strech of slides from 4:3 to 16:9
I use Linux mint.
hi @chebaev welcome to collabora online forum
Thanks for the report. First, could you say which Collabora Office you are using? Help > About and a note on how you installed it (deb package from the Collabora repositories, flatpak, snap) would tell us. There are two different desktop apps: the classic one, which paints the area around the slide black just like LibreOffice, and the new app, which uses a new slideshow implementation.
If you are on the new app, this is a known small gap: the presentation window currently leaves the unused screen area at the default white instead of painting it dark. That is easy to fix - if you can confirm it, please file an issue at Issues · CollaboraOnline/online · GitHub and mention this thread. If you are on the classic app, the bars should already be black, and we would need more detail about your version.
On stretching 4:3 to 16:9 automatically: the slideshow always preserves the slide’s aspect ratio, in LibreOffice too. You can convert a document via Slide > Slide Properties and set the size to Widescreen 16:9, but content is repositioned rather than scaled, so each converted file needs a quick look afterwards. For a large set of existing 4:3 files, dark bars are the practical answer.
Thank you for the quick response.
I use flatpack version: 26.04.3.3 (git hash: 7ddebab0ef ).
Itried also classic version, but in this version i have other broblem. In presentation mode (window), when i click “Slide” button to view all slides, the program show me all slides and jump to first slide. In flatpack version jump to current slide, that function is very important for me. Also in “Sledes” mouse scroll is not working in classic version, but in new version is working.
