Collabora Office for Android and iOS is moving to 26.04. Please help us test it
The mobile apps are moving from 25.04 to 26.04, and the past five weeks have been busy: 59 mobile changes merged in Gerrit, 38 Android and iOS issues closed on GitHub.
What’s new: sheet protection and the sheet tab menu in Calc, keyboard and cell cursor fixes, dark mode that follows the system theme, file creation and opening on Android, copy and paste on iOS.
All mobile work now lands first on distro/collabora/co-26.04-mobile, so fixes reach the test builds within days instead of waiting on a release.
Install a build and use it for real work:
  • Android: grab the newest dated folder from the snapshot builds and install the arm64-v8a APK (you’ll need to allow installs from unknown sources).
  • iOS: join the TestFlight beta.
These are test builds. Work on copies, not on the only version of a document you have.
When something breaks, open an issue with [mobile] in the title. Please include:
  • device model and Android/iOS version
  • the app build date (Settings → About)
  • steps to reproduce, what you expected, what happened
  • the document, if you can share it publicly, if you can’t, say so and we’ll arrange a private channel
Search open issues first so we don’t chase duplicates. Reports with clear steps get fixed fast.
