Date: 2026-09-23
Present:
- Regina, Adria, Stephan, Caolan, Szymon, Andras, Michael S, Miklos
Completed action items
Pending action items
check that no builds are incremental anymore (Adria)
still pending, first needs more capacity
also watch out for the hidden incremental Windows app problem, as discussed on Matrix
- I think I fixed that with /t:Rebuild (Caolán)
clang loplugin in code outside engine/, look at this (Adria)
- so build not only engine/ code in this config
Drop the old extensions framework (Andras)
- in progress, we just don’t read that layer anymore
Releases
CODE 26.04.4.2 “green” this week
CODE 26.05.5.1 in 2 weeks
Patch review (Miklos)
- Week 39: 209(-15)
- Week 39: 1(-1)
- Week 39: Arkadiusz Kozdra, Deleted User, Halis ŞİMŞEK, Hosted Weblate user 54392, Mike Schulte, Nobody 12345, QuietCedar47
- Week 39: Caolán McNamara (120), Miklos Vajna (106), Noel Grandin (79), Stephan Bergmann (42), Szymon Kłos (24), Michael Stahl (23), Tor Lillqvist (18), Samuel Mehrbrodt (17), Tomaž Vajngerl (14), Mike Kaganski (12)
Bug reporting
- Week 39: 6(+0)
Jenkins / CI update (Adria)
- not worse than it worse
Week 39: Success rate is 36%, failed builds are 32/50
Week 39: Turnaround time is 2 hr 58 min (median of last 48 SUCCESS/FAILURE builds)
Crash testing (Caolan)
2026-09-20: 9 (-2, +0)
- and some more fixes in the next run
2026-09-16: 11 (-11, +0)
- further improvement, fix for some more available.
TTT talks
Have talks for the next two weeks
- need to check with Tomaz if he can do next Fri
JUnit tests status (Stephan)
Complex tests are broken, but Noel will bring it back
The unoapi tests will be removed
What’s cooking
Regina
- Review of SmartArt related patched from Armin (13211) and Samuel (12808).
Szymon
had an undo fix for Impress image crop, was not grouped
worked on the Impress slide linking API
Stephan
- more boring GAS scripting interop work
Caolan
various efforts at a reduced submit-to-verdict for changesets
- trying to count from “submit to gerrit” to “a result is reported”
landlock by default for the dev “make run”
- if Ubuntu needed tweaks for the user-namespace case, that is no longer needed
some more steps to reduce double-compiling for the coda+server build
Andras
Lightproof C++ port has been merged
Various smaller fixes
Adrià
CI capacity adjusting and monitoring (goal -> CI turnaround < 1h)
windows11 incus VM, 2 extra instances already in place
new capacity added for linux builds (alma and oracle linux new containers)
clang dbgutil higher exec priority to fail related builds if fails
ccache pre-warming
new grafana dashboard with system metrics
kill-wrapper lode tool updated on containers
new documentation on windows incus vm and new macmini infra, operation guides
Miklos
- https://github.com/CollaboraOnline/online/issues/16219 “COOL paste: add a “merged” mode”
Michael S
updated skia in Classic branch
on main, skia looks unused
AI: file an easy hack for the removal (Michael S)
updating expat and libxml2
fixing SBOM generator performance
