COOL TC meeting minutes: 2026-10-21
Date: 2026-10-21
Present:
  • Luna, Regina, Adria, Andras, Banobe, Noel, Stephan, Michael S, Szymon, Tomaz, Michael M, Caolan, Miklos
Completed action items
Pending action items
  • check that no builds are incremental anymore (Adria)
  • crashtesting: ask Adria to help move this to COOL from soffice (Caolan)
  • Releases
    • CODE 26.05.5.2 this week (green CODE)
Patch review (Miklos)
  • All changes
    • Week 43: 274(+41)
  • GitHub PRs
    • Week 43: 1(+0)
    • Week 43: Dmytro Kulyk, Raúl F. Pérez, Simonth
    • Week 43: Tomaž Vajngerl (112), Miklos Vajna (98), Caolán McNamara (91), Noel Grandin (86), Michael Stahl (40), Szymon Kłos (23), Mike Kaganski (22), Andras Timar (13), Stephan Bergmann (8), Ashod Nakashian (8)
Bug reporting
Jenkins / CI update (Adria)
  • Szymon’s monitoring: “last builds” monitoring
    • looks good, didn’t even have to monitor this closely
  • Gerrit for online main
    • Week 43: Success rate is 70%, failed builds are 15/50
    • Week 43: Turnaround time is 1 hr 54 min (median of last 43 SUCCESS/FAILURE builds)
    • Week 43: 58% of lone pushes got a CI verdict within an hour (194 lone pushes in the last 7 days, median 51 min)
Crash testing (Caolan)
TTT talks
Animated GIFs (Szymon)
  • Play animated gifs on Safari macOS, iOS and CODA (Banobe)
    • ImageDecoder API has limitations on Safari and Http, which also limits animating the gif in CODA
    • Solution is to have a fallback for the above
    • Most used JS libraries are:
    • omggif is the better fit for COOL because it decodes one frame on request into a buffer we provide, which suits our 60-frame cache and on-demand decoding. modern-gif’s main decode function decodes every frame at once and returns each one as a separate full-size image, so memory use grows with the number of frames.
  • Screwed over by Apple again – re: unhelpful Safari … (Michael M)
    • do we really want to have another special-case for this broken platform ?
    • Should we do this everywhere ?
    • The API is new, perhaps we get it in Safari – lets polyfill (Szymon)
    • does it work for animated PNGs ? (Michael)
      • yes ImageDecoder works for that (Banobe)
      • do we need a fallback for animated-pngs ?
    • IOS browsers also have this problem (Banobe)
      • not the same engine – it’s an older Safari.
  • Decision: do the JS polyfill and drop it later when Safari baseline supports it
    • **AI: **grab omggif, cut out all the code we don’t use for encoding too (Banobe)
    • AI: map it into a polyfill (Banobe)
    • AI: update SBOM / license bits (Andras)
    • AI: look into fetch-API enabling for the Mac web-view (Banobe)
Dropping locking (Noel)
  • Can we drop (almost) all of the locking? Including SolarMutex?
    • This means that (just like right now) almost everything would run on the main thread,
    • except for a handful of things we push onto separate threads.
  • We have a list of threads we join before background-save (Miklos)
    • lcl_joinThreads() in engine/desktop/source/lib/init.cxx
    • this has a nice list of threads that we really use …
  • Changes required
    • (*) change the Java UNO remote bridge so that everything there runs
      on the main thread, means the protocol would need changes to handle
      a remote call that triggers a call back into the client-side process.
      • This is the hardest part of the change.
      • We don’t need this anymore in the mono-repo can go away (Stephan)
  • (*) Lose the solarmutex, but change it to assert that we are on the main thread.
  • (*) Annotate everything (with some kind of documentation?) that currently is spun off from
  • the main thread to run on separate threads, so we know what needs to keep its locks.
  • (*) Finally, remove all of the locking from existing UNO components code.
  • Have locking all over the place eg. in chart – which looks un-necessary …
  • Writer – doesn’t bother with fine-grained locking – just take the SolarMutex (Miklos)
    • Perhaps good to replace fine-grained locking with SolarMutex as precursor
  • Could we warn whenever we hit a contended SolarMutex and see what happens ? (Michael M)
    • perhaps gives some idea of what’s up …
  • Can python spawn threads and do things ? (Stephan)
    • JS presumably is single-threaded end of story …
    • Can StarBasic spawn threads ?
    • Did Kai’s appartment model thing work for cross-threading ? (Michael M)
      • its not bug-free (Stephan)
    • Python has threads – but has its own global mutex (Michael S)
      • Basic has no threading
    • Grammar checkers ran in own thread – which used UNO API to interact with writer (Michael S)
      • so can do expensive grammar checking without blocking.
      • This thread is still here – checkers do synchronous HTTP I/O (Miklos)
  • SocketPoll – proper async DNS and async requests usable in engine … is a good goal (Michael)
    • needs a bit of dependency thinking etc.
  • Does WebDAV use threads ? (Michael M)
    • it is all synchronous – with a thread handling timeout for locks (Michael S)
  • Good to kill the Windows VCL / cross-thread DC bits (Michael M)
What’s cooking
  • Szymon
    • did some race fixes, icon view (request render before we can do it, failing silently)
    • simplified state handling for “review mode” switch, plan to do for sidebar too
      • Would love the floating palette to have accept/reject etc. in it …
  • Stephan
    • dconf (for configmgr backend): was enabled by default when dconf-devel package is installed on machine (some Jenkins jobs have explicit –disable-dconf), got broken, Gerrit change to remove it → that failed on Jenkins because support for –disable-dconf is gone from the change; added a commit last week that turns the dconf default to “disabled”. Will now remove –disable-dconf mentions from Jenkins and re-land the change.
  • Noel
    • switching to a different approach for –enable-unitedlibs, Windows scuppered my approach, will try building a static library instead.
  • Caolan
    • dropped the macro recorder
    • Noticed that ci for older branches with firebird built super slowly, blocking main from getting slots. Fixed a silly in the classic branch there.
      • Should have taken 20mins out of the classic build time …
  • Adrià
    • MacOS webdriver tests on online main CI
    • Infra + jenkins job to release snap artifacts (amd64, arm64)
    • cypress tests 2 jobs merged into 1 (1 less engine build per patch)
    • RAM doubled (now 512GB) in chen HW - seems to solve the host performance issue
      • next step – do the same in Wilson … 25% more
      • gathering data to make the case conclusively – but seems to really help …
  • Regina
    • Ongoing discussion with ISO to have joint work on the spec of Calc functions
    • There will be a meeting in Nov, then in Jan next year
    • Already had 2 meetings
    • Have a sheet with all functions which LO/CO implements
    • If interested, happy to share
    • Plan is to share it with Excel; OOXML has a number of functions which are not documented, besides their end-user help
    • Related problem: no native Logical (BOOL) type in Calc (Michael M)
      • Would be good to add it to Calc, but it’s some work
    • 140 functions – which are implemented in Calc, but they are not in the ODF spec (Regina)
      • Some from MS may publish a spec for these in the future
    • Regexps are fun - PCRE2 is what Excel uses, we use ICU ones (Michael M)
    • Google re-uses our documentation for their formula engine too (Michael M)
  • Miklos
  • Michael S
    • security patch review fairy
  • Michael M
    • review Mohit’s re-connection work – with broken proxies …
    • cool-proxy.py – to catch re-connection …
      • make run-proxy …
    • mended scrolling pre-fetching of tiles in calc to improve perf.
  • Quikee
    • Client side cursor and selections movement in text edit mode
      • \Also cursor and selection animation
    • Fixes for text layout prediction – adding some cypress tests
    • Hyperlinks as spans instead of fields in EditEng
      • Have a backwards compatible solution
      • Fixing CI – many tests failed because they expect hyperlink as 1 char
      • Would love to have a linter check to “mend your links” to have the new property on it.
    • Researching GROUPBY and PIVOTBY formulas from MSO 365 (long term)
    • Removing GrabBags – Effects and Artistic Effects
    • Removing comphelper::COKit::isActive() == false code paths
  • Luna
    • Swedish translations for Engine
  • Andras
    • Enabled our Weblate to translate engine
    • External sentence checkers: LanguageTool, Duden Korrekturserver, Grammalecte
      • in CODA and per user setting in COOL/CODE
    • Translator services: DeepL and LibreTranslate
