COOL TC meeting minutes: 2026-10-28
Date: 2026-10-28
Present:
  • Caolán, Noel, Stephan, Andras, Michael M., Tomaz, Adria, Michael S., Szymon, Kohei
Completed action items
  • Animated Gifs
    • **AI: **grab omggif, cut out all the code we don’t use for encoding too (Banobe)
    • AI: map it into a polyfill (Banobe)
    • AI: look into fetch-API enabling for the Mac web-view (Banobe)
  • AI: update SBOM / license bits of animatet gif (omggif) (Andras)
    • done from my side, I reviewed the patch wrt SBOM (Andras)
Pending action items
  • check that no builds are incremental anymore (Adria)
  • crashtesting: ask Adria to help move this to COOL from soffice (Caolan)
  • Releases
    • CODE 26.05.6.1 next week (red CODE)
    • COOL 26.04.5.3 and CODA 26.04.5.3 next week
Patch review (Miklos)
  • All changes
    • Week 44: 230(-44)
  • GitHub PRs
    • Week 43: 1(+0)
    • Week 44: Besmir Godolja, Inger Leire Fenger, Mette Kærgaard Hansen, Michal, PhD. Ayhan YALÇINSOY, Sonia Breuer Bistrup, คนแปล มังงะฝึกหัด
    • Week 44: Mike Kaganski (113), Caolán McNamara (92), Noel Grandin (64), Tomaž Vajngerl (58), Miklos Vajna (51), Michael Stahl (36), Szymon Kłos (20), Stephan Bergmann (15), Michael Meeks (11), Samuel Mehrbrodt (10)
Bug reporting
Jenkins / CI update (Adria)
  • Gerrit for online main
    • Week 44: Success rate is 78%, failed builds are 11/50
    • Week 44: Turnaround time is 29 min (median of last 46 SUCCESS/FAILURE builds)
    • Week 44: 77% of lone pushes got a CI verdict within an hour (204 lone pushes in the last 7 days, median 36 min)
    • Week 43: Success rate is 70%, failed builds are 15/50
    • Week 43: Turnaround time is 1 hr 54 min (median of last 43 SUCCESS/FAILURE builds)
    • Week 43: 58% of lone pushes got a CI verdict within an hour (194 lone pushes in the last 7 days, median 51 min)
  • Getting more parallelism with cypress tests saving around five minutes on the CI run.
Crash testing (Caolan)
  • 2026-10-28: 2 (-1, +0)
  • Can we do the 16 day run … to get all of the files onto the server ? (Michael)
  • not enough space on the server … (Caolan)
    • talking +1 Tb disk would do it …
  • Is the ‘crashiness’ uniformly distributed or not … ? (Michael)
    • the commonality is quite high … (Caolan)
      • there is a test-case document for all the ODP features in gerrit somewhere.
TTT talks
JODConvertor bits
  • Should we delete it now – if it is deprecated ? (Caolan)
  • Currently it stands in the way of removing a lot of locking across the engine (Noel)
    • because of this all the components require their own locking.
    • This is the last thing that requires lots of locking.
  • Was eager to use it for pdfium to do synchronous look-ahead I/O wrapper (Michael)
    • for loading huge PDF files.
    • Lets get rid of it … (Michael)
Threading redux
  • Remove the UNO remote bridge
  • across the engine – only a handful of places need locking
  • Chart and framework can go lock-free …
  • Keep the SolarMutex around for a while …
    • needed for the Grammar checker …
  • SocketPoll as VCL main-loop ?
    • Can we get rid of the LOK abstraction and just use it ?
  • We talk to printers and clipboards on Windows etc. (Noel)
  • Ideally we run the engine/ in its own thread and sandbox that hard …
  • Someone started pushing patches trying to get locking right in Chart (Noel)
    • and turns out we don’t need it.
What’s cooking
  • Szymon
    • Checking cleanup of PostMessage APIs and SDK
    • Caching improvement in Impress
      • this is done on the webserver thread not in a DocumentBroker …
    • Template initial lookup failing on file restriction rules in COOL https://gerrit.collaboraoffice.com/c/online/+/17718
  • Stephan
    • test harness for running add-ons against document corpus (so e.g. text doc content iteration doesn’t get stuck or misses parts)
  • Noel
    • converting Junit tests to C++ tests
      • removing an UNO remote bridge blocker
  • Caolan
    • some more ci efforts, gdb can hang itself for 20 minutes
      • infrequently happens but we loose an hour of CI
    • video background – getting this working smoothly …
      • store a preview of media in the file …
      • insert→image – a standard frame on a master-slide …
    • ServerId mismatch / WOPISrc routing problems on share …
  • Adrià
    • macos app wdio tests – preparing CI infra
    • CODA flatpak Debug nightly
  • Regina
    • Not in meeting
  • Miklos
    • On leave
  • Michael S
    • add SBOMs to MSIs
    • python upgrades – 2x new versions in 4 days …
    • reviewing 108 patches for a customer branch …
  • Michael M
    • Disabling optimization for top-level test/ cppunit tests
      • spending a lot of time linking for no good reason.
    • Could we also do this for engine/ tests ?
    • On Windows 120 test-cases there – bottleneck … (Caolan)
      • not very clear if we loose on time running the test, vs. compiling it.
  • Quikee
    • Vector rendering – adding rendering to final missing primitives
  • Kohei
    • Moving the cell cursor movement in calc from engine → client side …
    • Trying to fill in the 12 year gap in the code-base … stopped in 2014 …
  • Andras
    • Persistent AutoCorrect settings in COOL/CODA (in main → 26.04.6.x)
      • improving the writing aids in Writer…
    • Branding in tree. COOL/CODE/CODA. https://gerrit.collaboraoffice.com/q/topic:%22branding-in-tree%22
      • first set of patches are in gerrit waiting for review.
      • Have to do lots of things in parallel to get the product
        build-able and to keep CI happy
