COOL TC meeting minutes: 2026-11-04
Present:
  • Luna, Miklos, Regina, Adria, Caolan, Szymon, Noel, Stephan, Tomaz, Michael S, Michael M, Thorsten, Kohei, Andras
Completed action items
Pending action items
  • no builds should be incremental anymore (Adria)
  • crashtesting: get this moved to COOL from soffice (Caolan)
    • more disk space coming
  • Releases
    • CODE 26.05.6.1 this week (red CODE)
    • COOL 26.04.5.3 and CODA 26.04.5.3 this week
Patch review (Miklos)
  • All changes
    • Week 45: 226(-4)
  • GitHub PRs
    • Week 45: 1(+0)
    • Week 45: Francesco Saltori, Inger Leire Fenger, Mette Kærgaard Hansen, Michal
    • Week 45: Caolán McNamara (139), Tomaž Vajngerl (88), Noel Grandin (70), Mike Kaganski (63), Szymon Kłos (52), Michael Stahl (32), Stephan Bergmann (29), Miklos Vajna (24), Samuel Mehrbrodt (20), Andras Timar (14)
Bug reporting
Jenkins / CI update (Adria)
    • Web-UI is timing out …
  • Status (Adria)
    • More memory is purchased, supposed to arrive sometime this week.
      • ETA seems to have shifted to early next week (Mon or Tue)
  • Szymon’s stats: not monitoring, was too good recent time :slight_smile:
    • Mohit also running the stats locally …
    • AI: make this part of the dashboard, talk to Andras (Szymon)
  • Gerrit for online main
    • Week 45: Success rate is 50%, failed builds are 25/50
    • Week 45: Turnaround time is 50 min (median of last 47 SUCCESS/FAILURE builds)
    • Week 45: 73% of lone pushes got a CI verdict within an hour (225 lone pushes in the last 7 days, median 41 min)
Crash testing (Caolan)
TTT talks
What’s cooking
  • Szymon
    • Working on Impress
  • Stephan
    • not much to report this week (scripting corpus checks found some sanitizer issues outside scripting)
  • Noel
    • Little bit of performance chasing autofilter stuff.
    • Converted Java unit test → C++ unit tests …
    • Removed the Java remote URP bits, but the C++ side / python bits are still using it
      • Python UI test → Cypress conversion (?) … it is using URP …
    • Surprised it’s not in-proc (Stephan)
      • many UI tests are irrelevant with COOL / CODA
      • some test something in the engine via the UI
        • perhaps replaced with different sorts of tests …
    • Apartment – cross-thread marshalling ? (Michael M)
      • how did that work ? (Michael S)
        • marshalling across the threads …
        • could we work out how this binary UNO stuff is marshalled ?
        • Prefer to try the SocketPoll bits for now (Stephan)
    • Quite useful technology (Thorsten)
      • if it does more than helping with the threading cleanup
    • Could we use SocketPoll for URP ? (Michael M)
      • callbacks could be a problem, cross messages etc. (Noel)
        • we could just re-enter during the outgoing call (Michael)
      • UI tests only run on Linux anyway (Michael)
        • so – we could then just re-use a unix domain socket SocketPoll
        • and spin that poll loop as/when we wait for responses (and/or flush outgoing URP stuff)
        • as per the synchronous https:// calls we have in the core …
        • will prolly help break the engine/ net/ separation …
  • Caolan
    • some video bg fixing (thats looking for review)
    • using a (fancy) memory_resource thing to keep some load-time-only spreadsheet pieces out of the rest of memory so it doesn’t leave a pile of holes behind in long-term memory post-load
      • quite a bit of memory saving here 5Mb here and there from gaps …
      • custom allocator for this – for Linux/Windows etc.
  • Regina
    • ongoing testing and reviewing of Armins’ smart-art work …
      • testing involves generating self-defined smart-arts,
        which go beyond what’s in the presets
    • Can we build a gallery of self-defined shapes as we go ?
      • Starting with existing ones – and tweaking them
        when we need our own – should start from scratch.
        • no documentation at all.
  • Adrià
    • renew apple certificates for CI
    • Jenkinsfile for iOS (+ working on a plan to add more jenkinsfile for other checks)
      • code for CI should live in online in the end.
  • Miklos
  • Michael S
  • Michael M
    • nothing (distracted by annual reviews…)
  • Quikee
    • Vector rendering
      • Finished list of missing primitives, but review found some more
        • A couple of these – solved the form-field button bits …
      • Implemented slideshow animations with vector rendering
        • Objects rendered to “layers” so we get 60fps with WebGL
        • Some objects could be rendered directly in WebGL
        • Fixed presenter console to work with vector rendering
        • Changed presenter console to render twice instead fetching texture from GPU, which is a performance killer
    • Can we get some of the comprehensive test files into git ? (Michael M)
      • there are mocha tests to test JSON …
  • Kohei
    • Still working on moving the cell cursor movement and range selection logic from the engine to the client – high level view …
      • mechanism adding – have the engine report to the client interesting things about the sheet: spark-line group ranges, style ranges, dynamic array ranges,
      • cursor movement logic → the client.
      • Client reporting → engine the cursor it wants to go to …
        • server correcting based on merged / protected cells / etc.
        • seeing if this can be used for handling them …
  • Andras
    • Better OOXML export for custom shapes and fontwork
      • can export equations for handles / guides + some 3D properties …
  • Luna
    • Swedish translations done together with Leif-Jöran as usual
