Present
Ivana, Raul, Sahil, Darshan, Armin, Banobe, June, Pedro
Impress – Running on Primitives
Shapes: Armin is working on shapes.
Quikee is about to merge this.
Armin will ping us once this happens.
Vector: UI needs to be redone, with more work on the client side.
Glue points
Ivana
Calc – Cell selection
Cell selection currently appears difficult to read; the contrast between the background and text could be improved.
AI: Ivana to create an enhancement issue describing the current state and ideally how it should look.
Meta-presentations – Statuses and icons
Ivana has some notes regarding UX/UI for Import Slides.
Ideally, create a GitHub enhancement issue with the
UXtag. -
Current version is much better, but we could still iterate on the warning/danger icon so it works better at that size and style.
Slide notes icon – Impress
Onboarding flow
Convert this into a GitHub issue.
Missing parts from Darshan’s WIP changes should be pushed into a WIP change chain:
Transition
Box-shadow per component
Overlays:
No overlays for onboarding.
Use overlays for the new updates dialog.
Highlight colour exception for components that already have a document-type background.
- AI: Ivana to prepare a different case for the top toolbar (blue colour) as well.
Existing issues
Raul
Current – Need Opinions
Writer – Picture tab: Fill Color button
Looks good.
AI: Pedro & Ivana to test and see if we can come up with a better user flow.
Ivana suggested:
Add a tooltip explaining how to use it, since it only works with transparent images.
Alternatively, show the button only when the image is transparent, or enable/disable it depending on the image.
Shape tab – Line Thickness dropdown
- Discussed whether the dropdown could be confusing for users.
Next – Moving from Sidebar to Notebookbar
Two options were discussed:
Shape > Effect section
- Need to determine the appropriate placement.
Formula > Formula section
Potentially move the entire sidebar into a panel similar to Extensions.
This area needs further work regardless.
