Present: Ivana, Raul, Darshan, Vivek,Pedro,sahil
Banobe
Review Mode: https://github.com/CollaboraOnline/online/issues/15721
implemented for Writer and acceptance criteria of:
When in review mode, recording is turned on
User can add comments
Pending questions:
When switched to review mode should the tab change to “Review”
Accept and reject permission
Sharing option in richdocuments for Review
Pedro: Turning off tracking changes should move to edit mode and vice versa
On Boarding work : https://gerrit.collaboraoffice.com/c/online/+/13504
- AI (Ivana): create icon for Show Tour
Vivek
Delete button for remove AI assistance api key => https://gerrit.collaboraoffice.com/c/online/+/13537/3
things to fix:
horizontal scrollbar
icons down chevrons padding
status needs a fix
input select elements should all have the same width
13689: browser: simplify shared AI provider configuration | https://gerrit.collaboraoffice.com/c/online/+/13689
Introduce default(Server/empty) api key on reset button
Disable/enable button for User AI Assistance
Raul:
Comments covering document when zoomed in (25.04): what is the expected behavior?!
There are 2 problems
comment is cropped/behind the interface (notice the notebookbar and status bar are above it)
Also check if it is possible to dismiss/hide comment not only via mouse but also keyboard
Comment above document text: comment cards are floating elements in that branch/version so, that is expected.
Properties section rework (incl. Line Thickness dropdown) – will send some mockups myself today
Calc: moving / resizing a chart while editing it seems to result in a freeze / crash – I can work on it but I need to know the expected behavior
Yes, please remove the option to resize or move the whole object when in editing mode.
Don’t allow moving chart elements outside of its frame
Ok, but what if a user:
1. Double click a chart
2. Rename a label
3. The label is now too long and goes beyond the frame
4. User wants to increase the frame of the chart
5. Not possible.
Writer: Formula Bar move – split the container into a container for each section, with its label beneath
Writer: Fill Color user flow improvement – Caolan asked “why go through the effort of disabling?”, giving “border color where there is no border or text color for hidden text” as examples
Need review: https://gerrit.collaboraoffice.com/c/online/+/13930 – Slide sorter alignment / spacing issue
Ivana
Trash icon redesign
Impress: grid view
created some issues for import slides panel https://github.com/CollaboraOnline/online/issues/16254
Sahil’s CODA suggestion on collaborative editing widgets.
Flow: first time big popup will be presented, if user chooses “local edit”, then we show Sahil’s mock ups for top tool bar. Some ux/ui comments for Sahil:
remove +2
remove label Robin
remove container
remove x button
rename button label from Join to Edit together
Sahil
The Join Widgets
The Invitation Widgets
The comments widgets
