COOL UX-UI Design meeting minutes: 2026-10-08
2026-10-08
Ivana:
  • Some of the button alignments are off (writer: insert tab/illustrations: shapes. Calc: insert tab: functions)
    • image
    • AI (Ivana): file task
  • Impress: View/Open the Shapes Deck (researched)
    • Saw Pedro’s PR of new name “Shapes Deck” ← makes sense:)
    • This was shown in Online: 2026-09-07 https://gerrit.collaboraoffice.com/c/online/+/11762
      • questioning whether it makes sense to have this View tab > Shapes Sidebar shown? how is it different to insert/shapes? I propose to move all the shapes to same location (insert/shapes)
      • Pedro: for A11Y reasons it might make sense to have a sidebar so the user can freely navigate and listen screenreader for each shape etc. Plus this makes it easier (less clicks) to create diagrams. Ideally, we would have a single component dropdown with items and a button at the end (akin to Layout > Margin), present twice: in the Insert tab and in the View tab.
  • Impress: grid view exploration
    • Main issue: grid is not visible when enabled
    • Idea: to add major and minor lines for better orientation and alignment
    • Pedro: low prio/enhancement; ruler should probably be part of the same story. Also we should double check how it looks in hdpi vs mdpi
  • Meta-presentations:
    • Ivana has new icons
      • Fri, Sep 18 1st batch (ignore source missing)
      • Thu, Sep 24 2nd batch that has the source missing
    • To do (but wait until Pedro pushes the change):
      • Alert (low prio)
  • Calc: Hyperlink dialog update
    • What is the problem:
    • Mockup
      • Maybe we could use the same labels as in text documents (so, link)
      • The mockup looks nice and I think we can move forward, particularly because when using spreadsheets we don’t have the same auto fill hyperlink functionality as in text documents.
  • Pedro (To do): create a low prio gh issue to improve horizontal tabs on dialog
  • Banobe
    • Area tabs in dialog (Color, Image, Pattern, Hatch, Gradient) 14407: jsdialog: build every fill type of the Area page once | https://gerrit.collaboraoffice.com/c/online/+/14407
      • Render all tabs in one screen layout
      • define which is most used actions (1. colour, 2. pattern?, 3. gradient?)
    • CODA tabs
      • polishing https://gerrit.collaboraoffice.com/c/online/+/14205
        • Pedro: would be great to have a right click context menu to close all tabs to the right
          • List of actions to have in the context menu?
            • To complete
      • now working on Thumbnails on Wondering what should display, just an image or image and document title?
  • Raul:
    • Pedro: Perfect, please do not added further overlays, context is key here, good to don’t cover axis etc.
      • In progress
        • Calc: Chart highlight – should the inner element be highlighted (using dimming) when selected or should the chart stay selected.
        • I don’t remember touching the alignment in Ivana’s section, but I can fix it :slight_smile:
      • Merged:
        • Shape / Picture tabs Properties section rework
        • Writer: Elements sidebar deck moved to Formula notebookbar tab
