@darshan or @andras.timar or any other administrator,
Could you enable the ability to add Glossary terms in Weblate?
Good idea, thanks! I enabled the Glossary. Making sure you're not a bot!
Could you add @sebastiaanveld to the white list as well?
Any logged-in user can edit the glossary. Sebastiaan already has full translator rights on Weblate, glossary included, and there is no whitelist there. Which list do you mean?
I thought that āmaking sure youāre not a botā implied something like a white list
@andras.timar do you know if deviation from the glossary leads to āhas checkā markings?
FYI, Iām a big fan of āhas checkā combined with āsimilar translationsā as they open doors to many errors and consistencies
No, the glossary check was not turned on. I enabled it now.
