Build of Collabore Office Classic fails in vcl/win/dtrans/FmtFilter
After a ./g pull -r and a make clean I have started a new build on Windows. But it fails with
/engine/vcl/win/dtrans/FetcList.cxx(145): error C7568: argument list missing after assumed function template ‘Sequence’
and with several error messages in /engine/vcl/dtrans/Fmtfilter.cxx, for example:
/engine/vcl/win/dtrans/FmtFilter.cxx(62): error C7568: argument list missing after assumed function template ‘Sequence’
C:/colwsl7/online/engine/vcl/win/dtrans/FmtFilter.cxx(132): error C2556: ’ WinENHMFPictToOOMFPict(HENHMETAFILE)': overloaded function differs only by return type from ‘cpo::uno::Sequence<sal_Int8> WinENHMFPictToOOMFPict(HENHMETAFILE)’
C:\colwsl7\online\engine\vcl\win\dtrans\FmtFilter.hxx(37): note: see declaration of ‘WinENHMFPictToOOMFPict’
C:/colwsl7/online/engine/vcl/win/dtrans/FmtFilter.cxx(132): error C2371: ‘WinENHMFPictToOOMFPict’: redefinition; different basic types
That is most likely a fallout from commit 14bf02c09226591481735d02b9276f3968d4bcbd, you can try to change the implicit uno::Sequence to cpo::uno::Sequence in the mentioned lines and see if that helps.
I assume you hit this because CI only tests the --with-distro=CODAWindows config (as documented at Build Collabora Office for Windows | Collabora Office - Community Page ), but you don’t seems to use that? I guess --enable-headless is what bypasses this code in the working case. Thanks.
The files have a using namespace com:sun:star:uno; . Need there be something like using namespace cpo::uno ? If yes, in addition or instead?
Or/and needs a #include <cpo/uno/Sequence.h>?
I do not use --with-distro=CODAWindows because I want a Office Classic, for to be similar to LibreOffice.
I’ll do that. It looks good so far (build is running). The problem seems to have been, that the files do not contain uno::Sequence but only Sequence and thus were not caught by the script.
Build has finished with that changes. The patch with these changes is now at https://gerrit.collaboraoffice.com/c/online/+/6499
Add `using namespace cpo::uno;`. That code doesn’t get tested in CI’s default config, so it went unnoticed till you built classic.
