Collabora Code & Nextcloud in docker works - but doesn't
Hello There
I was sent here by our friends over at the nextcloud forum. See my post over there for additional info: Nextcloud & Collabora CODE docker compose almost everything is working - except it isn't - 📄 Collabora - Nextcloud community
I am running Docker on my Debian server and have a docker-compose containing the following services:
  • nextcloud → official image running 28.0.2
  • collabora/code → official image, latest version
In Addition I have the nginx-proxy-manager in another docker-compose file which is handling all the proxying.
I installed Collabora and was pleasantly surprised how easy and quick everything worked. I can Edit, Share and Create new documents. :tada:
[11:42:48] [~] ❱❱❱ curl https://office.mydomain.tld
OK%
After my initial success, I wanted to visit the admin dashboard at https://office.mydomain.tld/browser/dist/admin/admin.html → a login prompt appears and I can’t log in using my defined credentials. Or any other credentials.
I’ve set the “username” and “password” in the environment variables in my docker-compose file as well as the commonly mentioned ssl extra_params (extra_params appear to be working).
In addition, I then tried to upload custom fonts via the Nextcloud Office Administration Settings and add the custom font json via extra_params as well. This also doesn’t work.
This appears to be working now after I removed the local DNS entry from my pi-hole instance.
Here is my docker-compose config for collabora:
    image: collabora/code
    hostname: nc-collabora
    privileged: true
    restart: unless-stopped
      - TZ=Europe/Zurich
      - dictionaries=de_DE
      - VIRTUAL_HOST=office.mydomain.tld
      - aliasgroup1=https://cloud.mydomain.tld
      - server_name=office.mydomain.tld
      - username="${COLLABORA_USERNAME}"
      - password="${COLLABORA_PASSWORD}"
      - "extra_params=--o:ssl.enable=false --o:ssl.termination=true --o:remote_font_config.url=https://cloud.mydomain.tld/apps/richdocuments/settings/fonts.json"
      - proxy
      - nextcloud
After some more digging I found that the coolwsd command inside of the docker container doesn’t work as well:
cool@nc-collabora:/$ coolwsd
Failed to initialize COOLWSD: Access to file denied: /usr/bin/jails
wsd-00081-00081 2024-02-27 11:51:11.752447 +0100 [ coolwsd ] INF  Initializing wsd. Local time: Tue 2024-02-27 11:51:11 +0100. Log level is [8]| common/Log.cpp:597
wsd-00081-00081 2024-02-27 11:51:11.752463 +0100 [ coolwsd ] INF  Setting log-level to [trace] and delaying setting to [warning] until after WSD initialization.| wsd/COOLWSD.cpp:2424
wsd-00081-00081 2024-02-27 11:51:11.752469 +0100 [ coolwsd ] INF  Initializing coolwsd server []. Experimental features are enabled.| wsd/COOLWSD.cpp:2435
wsd-00081-00081 2024-02-27 11:51:11.752478 +0100 [ coolwsd ] DBG  New SocketPoll [UnitWSD] owned by 0x7f07350da880| net/Socket.cpp:199
wsd-00081-00081 2024-02-27 11:51:11.752526 +0100 [ coolwsd ] INF  Anonymization of user-data is configurable.| wsd/COOLWSD.cpp:2504
wsd-00081-00081 2024-02-27 11:51:11.752534 +0100 [ coolwsd ] INF  Anonymization of user-data is disabled.| wsd/COOLWSD.cpp:2551
wsd-00081-00081 2024-02-27 11:51:11.752548 +0100 [ coolwsd ] INF  SSL support: SSL is enabled.| wsd/COOLWSD.cpp:2601
wsd-00081-00081 2024-02-27 11:51:11.752550 +0100 [ coolwsd ] INF  SSL support: termination is disabled.| wsd/COOLWSD.cpp:2602
wsd-00081-00081 2024-02-27 11:51:11.752554 +0100 [ coolwsd ] DBG  Setting envar PDFIMPORT_RESOLUTION_DPI=96 per config per_document.pdf_resolution_dpi| wsd/COOLWSD.cpp:2628
wsd-00081-00081 2024-02-27 11:51:11.752571 +0100 [ coolwsd ] INF  Creating childroot: /usr/bin/jails/81-b2a527db/| wsd/COOLWSD.cpp:2668
wsd-00081-00081 2024-02-27 11:51:11.752950 +0100 [ coolwsd ] INF  Cleaning up childroot directory [/usr/bin/jails/].| common/JailUtil.cpp:200
wsd-00081-00081 2024-02-27 11:51:11.752955 +0100 [ coolwsd ] TRC  Directory [/usr/bin/jails/] is not a jail directory or doesn't exist.| common/JailUtil.cpp:205
wsd-00081-00081 2024-02-27 11:51:11.752956 +0100 [ coolwsd ] INF  Cleaning up childroot directory [/usr/bin/jails/81-b2a527db/].| common/JailUtil.cpp:200
wsd-00081-00081 2024-02-27 11:51:11.752958 +0100 [ coolwsd ] TRC  Directory [/usr/bin/jails/81-b2a527db/] is not a jail directory or doesn't exist.| common/JailUtil.cpp:205
wsd-00081-00081 2024-02-27 11:51:11.752960 +0100 [ coolwsd ] INF  Creating jail path (if missing): /usr/bin/jails/81-b2a527db//tmp/incoming| common/JailUtil.cpp:279
wsd-00081-00081 2024-02-27 11:51:11.753028 +0100 [ coolwsd ] FTL  Failed to initialize COOLWSD: Access to file denied: /usr/bin/jails| wsd/COOLWSD.hpp:534
Also, the WOPI allow list field in the Administration settings can’t be filled in, although apparently that is a nextcloud bug that is already being worked on ([Bug]: Unable to Enter IP in 'Allow List for WOPI Requests' in Nextcloud Admin Settings · Issue #3377 · nextcloud/richdocuments · GitHub).
Is there a workaround to add IP Addresses to the WOPI allow list without editing the coolwsd.xml?
I’d be happy to provide additional logs or infos if it helps.
Thanks in advance :smiling_face:
Hey @scorewinner. Welcome to the forum + thanks for the questions. :slight_smile:
Which exact version is this?
  • And even better, the exact Help > About info.
(Remember, someone can stumble upon this a week from now, and the “latest version” can be different.)
Hmmm, looks like that specific richdocuments #3377 was fixed last week, so hopefully your next update will take care of that specific issue.
I don’t believe so.
I think you’d have to manually edit your lok_allow + <host desc=""></host> lines in your coolwsd.xml.
Hmmm… and what if you try to temporarily set the username/password to something super easy.
Then see if you can login to the admin console fine.
Thanks for the warm welcome :slight_smile:
I’m running Collabora Version: 23.05.9.2. Not sure where Htlp > About is supposed to be, in Nextcloud?
I’ve tried setting it to “admin” and “password” still nothing :confused: I also tried replacing the env variables with the actual values…
In Collabora Online itself. (Once you successfully get in there that is.)
But version “23.05.9.2” is good enough for some basic debugging. Thanks. :slight_smile:
