Collabora/CODE not working with NC 24.0.3 in Docker
I am running Nextcloud 24.0.3 and the Collabora/CODE separate containers in Docker & connecting them using an internal docker network. Using the Nextcloud Office app, I can successfully connect them together (I get the green check in the admin settings page), However whenever I attempt to open a .odt file it says: “Document loading failed. Failed to load Nextcloud Office - please try again later”
Here is my docker-compose stack:
version: "3"
  nextcloudapp:
    image: nextcloud:apache
    restart: unless-stopped
    container_name: nextcloudapp
    hostname: nextcloudapp
      - data:/var/www/html
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=nextcloud
      - MYSQL_PASSWORD=********
      - MYSQL_HOST=nextclouddb
      - REDISHOST=nextcloudredis
      - APACHE_DISABLE_REWRITE_IP=1
    depends_on:
      - nextclouddb
      - nextcloudoffice
      - nextcloudredis
      - frontend
      - backend
  nextcloudoffice:
    image: collabora/code
    container_name: nextcloudoffice
    hostname: nextcloudoffice
    cap_add:
      - MKNOD
      domain: "files.example.com"
      - backend
  nextclouddb:
    image: mariadb
    container_name: nextclouddb
    hostname: nextclouddb
      - MYSQL_RANDOM_ROOT_PASSWORD=********
      - MYSQL_PASSWORD=**********
      - db:/var/lib/mysql
      - backend
  nextcloudredis:
    image: redis:alpine
    container_name: nextcloudredis
    hostname: nextcloudredis
      - backend
  nextcloudcron:
    container_name: nextcloudcron
    entrypoint: /cron.sh
    depends_on:
      - nextclouddb
      - nextcloudredis
      - backend
   data:
   db:
  frontend:
    external:
  backend:
(The proxy-apps external network contains my nginx-proxy-manager container that I am using as a reverse proxy & generating SSL certificates for nextcloudapp)
Currently I am just trying to connect the two containers internally (which seems more secure), however some tutorials (e.g: https://www.youtube.com/watch?v=BAc15RHfwEA) have suggested to also put the Collabora/CODE container available externally on it’s own domain with an SSL certificate. Is this necessary/the solution to my problem? (As I said this seems less secure so would rather not do it, as only my internal NC instance needs access to this container)
TL;DR How to make Collabora/CODE container work for NC 24, even though it successfully connects.
This is the successful connection to the Collabora/CODE container
Solved here: Collabora/CODE not working with NC 24.0.3 in Docker - #4 by wwe - 🚧 Installation - Nextcloud community
