The prototype agenda is below. Extra items are appreciated either in
this document or as a reply to this forum post:
You can join using Jitsi here:
Date: 2026-06-17
Present:
Completed action items
Pending action items
File a github issue for the canvas / slideshow cleanup (Thorsten)
Look at on-demand HW from Hetzner (Andras)
File a github issue to track the com.sun.star → cpo name change (Noel).
github online.git: remove all code there, the README etc stays (Andras)
Add in fallback server URL support, and fall-back if the socket fails to connect to horror-style URLs – and note in red in the admin console (Caolan)
wasm: Check some run-time configuration / logic as to whether we should serve the WASM or not (Stephan)
wasm: generate a separate WASM package in due course with the necessary blob (Adria)
Check LibreOffice loads WEBP files and switch to not doing the PNG conversion (Quikee)
Monorepo status
CI~~– complete, only the fuzzer is under testing now, it broke this week
- was enable, then disabled – to try to get it into the best shape first
**Releases **(Andras)
CODE 26.04.1 is out, released earlier this week
development can continue on main branch
distro/collabora/co-26.04 branch is created in case we have to release again for CODE 26.04.1 (and also for CODA)
Patch review
- Week 25: 199(+9)
- Week 25: 23(-3)
- Week 25: Ibnu Batuthah, Isaki23, Артур
- Week 25: Miklos Vajna (71), Caolán McNamara (46), Noel Grandin (32), Tomaž Vajngerl (26), Stephan Bergmann (21), Szymon Kłos (16), Michael Stahl (9), Andras Timar (7), Mike Kaganski (6), Michael Meeks (5)
Bug reporting
- Week 25: 12(-2)
Jenkins / CI update (Andras)
- Week 25: Success rate is 14%, failed builds are 43/50
Re-visit new hardware next week.
Crash testing (Caolan)
2026-06-10 192 (-34, +0)
MatrixResizeGuard for ScColumn::CalcAll fix in motion
unshare formula cells the matrix import overwrites
2026-05-31 278 (-269, +0)
- crashtesting: defer dynamic-array resize while measuring optimal
row height fixed, hoping to hit the bulk of those now
TTT talks
Have a plan for the next 2 weeks?
What’s cooking
Regina
Stephan
Andras
Quikee
Szymon
Noel
Miklos
Caolán
Adria
