Coolmount fails to function
Hello everyone,
In my collabora instance with the official Docker image called collabora/code:latest I get this error whenever closing a document.
sh: 1: /usr/bin/coolmount: Operation not permitted
Everything functions, but I would like to suppress of entirely fix this issue. From my own research, this command does work again after recreating it by copying it away and replacing the original one. or by chowning it to cool:cool inside the container.
this is my compose:
    image: collabora/code:latest
#    privileged: true
    container_name: 'collabora'
      - cloud-nextcloud
      - /etc/localtime:/etc/localtime:ro
      - ./coolwsd.xml:/etc/coolwsd/coolwsd.xml
      - 9980:9980/tcp
    restart: always
      - username=admin
      - password=pass
      - aliasgroup1=https://nextcloud\.domain\.nl:443
      - server_name=devcolla\.domain\.nl
      - extra_params=--o=ssl.enable=true--ssl.termination=true
#    cap_add:
#      - MKNOD
  cloud-nextcloud:
    external: true
I would like to use this for our company and need production functionality. or at least no errors spamming the stdout.
Hi Daan, dseen,
Welcome to this forum :sun_with_face: & thanks for your clear description!
I can understand that yes :slight_smile: To sort out possibilities for (commercial) support here, best is to send an email to sales@collaboraoffice.com and/or share (in a DM) your contact details.
Hope that helps,
Cheers,
Cor
Have you given root privileges to that mount process, in order to get secure containment; are there other errors in the logs (?)
Thanks.
wsd-00001-00062 2024-05-05 22:03:48.193635 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_searchprev.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.193987 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_statetablecellmenu.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.194329 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_searchnext.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.194964 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_prev.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.195385 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_zoom.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.195762 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_next.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.211432 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/lc_statetablecellmenu.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:48.212070 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/lc_zoom.svg].| wsd/FileServer.cpp:751
frk-00026-00026 2024-05-05 22:03:48.384003 +0200 [ forkit ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:425
wsd-00001-00062 2024-05-05 22:03:49.064654 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_insertsheet.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:49.210446 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/lc_statetablecellmenu.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:49.286514 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/user.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:49.293941 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/lc_statetablecellmenu.svg].| wsd/FileServer.cpp:751
wsd-00001-00062 2024-05-05 22:03:49.336918 +0200 [ websrv_poll ] ERR  FileServerRequestHandler: File not found: Invalid URI request: [/browser/f12ee1f/images/dark/user.svg].| wsd/FileServer.cpp:751
These are all the errors of a single “chain”, with this compose:
#    privileged: true
      - cloud-nextcloud
      - /opt/colla/images:/usr/share/coolwsd/browser/dist/images
      - 9980:9980/tcp
    restart: always
      - username=admin
      - password=PASS
      - aliasgroup1=DOMAIN1
      - aliasgroup2=DOMAIN2
      - server_name=COLLA DOMAIN+SUB
    cap_add:
      - MKNOD
  cloud-nextcloud:
    external: true
I filtered some things out.
I see in my docker compose that I mapped the image folder as well, but the needed images are missing there as well, so this line can be removed.
