Failed setsockopt TCP_NODELAY
Hello, sorry for my bad English.
I have installed Collabora in container LXC Debian bookworm unconfined
Package versions:
  • collaboraoffice 23.05.5-1 amd64
  • coolwsd 23.05.5.1-1 amd64
  • code-brand 23.05-16
The coolwsd logs show the following error lines:
Oct 17 09:44:17 collabora coolwsd[161]: kit-00161-00149 2023-09-17 09:44:17.176264 +0000 [ kit_spare_002 ] ERR  #26: Failed setsockopt TCP_NODELAY: Operation not supported (EOPNOTSUPP: Operation not supported)| net/Socket.hpp:206
Oct 17 09:44:17 collabora coolwsd[123]: wsd-00123-00148 2023-09-17 09:44:17.176330 +0000 [ prisoner_poll ] ERR  #28: Failed setsockopt TCP_NODELAY: Operation not supported (EOPNOTSUPP: Operation not supported)| net/Socket.hpp:206
Collabora works rigth (apparently)
How could I solve these error lines?
any clue where I can look?
@Jorgepastorr
Hey,
did you find out the solution for the issue ?
I have the exact same issue.
best regards,
I continue with the same error
Collabora works, I haven’t seen anything fail in collabora, but logs show that error
Ah - thinking about it this is prolly a new kernel error when we set nodelay on a Unix domain socket: net: don't try to set TCP_NODELAY on local Unix sockets. by mmeeks · Pull Request #7573 · CollaboraOnline/online · GitHub should fix that. Testing appreciated - either way the warning is completely harmless.
