Failed to load Nextcloud office
Im using nextcloud and collabora behind an nginx proxy in a single docker network. I keep getting errors and cant connect collabora to nextcloud.
nginx.conf
server {
    listen 443 ssl http2;
    server_name office.${GLOBAL_DOMAIN};
    ssl_certificate /etc/letsencrypt/live/office.${GLOBAL_DOMAIN}/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/office.${GLOBAL_DOMAIN}/privkey.pem;
    ssl_session_timeout 1d;
    ssl_session_cache shared:MozSSL:10m;  # about 40000 sessions
    ssl_session_tickets off;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_prefer_server_ciphers off;
    add_header Strict-Transport-Security "max-age=63072000" always;
    ssl_stapling on;
    ssl_stapling_verify on;
    # main websocket
    location ~ ^/cool/(.*)/ws$ {
        proxy_pass http://collabora:9980;
        proxy_http_version 1.1;
        proxy_set_header Host $host;
        proxy_read_timeout 36000s;
    # # Admin Console websocket
    location ^~ /cool/adminws {
        proxy_buffering off;
    location / {
docker-compose.yml
version: '3.7'
        container_name: collabora
        image: collabora/code
        env_file:
            - /docker-nas/docker-templates/collabora/.env
            - TZ=America/New_York
            - 'extra_params=--o:ssl.enable=false --o:net.proto=IPv4 --o:ssl.termination=true --o:net.post_allow.host[0]=172\.[0-9\.]+ --o:storage.wopi.host[0]=172\.[0-9\.]+'
            - DONT_GEN_SSL_CERT=true
            - server_name=office.${GLOBAL_DOMAIN}
            - aliasgroup1=https://cloud\.example\.com:443
            - username=${GLOBAL_COLLABORA_USERNAME}
            - password=${GLOBAL_COLLABORA_PASSWORD}
        cap_add:
            - MKNOD
            - backend
        restart: unless-stopped
        privileged: true
errors
frk-00025-00025 2022-08-21 12:37:23.297835 -0400 [ forkit ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:400
wsd-00001-00033 2022-08-21 12:37:23.300058 -0400 [ docbroker_001 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| net/Socket.hpp:727
wsd-00001-00033 2022-08-21 12:37:23.300117 -0400 [ docbroker_001 ] ERR  #35: Read failed, have 0 buffered bytes (EPIPE: Broken pipe)| net/Socket.hpp:1133
wsd-00001-00033 2022-08-21 12:37:23.300195 -0400 [ docbroker_001 ] ERR  #35: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00033 2022-08-21 12:37:23.300226 -0400 [ docbroker_001 ] ERR  #35: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00033 2022-08-21 12:37:23.300331 -0400 [ docbroker_001 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2243
wsd-00001-00033 2022-08-21 12:37:23.300363 -0400 [ docbroker_001 ] ERR  Failed to add session to [https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli] with URI [https://cloud.example.com/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli?access_token=tokenhere&access_token_ttl=0]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2205
wsd-00001-00033 2022-08-21 12:37:23.300384 -0400 [ docbroker_001 ] ERR  Storage error while starting session on https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli for socket #30. Terminating connection. Error: WOPI::CheckFileInfo failed: | wsd/COOLWSD.cpp:4607
wsd-00001-00033 2022-08-21 12:37:23.300540 -0400 [ docbroker_001 ] ERR  Invalid or unknown session [013] to remove.| wsd/DocumentBroker.cpp:2288
wsd-00001-00029 2022-08-21 12:37:23.656351 -0400 [ websrv_poll ] WRN  DocBroker with docKey [https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli] is unloading. Rejecting client request to load.| wsd/COOLWSD.cpp:3157
wsd-00001-00029 2022-08-21 12:37:23.656443 -0400 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli].| wsd/COOLWSD.cpp:4637
wsd-00001-00029 2022-08-21 12:37:23.656457 -0400 [ websrv_poll ] ERR  #34: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00029 2022-08-21 12:37:23.656472 -0400 [ websrv_poll ] ERR  #34: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00029 2022-08-21 12:37:23.656478 -0400 [ websrv_poll ] WRN  #34 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| net/WebSocketHandler.hpp:826
wsd-00001-00029 2022-08-21 12:37:23.656491 -0400 [ websrv_poll ] ERR  #34: Attempted to remove: 919 which is > size: 0 clamped to 0| net/Socket.hpp:1234
wsd-00001-00029 2022-08-21 12:37:23.656510 -0400 [ websrv_poll ] ERR  #34: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00029 2022-08-21 12:37:24.120175 -0400 [ websrv_poll ] WRN  DocBroker with docKey [https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli] is unloading. Rejecting client request to load.| wsd/COOLWSD.cpp:3157
wsd-00001-00029 2022-08-21 12:37:24.120273 -0400 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli].| wsd/COOLWSD.cpp:4637
wsd-00001-00029 2022-08-21 12:37:24.120287 -0400 [ websrv_poll ] ERR  #34: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00029 2022-08-21 12:37:24.120300 -0400 [ websrv_poll ] ERR  #34: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00029 2022-08-21 12:37:24.120307 -0400 [ websrv_poll ] WRN  #34 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| net/WebSocketHandler.hpp:826
wsd-00001-00029 2022-08-21 12:37:24.120321 -0400 [ websrv_poll ] ERR  #34: Attempted to remove: 919 which is > size: 0 clamped to 0| net/Socket.hpp:1234
wsd-00001-00029 2022-08-21 12:37:24.120338 -0400 [ websrv_poll ] ERR  #34: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
Forced Exit with code: 70
wsd-00001-00024 2022-08-21 12:37:25.301189 -0400 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/COOLWSD.cpp:3242
kit-00027-00025 2022-08-21 12:37:25.301206 -0400 [ kit_spare_001 ] FTL  Forced Exit with code: 70| common/Util.cpp:1096
wsd-00001-00024 2022-08-21 12:37:25.301220 -0400 [ prisoner_poll ] WRN  An unassociated Kit disconnected.| wsd/COOLWSD.cpp:3257
wsd-00001-00024 2022-08-21 12:37:25.301238 -0400 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/COOLWSD.cpp:3242
wsd-00001-00024 2022-08-21 12:37:25.301244 -0400 [ prisoner_poll ] WRN  An unassociated Kit disconnected.| wsd/COOLWSD.cpp:3257
wsd-00001-00035 2022-08-21 12:37:26.173548 -0400 [ docbroker_002 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| net/Socket.hpp:727
wsd-00001-00035 2022-08-21 12:37:26.173601 -0400 [ docbroker_002 ] ERR  #35: Read failed, have 0 buffered bytes (EPIPE: Broken pipe)| net/Socket.hpp:1133
wsd-00001-00035 2022-08-21 12:37:26.173622 -0400 [ docbroker_002 ] ERR  #35: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00035 2022-08-21 12:37:26.173631 -0400 [ docbroker_002 ] ERR  #35: Socket write returned -1 (EPIPE: Broken pipe)| net/Socket.hpp:1431
wsd-00001-00035 2022-08-21 12:37:26.173712 -0400 [ docbroker_002 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2243
wsd-00001-00035 2022-08-21 12:37:26.173730 -0400 [ docbroker_002 ] ERR  Failed to add session to [https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli] with URI [https://cloud.example.com/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli?access_token=tokenhere&access_token_ttl=0&permission=edit]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2205
wsd-00001-00035 2022-08-21 12:37:26.173751 -0400 [ docbroker_002 ] ERR  Storage error while starting session on https://cloud.example.com:443/index.php/apps/richdocuments/wopi/files/936707_oczddki0ydli for socket #22. Terminating connection. Error: WOPI::CheckFileInfo failed: | wsd/COOLWSD.cpp:4607
wsd-00001-00035 2022-08-21 12:37:26.173887 -0400 [ docbroker_002 ] ERR  Invalid or unknown session [01d] to remove.| wsd/DocumentBroker.cpp:2288
frk-00025-00025 2022-08-21 12:37:26.271691 -0400 [ forkit ] WRN  The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/hosts] is out-of-date. Will have to copy sysTemplate to jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:400
Hitting https://office.exampe.com responds with OK so i can tell its working. Also the admin logs in but I never get any logs from that.
it looks your Collabora can’t reach Nextcloud using the URL above.
Nextcloud provides good troubleshooting guide:
https://docs.nextcloud.com/server/latest/admin_manual/office/troubleshooting.html
This is a good link. Thank you. Going to take a look later tonight. It would be odd that it cant reach nextcloud as i have been using it for years. But it may be some internal container network stuff going on
Ok so i took a look at the doc, Im writting down the commands i used so that it may help others. I already sorta knew it would be collabora trying to reach nextcloud as you mentioned so i skipped checking the other way around.
docker exec -it collabora bash
 curl -v https://cloud.example.com/status.php
*   Trying 172.33.0.10...
* TCP_NODELAY set
* connect to 172.33.0.10 port 443 failed: Connection refused
* Failed to connect to cloud.example.com port 443: Connection refused
* Closing connection 0
curl: (7) Failed to connect to cloud.example.com port 443: Connection refused
This means its trying to connect internally and bypassing the nginx container which handles ssl on 443. Just have to find a way to make it route through nginx in the container.
I have figured it out I actually had hostname: cloud.example.com in the nextcloud compose and it was using that internally instead of routing out through nginx. I removed that and it now works.
I’m not using Docker but I have the same issue. First of all my system wasn’t resolving cloud.example.com (who knew - Ha). I changed /etc/hosts to accept and resolve it to 127.0.2.1 which it did but now i’m throwing a 404 error. What’s the real fix for this?
The trouble shooting guide doesn’t go into this specific error.
Thanks for your help in advance.
Nextcloud Office works btw. The error is just disturbing me because it keeps showing up in the logging file
