So when I try to go to https://collabora.example.net, it doesn’t connect. And even if I try going to https://:9980, it doesn’t connect either. Nextcloud can’t see it either. Any ideas on what I’m doing wrong?
image: collabora/code:latest
restart: always
container_name: collabora
privileged: true
- 0.0.0.0:9980:9980
- collabora
- aliasgroup1='https://collabora.example.net,https://collabora\\.example\\.net'
- aliasgroup2='http://collabora'
- aliasgroup3='https://collabora'
- server_name=collabora
- DONT_GEN_SSL_CERT=1
- username=admin
- password=pass
- dictionaries=en_US
- TZ=America/New_York
cap_add:
- MKNOD
- SYS_ADMIN
- /mnt/wd1/collabora/coolwsd/:/etc/coolwsd/:rw
Caddy Config:
collabora.example.net {
tls internal
reverse_proxy collabora:9980
I see the following in the logs. Please let me know if you need more logs. I tried googling the “Poco::SyntaxException” error but I couldn’t find anything:
collabora | 2025-05-21T12:17:30.822202741Z preload: merged xmlsecurity ucpchelp1 wpftwriter wpftcalc wpftimpress wpftdraw msforms cached1 vbaswobj swd sw ucppkg1 sm msword slideshow pdfimport sdui sd scriptframe protocolhandler dlgprov solver pricing date vbaobj scd sc ucpdav1 pcr pdffilter ldapbe2 log migrationoo2 sdd deploymentgui smd cui dbase animcore t602filter flash flat PresentationMinimizer invocation stocservices acc sw_writerfilter io reflection uuresolver bootstrap scn dba calc sdbt dbaxml dbpool2 scfilt introspection mysql_jdbc cairocanvas writer binaryurp LanguageTool bib storagefd namingservice svgfilter graphicfilter ucpcmis1 analysis migrationoo3 invocadapt mozbootstrap hwp textconversiondlgs proxyfac
collabora | 2025-05-21T12:17:30.822245452Z Disabled: cmdmail rptxml rptui rpt dbp dbu abp odbc sdbc2
collabora | 2025-05-21T12:17:30.996549632Z Preload textencodings
collabora | 2025-05-21T12:17:31.001298998Z Allowlisted languages: en_US
collabora | 2025-05-21T12:17:31.028378079Z Preloading local dictionaries: en-US
collabora | 2025-05-21T12:17:31.044262913Z Preloading local thesauri: en-US
collabora | 2025-05-21T12:17:31.049823632Z Preloading local hyphenators: en-US
collabora | 2025-05-21T12:17:31.049845799Z Preloading breakiterator
collabora | 2025-05-21T12:17:31.050290806Z Preload icons
collabora | 2025-05-21T12:17:31.056049110Z Preload short cut accelerators
collabora | 2025-05-21T12:17:31.114159553Z Preload languages
collabora | 2025-05-21T12:17:31.148076908Z Preload fonts
collabora | 2025-05-21T12:17:31.149488737Z Fontconfig error: Cannot load default config file: No such file: (null)
collabora | 2025-05-21T12:17:31.194176752Z Preload config
collabora | 2025-05-21T12:17:31.346987167Z frk-00010-00010 2025-05-21 08:17:30.383471 -0400 [ coolforkit-ns ] TRC dlopen(/opt/collaboraoffice/program/libmergedlo.so, RTLD_GLOBAL|RTLD_NOW)| kit/Kit.cpp:4105
collabora | 2025-05-21T12:17:31.347007322Z frk-00010-00010 2025-05-21 08:17:30.409463 -0400 [ coolforkit-ns ] TRC Invoking lok_preinit_2(/opt/collaboraoffice/program", "file:///tmp/user")| kit/Kit.cpp:4162
collabora | 2025-05-21T12:17:31.347021189Z frk-00010-00010 2025-05-21 08:17:31.346771 -0400 [ coolforkit-ns ] DBG After lok_preinit_2: loKitPtr=0x3f8ac100| kit/Kit.cpp:4171
collabora | 2025-05-21T12:17:31.347024530Z frk-00010-00010 2025-05-21 08:17:31.346790 -0400 [ coolforkit-ns ] TRC Finished lok_preinit(/opt/collaboraoffice/program", "file:///tmp/user") in 937ms| kit/Kit.cpp:4173
collabora | 2025-05-21T12:17:31.347027507Z frk-00010-00010 2025-05-21 08:17:31.346830 -0400 [ coolforkit-ns ] INF Setting up systemplate dynamic files in [/opt/cool/systemplate].| common/JailUtil.cpp:521
collabora | 2025-05-21T12:17:31.347030224Z frk-00010-00010 2025-05-21 08:17:31.346838 -0400 [ coolforkit-ns ] INF Updating systemplate dynamic files in [/opt/cool/systemplate]| common/JailUtil.cpp:550
collabora | 2025-05-21T12:17:31.347033881Z frk-00010-00010 2025-05-21 08:17:31.346861 -0400 [ coolforkit-ns ] DBG File contents mismatch: [/opt/cool/systemplate//etc/passwd] exists, 883 bytes, modified at 1747344330 =/= [/etc/passwd]: exists, 885 bytes, modified at 1747344335| common/FileUtil.hpp:329
collabora | 2025-05-21T12:17:31.347037605Z frk-00010-00010 2025-05-21 08:17:31.346867 -0400 [ coolforkit-ns ] INF No write access to path [/opt/cool/systemplate]: Permission denied| common/FileUtil-unix.cpp:450
collabora | 2025-05-21T12:17:31.347040463Z frk-00010-00010 2025-05-21 08:17:31.346872 -0400 [ coolforkit-ns ] WRN The systemplate directory [/opt/cool/systemplate] is read-only, and at least [/opt/cool/systemplate//etc/passwd] is out-of-date. Will have to clone dynamic elements of systemplate to the jails. To restore optimal performance, make sure the files in [/opt/cool/systemplate/etc] are up-to-date.| common/JailUtil.cpp:586
collabora | 2025-05-21T12:17:31.347043612Z frk-00010-00010 2025-05-21 08:17:31.346874 -0400 [ coolforkit-ns ] WRN Failed to update the dynamic files in [/opt/cool/systemplate]. Will clone dynamic elements of systemplate to the jails.| common/JailUtil.cpp:529
collabora | 2025-05-21T12:17:31.347047566Z frk-00010-00010 2025-05-21 08:17:31.346880 -0400 [ coolforkit-ns ] INF Systemplate dynamic files in [/opt/cool/systemplate] will be copied to keep them up-to-date.| common/JailUtil.cpp:542
collabora | 2025-05-21T12:17:31.347050404Z frk-00010-00010 2025-05-21 08:17:31.346886 -0400 [ coolforkit-ns ] DBG Linking symbolically [/opt/cool/systemplate/dev/random] to [../tmp/dev/random].| common/JailUtil.cpp:670
collabora | 2025-05-21T12:17:31.347053066Z frk-00010-00010 2025-05-21 08:17:31.346890 -0400 [ coolforkit-ns ] TRC Random device link [/opt/cool/systemplate/dev/random] already exists.| common/JailUtil.cpp:678
collabora | 2025-05-21T12:17:31.347285603Z terminate called after throwing an instance of 'Poco::SyntaxException'
collabora | 2025-05-21T12:17:31.347305475Z what(): Syntax error
collabora | 2025-05-21T12:17:31.347308873Z frk-00010-00010 2025-05-21 08:17:31.347226 -0400 [ coolforkit-ns ] SIG Fatal signal received: SIGABRT code: 18446744073709551610 for address: 0x3e90000000a
collabora | 2025-05-21T12:17:31.347311517Z Recent activity:
collabora | 2025-05-21T12:17:31.347313752Z
collabora | 2025-05-21T12:17:31.347315894Z Backtrace 10 - forkit startup of 25.04.2.1 0968141f2c:
collabora | 2025-05-21T12:17:31.347412179Z /usr/bin/coolforkit-ns(_ZN7SigUtil13dumpBacktraceEv+0x73)[0x63d503]
