Opening office documents sometimes fails
Hello
I am running a Nextcloud server with multiple DNS aliases. When users try to open office documents this sometimes fails with the error message “Document loading failed”. In the console I see the following error message:
Content-Security-Policy: The page’s settings blocked the loading of a resource (form-action) at https://dns-alias-1.tld/apps/richdocumentscode/proxy.php?req=/browser/xxx/cool.html?WOPISrc=https%3A%2F%2Fdns-alias-2.tld%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F....odt&lang=en&closebutton=1&revisionhistory=1 because it violates the following directive: “form-action ‘self’ https://dns-alias-2.tld”
In the Network tab of the webdeveloper tools I do not see a call to the URL mentioned above.
When connecting to Nextcloud with one DNS alias why are documents loaded from another DNS alias? Is there any way to fix this?
Hello @uli-a i see there are some configuration issues.
  • The error occurs because the document is being accessed from https://dns-alias-1.tld, but the form action is trying to submit to https://dns-alias-2.tld.
  • The CSP rule allows form submissions only to https://dns-alias-2.tld and self, which in this context would mean https://dns-alias-1.tld. However, since self is https://dns-alias-1.tld, but the form is targeting https://dns-alias-2.tld, the browser blocks the request as a security measure.
  • Why This Happens:
    • This typically occurs when Nextcloud and Collabora Online are accessed via different DNS aliases, and there is an inconsistency in how they handle or route the requests.
    • For instance, if a user accesses Nextcloud at https://dns-alias-1.tld and then tries to open a document, the request might be redirected to https://dns-alias-2.tld for the document processing (WOPI) by Collabora Online, triggering the CSP violation.
I would suggest if you should read this Multihost Configuration (Configuration — SDK https://sdk.collaboraonline.com/ documentation) this will help.
Collabora Online Configuration:
  • Update the coolwsd.xml or loolwsd.xml file on your Collabora server to handle multiple DNS aliases properly. Ensure the host settings cover all the aliases you’re using.
  • Make sure the frame_ancestors directive allows both DNS aliases if they are embedded in iframes.
Thanks for the very elaborate answer.
I am using the build-in CODE server of Nextcloud and did not find the configuration files you mentioned (coolwsd.xml/loolwsd.xml). Is there a way to do this for the build-in server as well?
@uli-a I see you are using build in.
So In your Nextcloud config.php, you can specify the overwritehost and overwriteprotocol settings to ensure consistent URLs are used, preventing such mismatches.
https://docs.nextcloud.com/server/21/admin_manual/configuration_server/reverse_proxy_configuration.html?highlight=overwrite#overwrite-parameters
Until you check your config file, I’ll continue digging through articles to see if this issue is mentioned or if there is a workaround available.
@uli-a i found something in NC
forum Refused to send form data to .. because it violates the following Content Security Policy directive: "form-action 'self'" - 📄 Collabora - Nextcloud community
