OpenPGP check for package collaboraofficebasis-core-debuginfo failed
Greetings
I am trying to install CODE on Fedora, it has been working fine, but recently I am getting an issue
Running transaction
Transaction failed: Signature verification failed.
OpenPGP check for package "collaboraofficebasis-core-debuginfo-25.04.5-2.x86_64" (/var/cache/libdnf5/collaboraoffice.com_repos_CollaboraOnline_CODE-rpm-5e756a15490e7c5f/packages/collaboraofficebasis-core-debuginfo-25.04.5-2.x86_64.rpm) from repo "collaboraoffice.com_repos_CollaboraOnline_CODE-rpm" has failed: The package is not signed
I followed this post New repository signing keys , to import the new key, but still no luck.
hiii @elhananjair
Check this two recent post
If you’re running Collabora Online as a separate service (e.g., on the same server or another server) installed using .deb or .rpm packages, then yes, you need to update the PGP key to continue receiving updates properly from the Collabora repository.
I have installed CODE using the CODE-rpm repo therefore updating the key is mandatory and I did that, the problem is as I mentioned on the post specific package is causing the issue, I am installing the packages using this command:
sudo dnf install coolwsd CODE-brand collaboraoffice*
sudo dnf install coolwsd CODE-brand just works fine, but the problem is with collaboraoffice*
