Read certs erorros
Hi, I’ve this error:
SSL context exception: Error loading private key from file /etc/loolwsd/privatekey.pem: error:0200100D:system library:fopen:Permission denied
How can I fix?
I’ve to change user permission .pem to lool ?
Yes, lool user needs the permission to be able to load the private key.
Thank you
Can I use the same collabora internal server for nextcloud and other integrations?
Yes, as long as the Collabora Online server can handle the usage, it can serve multiple file hosts it’s integrated with.
