* Present
+ Gokay, Michael, Miklos
* Found the UI readonly option
+ can set the UI to readonly
+ if it is readonly currently
+ edit view needs to be set to readonly.
+ set - if a view performs an action
+ readonly UI
+ listeners are disabled
+ enabled when the mode is added again.
+ couldn't use a global variable
* What about the comment-only semantic ?
+ readonly UI - doesn't allow you to edit
* coolwsd crash
AI: + fix this as a priority- it should never crash
+ if it's a debugging assert: ok perhaps.
+ should shut connections to the Kit
if necessary and kill it if we get
suspicious stuff.
* table re-sizing:
AI: + Poke at the SDI files to ensure that the
related UNO commands are set right for
readonly mode
* readonly mode
AI: + wsd/ClientSession.cpp - event filtering:
+ should retain much of this on top of
readonly mode
+ only allow through:
+ mouse move & click events
+ arrow keys + modifiers for
keyboard movement / selection
+ expect 'Copy' to go through
UNO commands - allow that too
if copy is not disabled.
+ we should push through the 'can comment'
permission into readonly mode in LOK core
* core problems:
+ with one readonly view - can't select shapes
+ since one disables it, and another doens't enable it again.
+ we should assume that the setReadOnlyView thing is called
just once at constrution or the earliest time we make something.
+ perhaps we should use:
kit/Kit.cpp: _loKitDocument->createView(options.c_str());
+ so this state is all present as we
create the SfxViewFoo.
* Performance:
+ 'mode changed' event is broadcasted on the core side
+ disabling and enabling listening to some events
+ concerned about this
+ we badly want to set the ReadOnly option once at
view creation, and then not again.
+ certainly at view strobing time.
+ need to do some QA / test of where readonly-ness is checked.
+ SwViewShell is not shared
=> no problem.
+ SfxObjectShell is shared
+ using the same pointer.
+ hits the drawing-layer stuff ...
AI: + SfxObjectShell::SetReadOnlyUI should not be called with 'true'
+ ObjectShell should be read-write.
+ SfxViewShells - should be readonly-only (or not)
AI: + add a permissions enum: ReadWrite, CanComment, ReadOnly
2 and thread it through everywhere.
AI: + need to switch call-sites that fetch read-only-ness
to not use SfxObjectShell instead ask it to the SfxViewShell (Gokay)
AI: + Audit listeners listening to ModeChanged to ensure they
filter in the callbacks in readonly mode.
$ git grep SfxHintId::ModeChanged
+ 8 hits
$ git grep on.*ModeChanged
+ 6 hits outside the IDE
* Keeping the model read-write
+ avoids complexity with SfxMedium and associated horrors =)
* Target this for 24.04
+ not merging this into 23.05
