Nextcloud says to add this in truenas scale. I am not sure how to do this.
Make sure to set this URL: https://nextcloud.xxxxxxxxxxxxxxx.com/apps/richdocuments/settings/fonts.json in the coolwsd.xml file of your Collabora Online server to ensure the added fonts get loaded automatically. Please note that http:// will only work for debug builds of Collabora Online. In production you must use https:// for remote font config.
<remote_font_config>
</remote_font_config>
Thank you for any and all help
Hello @rpohl67 welcome to the collabora online forum
How to Add Fonts to Collabora in TrueNAS SCALE:
Open Shell in Collabora App from TrueNAS SCALE UI (Apps → Collabora → ⋮ → Shell).
Edit config:
Run:
nano /etc/coolwsd/coolwsd.xml
Add inside <config>:
https://nextcloud.yourdomain.com/apps/richdocuments/settings/fonts.json
Restart Collabora:
supervisordctl restart coolwsd
Verify: Visit the URL in your browser to confirm fonts.json is served.
It says nano is not installed. Is there a way to install it in the collabora shell. Thank you
Use vi Instead of nano:
Once you’re in the Collabora container shell, run:
vi /etc/coolwsd/coolwsd.xml
It says the same thing VI not found. Thank you
