Apt returns Forbidden [IP: 46.235.227.219 443] on code install
I used this site Setting up and configuring native CODE packages on Linux - Collabora Office and Collabora Online to install the CODE packages, but the server only returns 403
Is this page outdated? temporary failure on the repo? I do somthing wrong? any idea? :slight_smile:
root@test001 ~ apt install coolwsd code-brand
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  collaboraoffice collaboraoffice-ure collaboraofficebasis-calc collaboraofficebasis-core collaboraofficebasis-draw collaboraofficebasis-en-us collaboraofficebasis-extension-pdf-import
  collaboraofficebasis-graphicfilter collaboraofficebasis-images collaboraofficebasis-impress collaboraofficebasis-math collaboraofficebasis-ooofonts collaboraofficebasis-ooolinguistic
  collaboraofficebasis-writer cpio expat fontconfig fontconfig-config fonts-dejavu-core libfontconfig1 libfreetype6 libpng16-16
Suggested packages:
  libarchive1
The following NEW packages will be installed:
  code-brand collaboraoffice collaboraoffice-ure collaboraofficebasis-calc collaboraofficebasis-core collaboraofficebasis-draw collaboraofficebasis-en-us
  collaboraofficebasis-extension-pdf-import collaboraofficebasis-graphicfilter collaboraofficebasis-images collaboraofficebasis-impress collaboraofficebasis-math collaboraofficebasis-ooofonts
  collaboraofficebasis-ooolinguistic collaboraofficebasis-writer coolwsd cpio expat fontconfig fontconfig-config fonts-dejavu-core libfontconfig1 libfreetype6 libpng16-16
0 upgraded, 24 newly installed, 0 to remove and 0 not upgraded.
Need to get 222 MB/235 MB of archives.
After this operation, 741 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraoffice-ure 22.05.5-3
  403  Forbidden [IP: 46.235.227.219 443]
Err:2 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-ooofonts 22.05.5-3
Err:3 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-core 22.05.5-3
Err:4 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-calc 22.05.5-3
Err:5 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-graphicfilter 22.05.5-3
Err:6 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-images 22.05.5-3
Err:7 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-impress 22.05.5-3
Err:8 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-writer 22.05.5-3
Err:9 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraoffice 22.05.5-3
Err:10 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-en-us 22.05.5-3
Err:11 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-draw 22.05.5-3
Err:12 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-extension-pdf-import 22.05.5-3
Err:13 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-ooolinguistic 22.05.5-3
Err:14 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-math 22.05.5-3
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraoffice-ure_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-ooofonts_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-core_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-calc_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-graphicfilter_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-images_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-impress_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-writer_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraoffice_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-en-us_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-draw_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-extension-pdf-import_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-ooolinguistic_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-math_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@test001 ~
/etc/apt/sources.list.d/collaboraonline.sources
Types: deb
URIs: https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11
Suites: ./
Signed-By: /usr/share/keyrings/collaboraonline-release-keyring.gpg
I have the same Problem:
The following packages will be upgraded:
   code-brand (22.05-13 => 22.05-14)
   collaboraoffice (22.05.5-2 => 22.05.5-3)
   collaboraoffice-dict-de (22.05.5-2 => 22.05.5-3)
   collaboraoffice-ure (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-calc (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-core (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-de (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-draw (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-en-us (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-extension-pdf-import (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-graphicfilter (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-images (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-impress (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-math (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-ooofonts (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-ooolinguistic (22.05.5-2 => 22.05.5-3)
   collaboraofficebasis-writer (22.05.5-2 => 22.05.5-3)
   coolwsd (22.05.5.2-1 => 22.05.5.3-1)
18 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 231 MB/240 MB of archives.
After this operation, 9,216 B of additional disk space will be used.
Err:1 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraoffice-dict-de 22.05.5-3
Err:2 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraoffice 22.05.5-3
Err:3 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-writer 22.05.5-3
Err:4 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-ooolinguistic 22.05.5-3
Err:5 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-math 22.05.5-3
Err:6 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-impress 22.05.5-3
Err:7 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-images 22.05.5-3
Err:8 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-graphicfilter 22.05.5-3
Err:9 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-extension-pdf-import 22.05.5-3
Err:12 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-de 22.05.5-3
Err:13 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-calc 22.05.5-3
Err:14 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-core 22.05.5-3
Err:15 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraoffice-ure 22.05.5-3
Err:16 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11 ./ collaboraofficebasis-ooofonts 22.05.5-3
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraoffice-dict-de_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-debian11/./collaboraofficebasis-de_22.05.5-3_amd64.deb  403  Forbidden [IP: 46.235.227.219 443]
Types: deb
Suites: ./
i have the same problem on ubuntu 18.04, but i got an upgrade for coolwsd and code-brand pulled in. After that my collabora server didn’t work anymore, i had to go back to the old versions.
I’m encountering the same problem with the latest apt package updates on Ubuntu 20.04 on 13/08/2022.
When I logged into my server and did apt update && apt upgrade, I couldn’t get the updates. For each package, I’m getting messages such as:
E: Failed to fetch https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-writer_22.05.5-3_amd64.deb 403 Forbidden [IP: 46.235.227.219 443]
how did you do that? Currently I have no connection to the repo
the old packages should be here:
/var/cache/apt/archives/
apt install /var/cache/apt/archives/collaboraofficebasis-calc_21.06.13-1_amd64.deb
for example.
Same here,
I can’t update the packages.
Hello, I’m having the same issue with an IPv6 address on Ubuntu 20.04
(Fehl = Error , Fehlschlag beim Holen von = Error fetching)
Fehl:1 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraoffice-ure 22.05.5-3
  403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
Fehl:2 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-ooofonts 22.05.5-3
Fehl:3 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-core 22.05.5-3
Fehl:4 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-calc 22.05.5-3
Fehl:5 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-graphicfilter 22.05.5-3
Fehl:6 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-images 22.05.5-3
Fehl:7 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-impress 22.05.5-3
Fehl:8 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-writer 22.05.5-3
Fehl:9 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraoffice 22.05.5-3
Fehl:10 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-en-us 22.05.5-3
Fehl:11 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-draw 22.05.5-3
Fehl:12 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-extension-pdf-import 22.05.5-3
Fehl:13 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-ooolinguistic 22.05.5-3
Fehl:14 https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004 ./ collaboraofficebasis-math 22.05.5-3
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraoffice-ure_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-ooofonts_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-core_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-calc_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-graphicfilter_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-images_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-impress_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-writer_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraoffice_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-en-us_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-draw_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-extension-pdf-import_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-ooolinguistic_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
E: Fehlschlag beim Holen von https://www.collaboraoffice.com/repos/CollaboraOnline/CODE-ubuntu2004/./collaboraofficebasis-math_22.05.5-3_amd64.deb 403  Forbidden [IP: 2a00:1098:0:82:1000:25:2eeb:e3db 443]
Ben
the update has now run through
but since the update it does not work with nextcloudintegration.
But the service is running.
I’ve installed it 30 minutes ago in an lxc container with nginx as reverse proxy, works as expected.
Yes, the repositories have been fixed, thanks for the patience!
