CODE 6.4.10_Docker - Nextcloud (Not working)
Hello, I upgraded CODE docker to 6.4.10 in my Unraid system and after that I can’t open any files within nextcloud webui. Rolling back to 6.4.9.3 Docker, works again.
When i try to open a file, in collabora’s docker log I get the following error
wsd-00007-00052 2021-07-03 06:27:50.458709 [ docbroker_001 ] WRN Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00007-00052 2021-07-03 06:27:50.458841 [ docbroker_001 ] ERR Socket #31 SSL BIO error: closed unexpectedly (-1). (0: Success)| ./net/SslSocket.hpp:294
wsd-00007-00052 2021-07-03 06:27:50.458886 [ docbroker_001 ] ERR Error while handling poll for socket #31 in HttpSynReqPoll: SSL Socket closed unexpectedly.| net/Socket.cpp:356
wsd-00007-00052 2021-07-03 06:27:50.458930 [ docbroker_001 ] ERR WOPI::CheckFileInfo failed for URI [https://cloud.MYDOMAIN.me/index.php/apps/richdocuments/wopi/files/1202030_HASH?access_token=TOKEN1&access_token_ttl=0]: 0 . Headers: Body: []| wsd/Storage.cpp:723
wsd-00007-00052 2021-07-03 06:27:50.458971 [ docbroker_001 ] ERR loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00007-00052 2021-07-03 06:27:50.458988 [ docbroker_001 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/1202030_HASH] with URI [https://cloud.MYDOMAIN.me/index.php/apps/richdocuments/wopi/files/1202030_HASH?access_token=TOKEN1&access_token_ttl=0]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00007-00052 2021-07-03 06:27:50.461094 [ docbroker_001 ] ERR No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-002| wsd/ClientSession.cpp:348
wsd-00007-00052 2021-07-03 06:27:50.461159 [ docbroker_001 ] ERR No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-002| wsd/ClientSession.cpp:348
wsd-00007-00052 2021-07-03 06:27:50.592531 [ docbroker_001 ] ERR Socket #26 SSL BIO error: error:140E0197:SSL routines:SSL_shutdown:shutdown while in init (0: Success)| ./net/SslSocket.hpp:307
wsd-00007-00052 2021-07-03 06:27:50.592622 [ docbroker_001 ] ERR Error while handling poll for socket #26 in docbroker_001: error:140E0197:SSL routines:SSL_shutdown:shutdown while in init| net/Socket.cpp:356
wsd-00007-00052 2021-07-03 06:27:50.592671 [ docbroker_001 ] ERR Invalid or unknown session [002] to remove.| wsd/DocumentBroker.cpp:1893
wsd-00007-00052 2021-07-03 06:27:50.592688 [ docbroker_001 ] ERR No socket associated with WebSocketHandler 0x14977c010280 to send Close Frame to.| ./net/WebSocketHandler.hpp:176
wsd-00007-00045 2021-07-03 06:27:52.459247 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
wsd-00007-00060 2021-07-03 06:28:24.517096 [ docbroker_002 ] WRN Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00007-00060 2021-07-03 06:28:24.517260 [ docbroker_002 ] ERR Socket #31 SSL BIO error: closed unexpectedly (-1). (0: Success)| ./net/SslSocket.hpp:294
wsd-00007-00060 2021-07-03 06:28:24.517332 [ docbroker_002 ] ERR Error while handling poll for socket #31 in HttpSynReqPoll: SSL Socket closed unexpectedly.| net/Socket.cpp:356
wsd-00007-00060 2021-07-03 06:28:24.517437 [ docbroker_002 ] ERR WOPI::CheckFileInfo failed for URI [https://cloud.MYDOMAIN.me/index.php/apps/richdocuments/wopi/files/1202030_HASH?access_token=TOKEN2&access_token_ttl=0]: 0 . Headers: Body: []| wsd/Storage.cpp:723
wsd-00007-00060 2021-07-03 06:28:24.517516 [ docbroker_002 ] ERR loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00007-00060 2021-07-03 06:28:24.517543 [ docbroker_002 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/1202030_HASH] with URI [https://cloud.MYDOMAIN.me/index.php/apps/richdocuments/wopi/files/1202030_HASH?access_token=TOKEN2&access_token_ttl=0]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00007-00060 2021-07-03 06:28:24.517637 [ docbroker_002 ] ERR No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-004| wsd/ClientSession.cpp:348
wsd-00007-00060 2021-07-03 06:28:24.517721 [ docbroker_002 ] ERR No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-004| wsd/ClientSession.cpp:348
wsd-00007-00060 2021-07-03 06:28:24.521094 [ docbroker_002 ] ERR Socket #22 SSL BIO error: error:140E0197:SSL routines:SSL_shutdown:shutdown while in init (0: Success)| ./net/SslSocket.hpp:307
wsd-00007-00060 2021-07-03 06:28:24.521189 [ docbroker_002 ] ERR Error while handling poll for socket #22 in docbroker_002: error:140E0197:SSL routines:SSL_shutdown:shutdown while in init| net/Socket.cpp:356
wsd-00007-00060 2021-07-03 06:28:24.521234 [ docbroker_002 ] ERR Invalid or unknown session [004] to remove.| wsd/DocumentBroker.cpp:1893
wsd-00007-00060 2021-07-03 06:28:24.521250 [ docbroker_002 ] ERR No socket associated with WebSocketHandler 0x14977c00fe40 to send Close Frame to.| ./net/WebSocketHandler.hpp:176
wsd-00007-00045 2021-07-03 06:28:26.517990 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
On NC shows the following message,
This is my docker run command
docker run -d --name='Collabora' --net='bridge' --privileged=true -e TZ="Europe/Athens" -e HOST_OS="Unraid" -e 'domain'='cloud\.DOMAIN\.me|test\.DOMAIN\.me' -e 'username'='admin' -e 'password'='PASSWORD' -e 'server_name'='collabora\.DOMAIN\.me' -e 'dictionaries'='en_US el_GR' -e 'extra_params'='-o:welcome.enable=false -o:user_interface.mode=notebookbar -o:ssl.termination=true' -p '9980:9980/tcp' -v '/etc/localtime':'/etc/localtime':'ro' 'collabora/code'
NC Ver: 21.0.3
NC Collabora App: 4.1.2
If there is any more info you might need, let me know.
CODE 6.4.10.2 released overnight hasn’t fixed the issue though the log does show something different now.
wsd-00007-00043 2021-07-05 05:23:05.485654 [ websrv_poll ] WRN  Skipping the token [--co-primary-text= #ffffff] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.486483 [ websrv_poll ] WRN  Skipping the token [--co-primary-element= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.487078 [ websrv_poll ] WRN  Skipping the token [--co-text-accent= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.487377 [ websrv_poll ] WRN  Skipping the token [--co-primary-element-light= #17adff] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.487833 [ websrv_poll ] WRN  Skipping the token [--co-color-error= #e9322d] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.488213 [ websrv_poll ] WRN  Skipping the token [--co-color-warning= #eca700] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.488579 [ websrv_poll ] WRN  Skipping the token [--co-color-success= #46ba61] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.488996 [ websrv_poll ] WRN  Skipping the token [--co-border-radius= 3px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.489462 [ websrv_poll ] WRN  Skipping the token [--co-border-radius-large= 10px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.489839 [ websrv_poll ] WRN  Skipping the token [--co-loading-light= #ccc] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.490303 [ websrv_poll ] WRN  Skipping the token [--co-loading-dark= #444] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.490753 [ websrv_poll ] WRN  Skipping the token [--co-box-shadow= rgba(77, 77, 77, 0.5)] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.491242 [ websrv_poll ] WRN  Skipping the token [--co-border= #ededed] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.491679 [ websrv_poll ] WRN  Skipping the token [--co-border-dark= #dbdbdb] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-05 05:23:05.491905 [ websrv_poll ] WRN  Skipping the token [--co-border-radius-pill= 100px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00046 2021-07-05 05:23:05.659548 [ docbroker_001 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00007-00046 2021-07-05 05:23:05.661156 [ docbroker_001 ] ERR  Socket #32 SSL BIO error: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error (0: Success)| ./net/SslSocket.hpp:307
wsd-00007-00046 2021-07-05 05:23:05.661834 [ docbroker_001 ] ERR  Error while handling poll for socket #32 in HttpSynReqPoll: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error| net/Socket.cpp:356
wsd-00007-00046 2021-07-05 05:23:05.662399 [ docbroker_001 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h?access_token=Ai3c5xa4u5AZp8op6fMWp3UiswYj1Noq&access_token_ttl=0]: 0 . Headers:     Body: []| wsd/Storage.cpp:723
wsd-00007-00046 2021-07-05 05:23:05.662880 [ docbroker_001 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00007-00046 2021-07-05 05:23:05.663306 [ docbroker_001 ] ERR  Failed to add session to [/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h] with URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h?access_token=Ai3c5xa4u5AZp8op6fMWp3UiswYj1Noq&access_token_ttl=0]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00007-00046 2021-07-05 05:23:05.663973 [ docbroker_001 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-002| wsd/ClientSession.cpp:348
wsd-00007-00046 2021-07-05 05:23:05.664382 [ docbroker_001 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-002| wsd/ClientSession.cpp:348
wsd-00007-00046 2021-07-05 05:23:05.664863 [ docbroker_001 ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00046 2021-07-05 05:23:05.665341 [ docbroker_001 ] ERR  Invalid or unknown session [002] to remove.| wsd/DocumentBroker.cpp:1893
wsd-00007-00043 2021-07-05 05:23:05.906432 [ websrv_poll ] WRN  DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2144
wsd-00007-00043 2021-07-05 05:23:05.906811 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h].| wsd/LOOLWSD.cpp:3613
wsd-00007-00043 2021-07-05 05:23:05.906830 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-05 05:23:05.906848 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-05 05:23:05.906854 [ websrv_poll ] WRN  Socket #27 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:764
wsd-00007-00043 2021-07-05 05:23:05.906864 [ websrv_poll ] ERR  #27: attempted to remove: 936 which is > size: 0 clamped to 0| ./net/Socket.hpp:1091
wsd-00007-00043 2021-07-05 05:23:05.906880 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-05 05:23:07.160019 [ websrv_poll ] WRN  DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2144
wsd-00007-00043 2021-07-05 05:23:07.160467 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h].| wsd/LOOLWSD.cpp:3613
wsd-00007-00043 2021-07-05 05:23:07.160572 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-05 05:23:07.160961 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-05 05:23:07.161007 [ websrv_poll ] WRN  Socket #27 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:764
wsd-00007-00043 2021-07-05 05:23:07.161236 [ websrv_poll ] ERR  #27: attempted to remove: 936 which is > size: 0 clamped to 0| ./net/Socket.hpp:1091
wsd-00007-00043 2021-07-05 05:23:07.161803 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00038 2021-07-05 05:23:07.665194 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
wsd-00007-00047 2021-07-05 05:23:08.205549 [ docbroker_002 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00007-00047 2021-07-05 05:23:08.207556 [ docbroker_002 ] ERR  Socket #30 SSL BIO error: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error (0: Success)| ./net/SslSocket.hpp:307
wsd-00007-00047 2021-07-05 05:23:08.207683 [ docbroker_002 ] ERR  Error while handling poll for socket #30 in HttpSynReqPoll: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error| net/Socket.cpp:356
wsd-00007-00047 2021-07-05 05:23:08.207986 [ docbroker_002 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h?access_token=Ai3c5xa4u5AZp8op6fMWp3UiswYj1Noq&access_token_ttl=0&permission=edit]: 0 . Headers:     Body: []| wsd/Storage.cpp:723
wsd-00007-00047 2021-07-05 05:23:08.208597 [ docbroker_002 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00007-00047 2021-07-05 05:23:08.208676 [ docbroker_002 ] ERR  Failed to add session to [/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h] with URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334210_ocosbn1u1n1h?access_token=Ai3c5xa4u5AZp8op6fMWp3UiswYj1Noq&access_token_ttl=0&permission=edit]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00007-00047 2021-07-05 05:23:08.209652 [ docbroker_002 ] ERR  #25: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00047 2021-07-05 05:23:08.209966 [ docbroker_002 ] ERR  Invalid or unknown session [005] to remove.| wsd/DocumentBroker.cpp:1893
sh: 1: /usr/bin/loolmount: Operation not permitted
frk-00039-00039 2021-07-05 05:23:08.235491 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/ljKt4c6lafHM5z20/tmp].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-05 05:23:08.261254 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/ljKt4c6lafHM5z20/lo].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-05 05:23:08.287959 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/ljKt4c6lafHM5z20].| common/JailUtil.cpp:68
wsd-00007-00038 2021-07-05 05:23:10.210246 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
frk-00039-00039 2021-07-05 05:23:10.459405 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/ZMvDNwSmVmxk1qSH/tmp].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-05 05:23:10.486059 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/ZMvDNwSmVmxk1qSH/lo].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-05 05:23:10.514813 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/ZMvDNwSmVmxk1qSH].| common/JailUtil.cpp:68
This is what appears briefly in NC…
nc04
I’m also on NC 21.0.3 running in a FreeBSD 12.2 jail. I’ve rolled back to the CODE image with tag version 6.4.9.3. This seems to work albeit with errors in the Collabora log.
I’ve let the TrueNAS community know about the issue via the discussion area for the resource Nextcloud and Collabora Integration. Refer to this post Nextcloud and Collabora Integration | Page 2 | TrueNAS Community
I have the same issue.
Jul 05 22:11:57 debian-kammer loolwsd[12019]: | wsd/DocumentBroker.cpp:1854
Jul 05 22:11:57 debian-kammer loolwsd[12019]: wsd-12019-12843 2021-07-05 20:11:57.531665 [ docbroker_01a ] ERR  Failed to add session to [/apps/richdocuments/wopi/files/xxx] with URI [https://xxxx.xxx.xxx/apps/
Jul 05 22:11:57 debian-kammer loolwsd[12019]: No server is available to handle this request.
Jul 05 22:11:57 debian-kammer loolwsd[12019]: </body></html>
Could you help me. Do you know, how can I rollingback with debian apt-get?
Still broken in CODE 6.4.10.3
office version details: { "ProductName": "Collabora Office", "ProductVersion": "6.4", "ProductExtension": ".10.44", "BuildId": "2b31b2ef595ece37ba5e5919be43ba04193a2d3b" }
wsd-00009-00052 2021-07-07 02:05:03.273957 [ websrv_poll ] WRN  client - server version mismatch, disabling browser cache. Expected: 2c4ce99| wsd/FileServer.cpp:288
wsd-00009-00052 2021-07-07 02:05:03.274411 [ websrv_poll ] WRN  Skipping the token [--co-primary-text= #ffffff] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274441 [ websrv_poll ] WRN  Skipping the token [--co-primary-element= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274448 [ websrv_poll ] WRN  Skipping the token [--co-text-accent= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274454 [ websrv_poll ] WRN  Skipping the token [--co-primary-element-light= #17adff] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274460 [ websrv_poll ] WRN  Skipping the token [--co-color-error= #e9322d] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274465 [ websrv_poll ] WRN  Skipping the token [--co-color-warning= #eca700] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274474 [ websrv_poll ] WRN  Skipping the token [--co-color-success= #46ba61] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274481 [ websrv_poll ] WRN  Skipping the token [--co-border-radius= 3px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274486 [ websrv_poll ] WRN  Skipping the token [--co-border-radius-large= 10px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274509 [ websrv_poll ] WRN  Skipping the token [--co-loading-light= #ccc] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274515 [ websrv_poll ] WRN  Skipping the token [--co-loading-dark= #444] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274522 [ websrv_poll ] WRN  Skipping the token [--co-box-shadow= rgba(77, 77, 77, 0.5)] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274528 [ websrv_poll ] WRN  Skipping the token [--co-border= #ededed] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274552 [ websrv_poll ] WRN  Skipping the token [--co-border-dark= #dbdbdb] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00052 2021-07-07 02:05:03.274559 [ websrv_poll ] WRN  Skipping the token [--co-border-radius-pill= 100px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00009-00054 2021-07-07 02:05:03.375749 [ docbroker_001 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00009-00054 2021-07-07 02:05:03.377297 [ docbroker_001 ] ERR  Socket #30 SSL BIO error: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error (0: Success)| ./net/SslSocket.hpp:307
wsd-00009-00054 2021-07-07 02:05:03.377439 [ docbroker_001 ] ERR  Error while handling poll for socket #30 in HttpSynReqPoll: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error| net/Socket.cpp:356
wsd-00009-00054 2021-07-07 02:05:03.377554 [ docbroker_001 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h?access_token=a1ui9BQREP0ZYOt2cMWVgQjo6ZGn6nmO&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_r3d%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22]: 0 . Headers:   Body: []| wsd/Storage.cpp:723
wsd-00009-00054 2021-07-07 02:05:03.377625 [ docbroker_001 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00009-00054 2021-07-07 02:05:03.377649 [ docbroker_001 ] ERR  Failed to add session to [/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h] with URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h?access_token=a1ui9BQREP0ZYOt2cMWVgQjo6ZGn6nmO&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_r3d%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00009-00054 2021-07-07 02:05:03.378609 [ docbroker_001 ] ERR  #25: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00054 2021-07-07 02:05:03.378857 [ docbroker_001 ] ERR  Invalid or unknown session [002] to remove.| wsd/DocumentBroker.cpp:1893
wsd-00009-00052 2021-07-07 02:05:03.623537 [ websrv_poll ] WRN  DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2144
wsd-00009-00052 2021-07-07 02:05:03.623680 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h].| wsd/LOOLWSD.cpp:3613
wsd-00009-00052 2021-07-07 02:05:03.623699 [ websrv_poll ] ERR  #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00052 2021-07-07 02:05:03.623719 [ websrv_poll ] ERR  #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00052 2021-07-07 02:05:03.623726 [ websrv_poll ] WRN  Socket #29 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:764
wsd-00009-00052 2021-07-07 02:05:03.624536 [ websrv_poll ] ERR  #29: attempted to remove: 1371 which is > size: 0 clamped to 0| ./net/Socket.hpp:1091
wsd-00009-00052 2021-07-07 02:05:03.624566 [ websrv_poll ] ERR  #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00052 2021-07-07 02:05:04.678065 [ websrv_poll ] WRN  DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2144
wsd-00009-00052 2021-07-07 02:05:04.678182 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h].| wsd/LOOLWSD.cpp:3613
wsd-00009-00052 2021-07-07 02:05:04.678200 [ websrv_poll ] ERR  #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00052 2021-07-07 02:05:04.678220 [ websrv_poll ] ERR  #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00052 2021-07-07 02:05:04.678227 [ websrv_poll ] WRN  Socket #29 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:764
wsd-00009-00052 2021-07-07 02:05:04.678257 [ websrv_poll ] ERR  #29: attempted to remove: 1371 which is > size: 0 clamped to 0| ./net/Socket.hpp:1091
wsd-00009-00052 2021-07-07 02:05:04.678277 [ websrv_poll ] ERR  #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00047 2021-07-07 02:05:05.378509 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
wsd-00009-00056 2021-07-07 02:05:05.716428 [ docbroker_002 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00009-00056 2021-07-07 02:05:05.718522 [ docbroker_002 ] ERR  Socket #30 SSL BIO error: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error (0: Success)| ./net/SslSocket.hpp:307
wsd-00009-00056 2021-07-07 02:05:05.718668 [ docbroker_002 ] ERR  Error while handling poll for socket #30 in HttpSynReqPoll: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error| net/Socket.cpp:356
wsd-00009-00056 2021-07-07 02:05:05.718997 [ docbroker_002 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h?access_token=a1ui9BQREP0ZYOt2cMWVgQjo6ZGn6nmO&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_r3d%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22&permission=edit]: 0 . Headers:   Body: []| wsd/Storage.cpp:723
wsd-00009-00056 2021-07-07 02:05:05.719523 [ docbroker_002 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00009-00056 2021-07-07 02:05:05.719639 [ docbroker_002 ] ERR  Failed to add session to [/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h] with URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334140_ocosbn1u1n1h?access_token=a1ui9BQREP0ZYOt2cMWVgQjo6ZGn6nmO&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_r3d%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22&permission=edit]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00009-00056 2021-07-07 02:05:05.720550 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-005| wsd/ClientSession.cpp:348
wsd-00009-00056 2021-07-07 02:05:05.720623 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-005| wsd/ClientSession.cpp:348
wsd-00009-00056 2021-07-07 02:05:05.720637 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-005| wsd/ClientSession.cpp:348
wsd-00009-00056 2021-07-07 02:05:05.720781 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-005| wsd/ClientSession.cpp:348
wsd-00009-00056 2021-07-07 02:05:05.720910 [ docbroker_002 ] ERR  #21: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00009-00056 2021-07-07 02:05:05.721030 [ docbroker_002 ] ERR  Invalid or unknown session [005] to remove.| wsd/DocumentBroker.cpp:1893
frk-00048-00048 2021-07-07 02:05:05.740049 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/hu1JZkkHS0rAQiYC/tmp].| common/JailUtil.cpp:68
frk-00048-00048 2021-07-07 02:05:05.763514 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/hu1JZkkHS0rAQiYC/lo].| common/JailUtil.cpp:68
frk-00048-00048 2021-07-07 02:05:05.786540 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/hu1JZkkHS0rAQiYC].| common/JailUtil.cpp:68
wsd-00009-00047 2021-07-07 02:05:07.721000 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
frk-00048-00048 2021-07-07 02:05:07.947933 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/uJMDYx2cJaci9e2T/tmp].| common/JailUtil.cpp:68
frk-00048-00048 2021-07-07 02:05:07.970493 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/uJMDYx2cJaci9e2T/lo].| common/JailUtil.cpp:68
frk-00048-00048 2021-07-07 02:05:07.993664 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/uJMDYx2cJaci9e2T].| common/JailUtil.cpp:68
More broken than before in the latest nightly. The error log is split over two posts.
wsd-00007-00043 2021-07-10 01:57:49.015141 [ websrv_poll ] WRN  convert-to: Requesting address is denied: ::ffff:10.1.1.4| wsd/LOOLWSD.cpp:2457
wsd-00007-00043 2021-07-10 01:58:11.190059 [ websrv_poll ] WRN  convert-to: Requesting address is denied: ::ffff:10.1.1.4| wsd/LOOLWSD.cpp:2457
wsd-00007-00043 2021-07-10 01:58:52.459040 [ websrv_poll ] ERR  Sending back: HTTP/1.1 200 OK
Last-Modified: Sat, 10 Jul 2021 01:58:52
User-Agent: LOOLWSD HTTP Agent 6.4.10
Content-Length: 33638
Content-Type: text/xml
X-Content-Type-Options: nosniff
Connection: close
<wopi-discovery>
    <net-zone name="external-http">
        <!-- Writer documents -->
        <app favIconUrl="https://collabora.udance.com.au/loleaflet/2c4ce99/images/x-office-document.svg" name="writer">
            <action default="true" ext="sxw" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="odt" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="fodt" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Text template documents -->
            <action default="true" ext="stw" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="ott" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- MS Word -->
            <action default="true" ext="doc" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="dot" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- OOXML wordprocessing -->
            <action default="true" ext="docx" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="docm" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="dotx" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="dotm" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Others -->
            <action default="true" ext="wpd" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="pdb" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="hwp" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="wps" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="wri" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="lrf" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="mw" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="rtf" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="txt" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="fb2" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="cwk" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="pages" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="abw" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="602" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <app name="writer-global">
            <!-- Text master documents -->
            <action default="true" ext="sxg" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="odm" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Writer master document templates -->
            <action default="true" ext="otm" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <app name="writer-web">
            <action default="true" ext="oth" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <!-- Calc documents -->
        <app favIconUrl="https://collabora.udance.com.au/loleaflet/2c4ce99/images/x-office-spreadsheet.svg" name="calc">
            <action default="true" ext="sxc" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="ods" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="fods" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Spreadsheet template documents -->
            <action default="true" ext="stc" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="ots" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- MS Excel -->
            <action default="true" ext="xls" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="xla" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- OOXML spreadsheet -->
            <action default="true" ext="xltx" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="xltm" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="xlsx" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="xlsb" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="xlsm" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Others -->
            <action default="true" ext="dif" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="slk" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="csv" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="dbf" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="wk1" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="gnumeric" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="numbers" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <!-- Impress documents -->
        <app favIconUrl="https://collabora.udance.com.au/loleaflet/2c4ce99/images/x-office-presentation.svg" name="impress">
            <action default="true" ext="sxi" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="odp" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="fodp" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Presentation template documents -->
            <action default="true" ext="sti" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="otp" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- MS PowerPoint -->
            <action default="true" ext="ppt" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="pot" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- OOXML presentation -->
            <action default="true" ext="pptx" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="pptm" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="potx" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="potm" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="ppsx" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Others -->
            <action default="true" ext="cgm" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="key" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <!-- Draw documents -->
        <app name="draw">
            <action default="true" ext="sxd" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="odg" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="fodg" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Drawing template documents -->
            <action default="true" ext="std" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="otg" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <!-- Others -->
            <action ext="svg" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="dxf" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="emf" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="wmf" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="cdr" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="vsd" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="vsdx" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="vss" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="pub" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="p65" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="wpg" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action default="true" ext="fh" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="bmp" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="png" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="gif" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="tiff" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="jpg" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="jpeg" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
            <action ext="pdf" name="view_comment" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <!-- Math documents -->
        <!-- In fact Math documents are not supported at all.
             See: https://bugs.documentfoundation.org/show_bug.cgi?id=97006
        <app name="math">
            <action name="view" default="true" ext="sxm"/>
            <action name="edit" default="true" ext="odf"/>
        </app>
        <!-- Legacy MIME-type actions (compatibility) -->
        <app name="image/svg+xml">
            <action ext="" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <app name="application/vnd.ms-powerpoint">
            <action default="true" ext="" name="edit" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <app name="application/vnd.ms-excel">
        </app>
        <app name="application/vnd.sun.xml.writer">
            <action default="true" ext="" name="view" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <app name="application/vnd.oasis.opendocument.text">
        </app>
        <app name="application/vnd.oasis.opendocument.text-flat-xml">
        </app>
        <app name="application/vnd.sun.xml.calc">
        </app>
        <app name="application/vnd.oasis.opendocument.spreadsheet">
        </app>
        <app name="application/vnd.oasis.opendocument.spreadsheet-flat-xml">
        </app>
        <app name="application/vnd.sun.xml.impress">
        </app>
        <app name="application/vnd.oasis.opendocument.presentation">
        </app>
        <app name="application/vnd.oasis.opendocument.presentation-flat-xml">
        </app>
        <app name="application/vnd.sun.xml.draw">
        </app>
        <app name="application/vnd.oasis.opendocument.graphics">
        </app>
        <app name="application/vnd.oasis.opendocument.graphics-flat-xml">
        </app>
        <!-- Chart documents -->
        <app name="application/vnd.oasis.opendocument.chart">
        </app>
        <app name="application/vnd.sun.xml.writer.global">
        </app>
        <app name="application/vnd.oasis.opendocument.text-master">
        </app>
        <app name="application/vnd.sun.xml.math">
            <action name="view" default="true" ext=""/>
        </app>
        <app name="application/vnd.oasis.opendocument.formula">
            <action name="edit" default="true" ext=""/>
        </app>
        <app name="application/vnd.sun.xml.writer.template">
        </app>
        <app name="application/vnd.oasis.opendocument.text-template">
        </app>
        <app name="application/vnd.oasis.opendocument.text-master-template">
        </app>
        <app name="application/vnd.sun.xml.calc.template">
        </app>
        <app name="application/vnd.oasis.opendocument.spreadsheet-template">
        </app>
        <app name="application/vnd.sun.xml.impress.template">
        </app>
        <app name="application/vnd.oasis.opendocument.presentation-template">
        </app>
        <app name="application/vnd.sun.xml.draw.template">
        </app>
        <app name="application/vnd.oasis.opendocument.graphics-template">
        </app>
        <!-- MS Word -->
        <app name="application/msword">
        </app>
        </app>
        <!-- MS Excel -->
        </app>
        </app>
        <app name="application/vnd.openxmlformats-officedocument.wordprocessingml.document">
        </app>
        <app name="application/vnd.ms-word.document.macroEnabled.12">
        </app>
        <app name="application/vnd.openxmlformats-officedocument.wordprocessingml.template">
        </app>
        <app name="application/vnd.ms-word.template.macroEnabled.12">
        </app>
        <app name="application/vnd.openxmlformats-officedocument.spreadsheetml.template">
        </app>
        <app name="application/vnd.ms-excel.template.macroEnabled.12">
        </app>
        <app name="application/vnd.openxmlformats-officedocument.spreadsheetml.sheet">
        </app>
        <app name="application/vnd.ms-excel.sheet.binary.macroEnabled.12">
        </app>
        <app name="application/vnd.ms-excel.sheet.macroEnabled.12">
        </app>
        <app name="application/vnd.openxmlformats-officedocument.presentationml.presentation">
        </app>
        <app name="application/vnd.ms-powerpoint.presentation.macroEnabled.12">
        </app>
        <app name="application/vnd.openxmlformats-officedocument.presentationml.template">
        </app>
        <app name="application/vnd.ms-powerpoint.template.macroEnabled.12">
        </app>
        <!-- Others -->
        <app name="application/vnd.wordperfect">
        </app>
        <app name="application/x-aportisdoc">
        </app>
        <app name="application/x-hwp">
        </app>
        <app name="application/vnd.ms-works">
        </app>
        <app name="application/x-mswrite">
        </app>
        <app name="application/x-dif-document">
        </app>
        <app name="text/spreadsheet">
        </app>
        <app name="text/csv">
        </app>
        <app name="application/x-dbase">
        </app>
        <app name="application/vnd.lotus-1-2-3">
        </app>
        <app name="image/cgm">
        </app>
        <app name="image/vnd.dxf">
        </app>
        <app name="image/x-emf">
        </app>
        <app name="image/x-wmf">
        </app>
        <app name="application/coreldraw">
        </app>
        <app name="application/vnd.visio2013">
        </app>
        <app name="application/vnd.visio">
        </app>
        <app name="application/vnd.ms-visio.drawing">
        </app>
        <app name="application/x-mspublisher">
        </app>
        <app name="application/x-sony-bbeb">
        </app>
        <app name="application/x-gnumeric">
        </app>
        <app name="application/macwriteii">
        </app>
        <app name="application/x-iwork-numbers-sffnumbers">
        </app>
        <app name="application/vnd.oasis.opendocument.text-web">
        </app>
        <app name="application/x-pagemaker">
        </app>
        <app name="text/rtf">
        </app>
        <app name="text/plain">
        </app>
        <app name="application/x-fictionbook+xml">
        </app>
        <app name="application/clarisworks">
        </app>
        <app name="image/x-wpg">
        </app>
        <app name="application/x-iwork-pages-sffpages">
        </app>
        <app name="application/vnd.openxmlformats-officedocument.presentationml.slideshow">
        </app>
        <app name="application/x-iwork-keynote-sffkey">
        </app>
        <app name="application/x-abiword">
        </app>
        <app name="image/x-freehand">
        </app>
        <app name="application/vnd.sun.xml.chart">
        </app>
        <app name="application/x-t602">
        </app>
        <app name="image/bmp">
        </app>
        <app name="image/png">
        </app>
        <app name="image/gif">
        </app>
        <app name="image/tiff">
        </app>
        <app name="image/jpg">
        </app>
        <app name="image/jpeg">
        </app>
        <app name="application/pdf">
            <action ext="" name="view_comment" urlsrc="https://collabora.udance.com.au/loleaflet/2c4ce99/loleaflet.html?"/>
        </app>
        <!-- End of legacy MIME-type actions -->
        <app name="Capabilities">
            <action ext="" name="getinfo" urlsrc="https://collabora.udance.com.au/hosting/capabilities"/>
        </app>
    </net-zone>
<proof-key exponent="AQAB" modulus="wkRCMXkdFkvJwAVGPjn3tUCyVRJw+sppeIdqFhWEkJkUNOqOzxNYl5lV4FJGGg14kWEBoWD69MoUPGIa+22ZGlDQaPEt37NC57St71j5JTDjn07VMRlxz7lYDq3HiH45QcTsNSrWcx/4WisSsFWx+zFlqeXHBctDo5dXPjFUucOzWyM4pKn/4EGzOQ0749PQobv9Rt2lA6b65zJiVjt66EZYPiq79FudzA/aLcJ7/eLJ9MPBEXgYnI6eReZbl7bVMqU9flgVbvDj4e0PmhkbHomxovr+2b8/pAp1fb1HM+nIfPq0mTrQnqrgcUOw+hyTxuIKl69Unb+hKUhS+SaIzQ==" oldexponent="AQAB" oldmodulus="wkRCMXkdFkvJwAVGPjn3tUCyVRJw+sppeIdqFhWEkJkUNOqOzxNYl5lV4FJGGg14kWEBoWD69MoUPGIa+22ZGlDQaPEt37NC57St71j5JTDjn07VMRlxz7lYDq3HiH45QcTsNSrWcx/4WisSsFWx+zFlqeXHBctDo5dXPjFUucOzWyM4pKn/4EGzOQ0749PQobv9Rt2lA6b65zJiVjt66EZYPiq79FudzA/aLcJ7/eLJ9MPBEXgYnI6eReZbl7bVMqU9flgVbvDj4e0PmhkbHomxovr+2b8/pAp1fb1HM+nIfPq0mTrQnqrgcUOw+hyTxuIKl69Unb+hKUhS+SaIzQ==" oldvalue="BgIAAACkAABSU0ExAAgAAAEAAQDNiCb5Ukgpob+dVK+XCuLGkxz6sENx4Kqe0DqZtPp8yOkzR719dQqkP7/Z/vqisYkeGxmaD+3h4/BuFVh+PaUy1baXW+ZFno6cGHgRwcP0yeL9e8It2g/MnVv0uyo+WEboejtWYjLn+qYDpd1G/buh0NPjOw05s0Hg/6mkOCNbs8O5VDE+V5ejQ8sFx+WpZTH7sVWwEita+B9z1io17MRBOX6Ix60OWLnPcRkx1U6f4zAl+VjvrbTnQrPfLfFo0FAamW37GmI8FMr0+mChAWGReA0aRlLgVZmXWBPPjuo0FJmQhBUWaod4acr6cBJVskC19zk+RgXAyUsWHXkxQkTC" value="BgIAAACkAABSU0ExAAgAAAEAAQDNiCb5Ukgpob+dVK+XCuLGkxz6sENx4Kqe0DqZtPp8yOkzR719dQqkP7/Z/vqisYkeGxmaD+3h4/BuFVh+PaUy1baXW+ZFno6cGHgRwcP0yeL9e8It2g/MnVv0uyo+WEboejtWYjLn+qYDpd1G/buh0NPjOw05s0Hg/6mkOCNbs8O5VDE+V5ejQ8sFx+WpZTH7sVWwEita+B9z1io17MRBOX6Ix60OWLnPcRkx1U6f4zAl+VjvrbTnQrPfLfFo0FAamW37GmI8FMr0+mChAWGReA0aRlLgVZmXWBPPjuo0FJmQhBUWaod4acr6cBJVskC19zk+RgXAyUsWHXkxQkTC"/></wopi-discovery>| wsd/LOOLWSD.cpp:2840
wsd-00007-00043 2021-07-10 01:58:53.062584 [ websrv_poll ] WRN  Skipping the token [--co-primary-text= #ffffff] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062619 [ websrv_poll ] WRN  Skipping the token [--co-primary-element= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062625 [ websrv_poll ] WRN  Skipping the token [--co-text-accent= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062631 [ websrv_poll ] WRN  Skipping the token [--co-primary-element-light= #17adff] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062637 [ websrv_poll ] WRN  Skipping the token [--co-color-error= #e9322d] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062642 [ websrv_poll ] WRN  Skipping the token [--co-color-warning= #eca700] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062647 [ websrv_poll ] WRN  Skipping the token [--co-color-success= #46ba61] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062653 [ websrv_poll ] WRN  Skipping the token [--co-border-radius= 3px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062658 [ websrv_poll ] WRN  Skipping the token [--co-border-radius-large= 10px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062663 [ websrv_poll ] WRN  Skipping the token [--co-loading-light= #ccc] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062668 [ websrv_poll ] WRN  Skipping the token [--co-loading-dark= #444] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062674 [ websrv_poll ] WRN  Skipping the token [--co-box-shadow= rgba(77, 77, 77, 0.5)] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062679 [ websrv_poll ] WRN  Skipping the token [--co-border= #ededed] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062685 [ websrv_poll ] WRN  Skipping the token [--co-border-dark= #dbdbdb] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00043 2021-07-10 01:58:53.062690 [ websrv_poll ] WRN  Skipping the token [--co-border-radius-pill= 100px] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
wsd-00007-00046 2021-07-10 01:58:53.218054 [ docbroker_001 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00007-00046 2021-07-10 01:58:53.219607 [ docbroker_001 ] ERR  Socket #32 SSL BIO error: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error (0: Success)| ./net/SslSocket.hpp:307
wsd-00007-00046 2021-07-10 01:58:53.219725 [ docbroker_001 ] ERR  Error while handling poll for socket #32 in HttpSynReqPoll: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error| net/Socket.cpp:356
wsd-00007-00046 2021-07-10 01:58:53.219837 [ docbroker_001 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h?access_token=aXjH3iq1pSorhZb7F7w58NmRjSbJx2Vv&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22]: 0 . Headers:   Body: []| wsd/Storage.cpp:723
wsd-00007-00046 2021-07-10 01:58:53.219913 [ docbroker_001 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00007-00046 2021-07-10 01:58:53.219963 [ docbroker_001 ] ERR  Failed to add session to [/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h] with URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h?access_token=aXjH3iq1pSorhZb7F7w58NmRjSbJx2Vv&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00007-00046 2021-07-10 01:58:53.220157 [ docbroker_001 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-005| wsd/ClientSession.cpp:348
wsd-00007-00046 2021-07-10 01:58:53.220190 [ docbroker_001 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-005| wsd/ClientSession.cpp:348
wsd-00007-00046 2021-07-10 01:58:53.220206 [ docbroker_001 ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00046 2021-07-10 01:58:53.220222 [ docbroker_001 ] ERR  Invalid or unknown session [005] to remove.| wsd/DocumentBroker.cpp:1893
wsd-00007-00043 2021-07-10 01:58:53.484650 [ websrv_poll ] WRN  DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2144
wsd-00007-00043 2021-07-10 01:58:53.484786 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h].| wsd/LOOLWSD.cpp:3613
wsd-00007-00043 2021-07-10 01:58:53.484807 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-10 01:58:53.484825 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-10 01:58:53.484831 [ websrv_poll ] WRN  Socket #27 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:764
wsd-00007-00043 2021-07-10 01:58:53.484843 [ websrv_poll ] ERR  #27: attempted to remove: 1232 which is > size: 0 clamped to 0| ./net/Socket.hpp:1091
wsd-00007-00043 2021-07-10 01:58:53.484859 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-10 01:58:54.565385 [ websrv_poll ] WRN  DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2144
wsd-00007-00043 2021-07-10 01:58:54.565595 [ websrv_poll ] ERR  Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h].| wsd/LOOLWSD.cpp:3613
wsd-00007-00043 2021-07-10 01:58:54.565632 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-10 01:58:54.565665 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00043 2021-07-10 01:58:54.565694 [ websrv_poll ] WRN  Socket #27 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:764
wsd-00007-00043 2021-07-10 01:58:54.565706 [ websrv_poll ] ERR  #27: attempted to remove: 1232 which is > size: 0 clamped to 0| ./net/Socket.hpp:1091
wsd-00007-00043 2021-07-10 01:58:54.565807 [ websrv_poll ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
frk-00039-00039 2021-07-10 01:58:55.337822 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/oCkVe3ZszBpLVDra/tmp].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-10 01:58:55.362774 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/oCkVe3ZszBpLVDra/lo].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-10 01:58:55.387574 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/oCkVe3ZszBpLVDra].| common/JailUtil.cpp:68
wsd-00007-00043 2021-07-10 01:58:55.601111 [ websrv_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
wsd-00007-00053 2021-07-10 01:58:55.606553 [ docbroker_002 ] WRN  Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:673
wsd-00007-00053 2021-07-10 01:58:55.608323 [ docbroker_002 ] ERR  Socket #30 SSL BIO error: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error (0: Success)| ./net/SslSocket.hpp:307
wsd-00007-00053 2021-07-10 01:58:55.608437 [ docbroker_002 ] ERR  Error while handling poll for socket #30 in HttpSynReqPoll: error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error| net/Socket.cpp:356
wsd-00007-00053 2021-07-10 01:58:55.608598 [ docbroker_002 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h?access_token=aXjH3iq1pSorhZb7F7w58NmRjSbJx2Vv&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22&permission=edit]: 0 . Headers:   Body: []| wsd/Storage.cpp:723
wsd-00007-00053 2021-07-10 01:58:55.609209 [ docbroker_002 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1854
wsd-00007-00053 2021-07-10 01:58:55.609261 [ docbroker_002 ] ERR  Failed to add session to [/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h] with URI [https://cloud.udance.com.au/index.php/apps/richdocuments/wopi/files/334557_ocosbn1u1n1h?access_token=aXjH3iq1pSorhZb7F7w58NmRjSbJx2Vv&access_token_ttl=0&reuse_cookies=tk_or%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22%3Atk_lr%3D%22https%3A%2F%2Fheimdall.udance.com.au%2F%22&permission=edit]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1816
wsd-00007-00053 2021-07-10 01:58:55.609502 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-008| wsd/ClientSession.cpp:348
wsd-00007-00053 2021-07-10 01:58:55.609831 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-008| wsd/ClientSession.cpp:348
wsd-00007-00053 2021-07-10 01:58:55.609839 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-008| wsd/ClientSession.cpp:348
wsd-00007-00053 2021-07-10 01:58:55.609844 [ docbroker_002 ] ERR  No DocBroker found, or DocBroker marked to be destroyed. Terminating session ToClient-008| wsd/ClientSession.cpp:348
wsd-00007-00053 2021-07-10 01:58:55.609862 [ docbroker_002 ] ERR  #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
wsd-00007-00053 2021-07-10 01:58:55.609880 [ docbroker_002 ] ERR  Invalid or unknown session [008] to remove.| wsd/DocumentBroker.cpp:1893
wsd-00007-00038 2021-07-10 01:58:57.613891 [ prisoner_poll ] WRN  Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2231
frk-00039-00039 2021-07-10 01:58:58.646140 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/O2quiN7gjC2OWGMD/tmp].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-10 01:58:58.669018 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/O2quiN7gjC2OWGMD/lo].| common/JailUtil.cpp:68
frk-00039-00039 2021-07-10 01:58:58.692265 [ forkit ] ERR  Failed to unmount [/opt/lool/child-roots/O2quiN7gjC2OWGMD].| common/JailUtil.cpp:68
I don’t think this applies to docker only. I use the packages on Ubuntu, behind haproxy as reverse ssl proxy and have the same problem. Ever since the latest update CODE is completely broken.
I am not sure if posting log entries would help, as the problem can be reproduced. Also I run all my stuff in LXD containers, not in docker containers, maybe that is related?
Jul 12 23:07:22 collabo loolwsd[132]: <proof-key exponent=“AQAB” modulus="rRQPAJ2TwdVV5WNomFolT0t6aJMZjcswWZ8qANpZy0pkVkcjEFp8fNluXSBtF1ajJMh5Gfe6Gc7+WIeiFvMVfoik2pAedJhALTSQ52xSGXVfUr6Cy1Esmbyem6PKtIL7p8Jnf3L+>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.733969 [ websrv_poll ] WRN Skipping the token [–co-primary-text= #ffffff] since it contains forbidden characters| wsd/FileServerUtil.c>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734039 [ websrv_poll ] WRN Skipping the token [–co-primary-element= #0082c9] since it contains forbidden characters| wsd/FileServerUti>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734049 [ websrv_poll ] WRN Skipping the token [–co-text-accent= #0082c9] since it contains forbidden characters| wsd/FileServerUtil.cp>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734059 [ websrv_poll ] WRN Skipping the token [–co-primary-element-light= #17adff] since it contains forbidden characters| wsd/FileSer>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734069 [ websrv_poll ] WRN Skipping the token [–co-color-error= #e9322d] since it contains forbidden characters| wsd/FileServerUtil.cp>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734078 [ websrv_poll ] WRN Skipping the token [–co-color-warning= #eca700] since it contains forbidden characters| wsd/FileServerUtil.>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734087 [ websrv_poll ] WRN Skipping the token [–co-color-success= #46ba61] since it contains forbidden characters| wsd/FileServerUtil.>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734096 [ websrv_poll ] WRN Skipping the token [–co-border-radius= 3px] since it contains forbidden characters| wsd/FileServerUtil.cpp:>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734104 [ websrv_poll ] WRN Skipping the token [–co-border-radius-large= 10px] since it contains forbidden characters| wsd/FileServerUt>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734116 [ websrv_poll ] WRN Skipping the token [–co-loading-light= #ccc] since it contains forbidden characters| wsd/FileServerUtil.cpp>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734125 [ websrv_poll ] WRN Skipping the token [–co-loading-dark= #444] since it contains forbidden characters| wsd/FileServerUtil.cpp:>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734136 [ websrv_poll ] WRN Skipping the token [–co-box-shadow= rgba(77, 77, 77, 0.5)] since it contains forbidden characters| wsd/File>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734145 [ websrv_poll ] WRN Skipping the token [–co-border= #ededed] since it contains forbidden characters| wsd/FileServerUtil.cpp:144
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734154 [ websrv_poll ] WRN Skipping the token [–co-border-dark= #dbdbdb] since it contains forbidden characters| wsd/FileServerUtil.cp>
Jul 12 23:07:22 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:22.734163 [ websrv_poll ] WRN Skipping the token [–co-border-radius-pill= 100px] since it contains forbidden characters| wsd/FileServerUt>
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00212 2021-07-12 21:07:23.054433 [ docbroker_001 ] WRN Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:671
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00212 2021-07-12 21:07:23.063286 [ docbroker_001 ] ERR WOPI::CheckFileInfo failed for URI [https://REDACTED.de/index.php/apps/richdocuments/wopi/files/184556_ocyp2l>
Jul 12 23:07:23 collabo loolwsd[132]: No server is available to handle this request.
Jul 12 23:07:23 collabo loolwsd[132]: ]| wsd/Storage.cpp:723
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00212 2021-07-12 21:07:23.063644 [ docbroker_001 ] ERR loading document exception: WOPI::CheckFileInfo failed:
503 Service Unavailable
Jul 12 23:07:23 collabo loolwsd[132]: | wsd/DocumentBroker.cpp:1854
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00212 2021-07-12 21:07:23.063709 [ docbroker_001 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/184556_ocyp2lyxttca] with URI [https://>
Jul 12 23:07:23 collabo loolwsd[132]: | wsd/DocumentBroker.cpp:1816
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00212 2021-07-12 21:07:23.064524 [ docbroker_001 ] ERR #23: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00212 2021-07-12 21:07:23.064594 [ docbroker_001 ] ERR Invalid or unknown session [025] to remove.| wsd/DocumentBroker.cpp:1893
Jul 12 23:07:23 collabo loolwsd[213]: kit-00213-00199 2021-07-12 21:07:23.175824 [ kit_spare_002 ] ERR mknod(/opt/lool/child-roots/FrvgEh9mf0ocQwqi//tmp/dev/random) failed. Mount must not use nodev flag. (EPER>
Jul 12 23:07:23 collabo loolwsd[213]: kit-00213-00199 2021-07-12 21:07:23.175929 [ kit_spare_002 ] ERR mknod(/opt/lool/child-roots/FrvgEh9mf0ocQwqi//tmp/dev/urandom) failed. Mount must not use nodev flag. (EPE>
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:23.645311 [ websrv_poll ] WRN DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/184556_ocyp2lyxttca] that is marked to be de>
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:23.646253 [ websrv_poll ] ERR Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocument>
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:23.646323 [ websrv_poll ] ERR #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:23.646365 [ websrv_poll ] ERR #27: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1255
Jul 12 23:07:23 collabo loolwsd[132]: wsd-00132-00208 2021-07-12 21:07:23.646385 [ websrv_poll ] WRN Socket #27 is shutting down but 64 bytes couldn’t be flushed and still remain in the output buffer.| ./net/W>
Has anyone glanced at the latest weekly meeting minutes Collabora Online Weekly Meeting #32 that occurred less than 24 hours ago? Here’s an extract…
Stability (Gabriel)
  • tested 6.4.10 manually and it looks better than 6.4.9 and internal version. It’s faster and more stable.
Is that some sort of joke? @StavrosMadK reported this issue 10 days ago. We haven’t heard boo from any Collabora staff on the forum. This appears to be a widespread issue. The minutes should reflect what the community are saying on the forum and not make nonsense statements like this.
Also just in case they don’t look on the forums for this kind of stuff, there is an open issue on github since 7 days ago, where i also posted logs etc.
On top of that. the last days, I’ve seen some very “bad” things, Collabora decided that is ok to overwrite tags(images) and also remove tags(images) from dockerhub. Which is something that can mess up a CI if you don’t manually step in
Hey basil!
Sorry to hear you are having issues, but the meeting minutes reflect what is said in the meeting by people who attend it. (It is a public meeting, open to all contributors of COOL/CODE)
Gabriel is not a member of the team but a valued contributor/community-member, and he was sharing his experience/thoughts.
Nonetheless, although this category is meant to be a place where users help each other, team members try to respond topics from time to time, but unfortunately their number/time is not infinite, and they work to fix and improve COOL/CODE all the time. :wink:
I’ll try to draw some attention to this topic, but the place to properly file bugs (after making sure it’s not a configuration error but a bug) is our GitHub Issues page, and they are very much appreciated there.
Btw, there IS a bug report on github for 6.4.10.* as I linked on my previous post (actually there are multiple, but the rest is smaller issues).
While some people might be able to make it work, there are a lot more that can’t make it work, using a working configuration from 6.4.9.3.
So please, let us know if there is something changed in 6.4.10.* images that might need different configuration on our end.
Hey @StavrosMadK ! It’s being investigated now.
Hi Kara, thank you for being the brave face of Collabora and responding to my post. My apologies to you and Gabriel for the abruptness of the post.
The Collabora forum appears to be a fairly new initiative. I don’t recall coming across it in April 2020 when I first set up the wiki resource Nextcloud and Collabora Integration for the TrueNAS community. Had I known about it, I would have loved to have referred to it then.
While I understand that GitHub is the place to report bugs, it’s worth noting that the forum is a useful indicator of trending issues that hit a significant cross-section of the community. At present, it doesn’t appear that Collabora is taking advantage of this valuable intel.
(Split over multiple posts as new users can only include two links in any one post)
The forum is the natural ‘go to place’ for users who are not developers. In fact, we either, naturally gravitate here, or, are directed to share our experiences on the forum e.g. see the forum post CODE 6.4.10 released - Please help us test! and this announcement extract that it links to…
Enjoy and get involved
With CODE, you always run the latest features in online collaboration and interoperability. We hope you like this new release as much as we do! It’s easy to get involved: do share your experiences – we love to hear your feedback. Finally, why not check-out the developer resources on GitHub and get involved
The evidence, at present, seems to be that the feedback isn’t being utilised.
6.4.10 does not work.
I have tried different configuration.
haproxy ->built-in code server
haproxy → nginx reverse proxy → loolwsd on docker or as vm with or without tls
nginx reverse proxy → loolwsd with or without tls
error messages without end
haproxy 2.4.2 makes the tls termination
@kara Is there any progress? 6.4.10.5 image is up but still not working.
I have the same issue. use 6.4.9.3 docker image can work.
6.4.10.5 still not working.
The demo server(tokyo) also has 6.4.10 installed, but it can work.
There is a “possible” fixed pushed about 3 days ago, (something related with SNI hostnames), but still no image is released.
The reason that demo server is working is probably not using any SNI… But not sure.
Anyway. I hope they push a build for the image soon.
You are right. I changed my nextcloud’s cert as the default cert of my web server. the issue resolved.
It’s related to SNI.
