After a ./g pull -r and make clean and calling make I get the build failure
C:\colwsl7\online\engine\cppcanvas\inc\pch\precompiled_cppcanvas.hxx(135): fatal error C1083: Cannot open include file: 'cppcanvas/canvas.hxx': No such file or directory
looks like a recent refactoring broke the precompiled header, and Windows CI does not use precompiled headers any more because it conflicts with ccache … hope this gerrit patch should fix it, but i’m afraid Noel will keep moving things around…
I took a look at the --disable-pch we are using on the windows ci
machines and I think there isn’t a fundamental incompatibility with the
ccache approach we are using on the windows machine, the engine
autodetects ccache and sets a ccache strategy that works with pch.
In local testing is all seems to work, maybe even the best of both
worlds with a faster build when headers change. I think the existing
cache is useless, and the same ci builds co-26.04 so probably need to
make sure co-26.04 pch is also fixed for that build, and then maybe try
and turn it on at a non-peak time in case it goes awry.
