Edit:
Found the issue. I had to switch back to “notebookbar” in the coolwsd.xml, afterwards the documents got opened again as they should and everything is working again normal.
For me it works fine even when <user_interface> / <mode> is set to default or classic.
It might be worth checking if you see any errors in the browser console if you switch the setting back.
Problem still persists, but only with Firefox. Chromium is fine. For me it also seems that it is only happening with .doc, docx, and .odt files, or so to say with Writer. Calc and Impress seem to be fine.
Here are some screenshots from the console, hope it helps.
Edit:
Believe it or not, this “hanging up” does not happen with a public link generated by Nextcloud itself. It only happens when im actually logged in. I have no clue…
Any chance of an account on your box for testing ? if so mail michael.meeks@collabora.com - thanks ! I’d say use a shared-link, but seemingly that works. Very odd that it is FF specific.
_hideWizard: function () {
this.removeContainer();
if (app.sectionContainer) {
app.sectionContainer.getSectionWithName(L.CSections.CommentList.name).removeHighlighters();
app.sectionContainer.getSectionWithName(L.CSections.CommentList.name).layout()
at this point L.CSections.CommentList.name is “comment list” and app.sectionContainer is non-null, but its members sectionContainers.sections is an empty list, sectionsDirty is false and windowSectionList is also []
So looks like rather an under-initialized CanvasSectionsContainer. So - I guess some early start race (?). Stack trace is:
