After a recent upgrade to collaboraonline from packages, I’ve got a problem that’s similar to topic 1031. When I try to open any file on any platform with either Firefox or a Chromium based browser it either stays “Loading …” at 0% or it complains it can’t connect to the server. All other indications are that it can, in fact, connect to the server at least to get to the initial screen.
The current version of collaboraoffice is 21.06.30-1 with coolwsd at 21.11.5.1-1 and code-brand at 21.11-27. I’m running on Debian 11 with Apache2. The Nextcloud app is version 4.2.7 and I’m running Nextcloud 22.2.8.
I’m getting the following errors from journalctl:
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629422 2022-06-06 10:42:04.061069 -0400 [ websrv_poll ] WRN DocBroker with docKey [https://myhostname.org:443/index.php/apps/richdocuments/wopi/files/<mydocumentstring>] is unloading. Rejecting client request to load.| wsd/COOLWSD.cpp:2993
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629422 2022-06-06 10:42:04.061689 -0400 [ websrv_poll ] ERR Error while handling Client WS Request: Failed to create DocBroker with docKey [https://myhostname.org:443/index.php/apps/richdocuments/wopi/files/<mydocumentstring>].| wsd/COOLWSD.cpp:4437
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629422 2022-06-06 10:42:04.061712 -0400 [ websrv_poll ] WRN #32 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| net/WebSocketHandler.hpp:793
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629422 2022-06-06 10:42:04.061729 -0400 [ websrv_poll ] ERR #32: attempted to remove: 999 which is > size: 0 clamped to 0| net/Socket.hpp:1224
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629422 2022-06-06 10:42:04.061742 -0400 [ websrv_poll ] WRN Ignoring attempted read from 32| net/Socket.hpp:1102
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629422 2022-06-06 10:42:04.062285 -0400 [ websrv_poll ] ERR #32 Error while handling poll at 0 in websrv_poll: #32BIO error: 337690831, rc: -1: error:1420C0CF:SSL routines:ssl_write_internal:protocol is shutdown:
Jun 06 10:42:04 myhost coolwsd[2629394]: 140510303516416:error:1420C0CF:SSL routines:ssl_write_internal:protocol is shutdown:../ssl/ssl_lib.c:1935:
Jun 06 10:42:04 myhost coolwsd[2629394]: | net/Socket.cpp:450
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629407 2022-06-06 10:42:04.519873 -0400 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/COOLWSD.cpp:3079
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2629407 2022-06-06 10:42:04.519905 -0400 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/COOLWSD.cpp:3079
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2631483 2022-06-06 10:42:04.620991 -0400 [ docbroker_005 ] ERR No acceptable WOPI hosts found matching the target host [myhostname.org] in config.| wsd/Storage.cpp:259
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2631483 2022-06-06 10:42:04.621050 -0400 [ docbroker_005 ] ERR loading document exception: No acceptable WOPI hosts found matching the target host [myhostname.org] in config.| wsd/DocumentBroker.cpp:2216
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2631483 2022-06-06 10:42:04.621067 -0400 [ docbroker_005 ] ERR Failed to add session to [https://myhostname.org:443/index.php/apps/richdocuments/wopi/files/<mydocumentstring>] with URI [https://myhostname.org/index.php/apps/richdocuments/wopi/files/<mydocumentstring>?access_token=ZQkJJ2Zc9XhNSbcvQbAELOSRciFmO2Uk&access_token_ttl=0&permission=edit]: No acceptable WOPI hosts found matching the target host [myhostname.org] in config.| wsd/DocumentBroker.cpp:2178
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2631483 2022-06-06 10:42:04.621083 -0400 [ docbroker_005 ] ERR Unauthorized Request while starting session on https://myhostname.org:443/index.php/apps/richdocuments/wopi/files/<mydocumentstring> for socket #21. Terminating connection. Error: No acceptable WOPI hosts found matching the target host [myhostname.org] in config.| wsd/COOLWSD.cpp:4394
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2631483 2022-06-06 10:42:04.621160 -0400 [ docbroker_005 ] WRN Ignoring attempted read from 21| net/Socket.hpp:1102
Jun 06 10:42:04 myhost coolwsd[2629394]: wsd-2629394-2631483 2022-06-06 10:42:04.621179 -0400 [ docbroker_005 ] ERR Invalid or unknown session [014] to remove.| wsd/DocumentBroker.cpp:2261
My next step is to load the prior version 21.06.29-1 as I have all the debs cached and see if that fixes anything. I’m hoping I can change something in my coolwsd.xml to try to fix this.
Let me know what other information I can provide.
