Cells Protection not available
I’m trying to protect cells by clicking Format - Cells and then click the Cell Protection tab.
But this doesn’t work. So I read the helpguide in ‘Collabora Help’ and is instructed to go to the Tools - Protect sheets menu to protect the whole sheet, but there is no entry in my Tools menu.
How can I solve it? Are there any external applications?
What the Tools menu should look like: tools1 — ImgBB (I guess)
How is my Tools menu: tools2 — ImgBB (Strumenti = Tools)
Hi ThatsMarco,
Your observation is correct.
Cell protection is respected, but the UI to turn it on/off, needs to be added…
Sorry for that :slight_smile:
Cor
Thank you for your reply! I imagined there was something like that
How can I activate it? Searching online in these hours I couldn’t find any answer, thanks to the forums :smiling_face_with_tear:
Sorry that my answer was almost but not fully clear :wink:
You can activate Sheet protection on desktop only currently. And that will work online.
For activating in Online, you should take a (deep?) dive here https://collaboraonline.github.io/ :slight_smile:
Thank you so much! I will write here the solution I will find to help someone else who will immerse himself in this topic :slight_smile:
+1
I was looking for the same problem and landed here. Hope it will be implemented soon, thanks.
