I’m trying to understand how Cell Protection works. I’m using CODE in Nextcloud, and by some random actions I have achieved what I needed with one sheet, but I cannot do this again.
I want to protect some cells, but not all.
The video here Unlock the Power of Sheet Protection in Collabora Online! is not at all helpful, nor the text.
I would imagine that I would
- Select the cells I want to Protect
- Format > Format cells > Protected
- Review > Protect Sheet > Allow users of this sheet to “Select unprotected cells”
This workflow locks the whole sheet.
The video doesn’t show that complete workflow, so it’s not possible to see what I am doing wrong.
This page https://www.collaboraonline.com/blog/unlocking-protection-with-locked-cells-in-collabora-online/ has the following instructiuons, that again do not make sense to me.
** Go to the “Context” menu of the sheet tab – or go to the tab “Review” > “Protect Sheet”;*
** You can set a password in the dialogue, but this is not mandatory;*
** Click “OK” to apply sheet protection – notice the lock icon on the tab; this indicates that the sheet protection is active;*
** To customize cell protection, navigate to “Format” > “Format Cells”, and then select the “Cell Protection” tab;*
** Cell Protection is automatically enabled and works when the sheet is protected – you can adjust settings to unprotect cells, hide them, and more;*
** In addition to protecting cell content, you can also control whether users are allowed to insert or delete columns and rows;*
Sheet protection is easy to use and helps you stay in control of collaboration.
Can anyone help me please?
