I’m trying to install CODE via Linux packages using this guide Setting up and configuring native CODE packages on Linux - Collabora Office and Collabora Online but, when trying to start it, it starts and crash right away.
root@onlineoffice-dc:/etc/apt/sources.list.d# sudo systemctl start coolwsd
root@onlineoffice-dc:/etc/apt/sources.list.d# sudo systemctl status coolwsd
● coolwsd.service - Collabora Online WebSocket Daemon
Loaded: loaded (/lib/systemd/system/coolwsd.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2022-11-05 18:46:56 EDT; 4ms ago
Main PID: 26084 ((coolwsd))
Tasks: 1 (limit: 2237)
Memory: 136.0K
CPU: 908us
CGroup: /system.slice/coolwsd.service
└─26084 "(coolwsd)"
Nov 05 18:46:56 onlineoffice-dc systemd[1]: Started Collabora Online WebSocket Daemon.
× coolwsd.service - Collabora Online WebSocket Daemon
Active: failed (Result: core-dump) since Sat 2022-11-05 18:46:59 EDT; 1s ago
Process: 26096 ExecStart=/usr/bin/coolwsd --version --o:sys_template_path=/opt/cool/systemplate --o:child_root_path=/opt/cool/child-roots --o:file_server_root_path=/usr/share/coolwsd (code=dumped, signal=ABRT)
Main PID: 26096 (code=dumped, signal=ABRT)
CPU: 1.106s
Nov 05 18:46:59 onlineoffice-dc systemd[1]: coolwsd.service: Main process exited, code=dumped, status=6/ABRT
Nov 05 18:46:59 onlineoffice-dc systemd[1]: coolwsd.service: Failed with result 'core-dump'.
Nov 05 18:46:59 onlineoffice-dc systemd[1]: coolwsd.service: Consumed 1.106s CPU time.
Nov 05 18:46:59 onlineoffice-dc systemd[1]: coolwsd.service: Scheduled restart job, restart counter is at 5.
Nov 05 18:46:59 onlineoffice-dc systemd[1]: Stopped Collabora Online WebSocket Daemon.
Nov 05 18:46:59 onlineoffice-dc systemd[1]: coolwsd.service: Start request repeated too quickly.
Nov 05 18:46:59 onlineoffice-dc systemd[1]: Failed to start Collabora Online WebSocket Daemon.
If logs are required, which ones should I post here?
I’m running Ubuntu Server 22.04 x64 and it is fully updated.
Thank-you,
Guillaume
