CODE is running an old version despite docker container is stopped
I have a strange situation. I recently updated NextCloud to Nextcloud Hub 9 (30.0.1) and I also pulled the last collabora CODE from dockerhub. Before the installation everything was working fine. The container is stuck restarting and the logs show the following
wsd-00001-00001 2024-10-18 14:20:25.932190 +0000 [ coolwsd ] WRN  File not found: Private key file: /etc/coolwsd/proof_key
No proof-key will be present in discovery.
If you need to use WOPI security, generate an RSA key using this command:
    sudo coolconfig generate-proof-key
or if your config dir is not /etc, you can run ssh-keygen manually:
    ssh-keygen -t rsa -N "" -m PEM -f "/etc/coolwsd/proof_key"
Note: the proof_key file must be readable by the coolwsd process.| wsd/ProofKey.cpp:151
wsd-00001-00001 2024-10-18 14:20:25.933337 +0000 [ coolwsd ] TRC  #14: Created socket. Thread affinity set to 0x7fa973cbc880| net/Socket.hpp:384
wsd-00001-00001 2024-10-18 14:20:25.933349 +0000 [ coolwsd ] ERR  #14: Failed to bind to: IPv6 port: 9980 (EADDRINUSE: Address already in use)| net/Socket.cpp:1048
Failed to listen on Server port(s) (9980-9980). Exiting
wsd-00001-00001 2024-10-18 14:20:25.933370 +0000 [ coolwsd ] TRC  #14: Socket dtor| net/Socket.hpp:150
wsd-00001-00001 2024-10-18 14:20:25.933379 +0000 [ coolwsd ] DBG  #14: Closed socket to []| net/Socket.hpp:155
wsd-00001-00001 2024-10-18 14:20:25.933401 +0000 [ coolwsd ] FTL  Failed to listen on Server port(s) (9980-9980). Exiting| wsd/COOLWSD.cpp:4253
Forced Exit with code: 70
wsd-00001-00001 2024-10-18 14:20:25.933423 +0000 [ coolwsd ] FTL  Forced Exit with code: 70| common/Util.cpp:819
After stopping and even removing the docker container, I can still edit documents using CODE, however it is running an older version
COOLWSD version:
23.05.8.4
git hash:
96e80a8
(E)
LOKit version:
built on
a great technology base
Collabora Office 23.05.8.4
git hash:
c5262f7
Served by:
Debian GNU/Linux 12 (bookworm)
b350cfe7
Copyright © 2024, Collabora Productivity Limited.
I’ve also checked what executable is using the port 9980 and I get this:
COMMAND     PID            USER   FD   TYPE     DEVICE SIZE/OFF NODE NAME
coolwsd 4132447 systemd-network   15u  IPv6 1552036625      0t0  TCP *:9980 (LISTEN)
coolwsd 4132447 systemd-network   18u  IPv6 1554435485      0t0  TCP localhost.localdomain:9980->localhost.localdomain:33886 (ESTABLISHED)
nginx   4162783           nginx   83u  IPv4 1554434798      0t0  TCP localhost.localdomain:33886->localhost.localdomain:9980 (ESTABLISHED)
and the executable location points to /usr/bin/coolwsd (executing readlink -f /proc/4132447/exe)
Is Nextcloud somehow running an old CODE version? Visiting the UI on nextcloud/index.php/settings/admin/richdocuments shows the following (I configured it to use my own server):
Collabora Online server is reachable.
Collabora Online Development Edition 23.05.8.4 96e80a8
and the URLs shown are also the correct ones. Does anyone have a clue what could be possibly happening? Thank you
Update:
After killing the process it respawns again, but the command systemctl status coolwsd yields Unit coolwsd.service could not be found. and I have made sure the docker daemon is not running.
What else could be executing collabora code?
I managed to get the latest version running.
What I did was ‘sudo snap disable docker’ and then ‘sudo snap enable docker’ and somehow that allowed me to install the latest image and run it without an issue.
Awesome @Angel it seems you have solved the problem all by yourself.
Kudos :tada:
