Collabora and Nextcloud on Proxmox LXC odd issue
I am experiencing a rather frustrating problem that has me at my wits end using CODE as a Document Editor with Nextcloud. FYI I tried entering the urls in a more readable fashion and was told I couldn’t post that many links because this is my first post.
I have a Nextcloud instance in a Proxmox LXC that I have maintained for years for myself and family members at cloud dot domain1. I have a Collabora instance on a separate LXC that has been working since I set it up at collabora dot mydomain. Both servers are running behind a Caddy reverse proxy that is handling SSL. Collabora is set up with SSL false, and termination true. I can create and edit documents from the browser, a tablet, a phone, etc… and I’m pleased with the system.
Recently I started working on setting up another Nextcloud server for a local volunteer organization that I work with, so we can digitize our documentation and stop printing mountains of paper. The Nextcloud instance is setup exactly as my original instance only at cloud dot domain2 and it is working fine for file sharing purposes. However, I have setup a 2nd Collabora instance at collabora2 dot mydomain and it simply does not work.
All 4 LXC containers are running on the same physical server and storage space. I have confirmed that the Caddy reverse proxy configuration is identical for both collabora instances other than the hostname and IP address.
In my investigations I have discovered several oddities. I do not know which of these items might be relevant so I am including them all here.
1: If I go to the Office settings in either Nextcloud server I can enter either collabora dot mydomain or collabora2 dot mydomain and I get a Green symbol and a message that the server is connected correctly. This apparently doesn’t mean what one would think it means.
2: cloud dot domain1 can connect to collabora dot mydomain even if it is NOT listed as a host in the coolwsd.xml file.
3: cloud dot domain2 cannot connect to collabora dot mydomain even if it IS listed as a host in the coolwsd.xml file.
4: Neither cloud dot domain1 or cloud dot domain2 can connect to collabora2 dot mydomain, whether they are listed as hosts or not.
5: I tried the “groups” setting instead of “first” on both collabora and collabora2, That made no difference.
6: If I go to https://collabora.mydomain.net/hosting/discovery? or https://collabora2.mydomain.net/hosting/discovery? I get identical output, other than the extra digit in the hostname.
7: I have checked the error logs and I’m seeing these errors in journalctl on both the working and non-working collabora instances when I attempt to open a document.
Dec 31 10:53:29 collabora coolwsd[783]: kit-00783-00696 2022-12-31 10:53:29.347688 -0500 [ kit_spare_003 ] ERR  mknod(/opt/cool/child-roots/Q011lXWcQqd6JKsM//tmp/dev/random) failed. Mount must not use nodev flag. (EPERM: Operation not permitted)| common/JailUtil.cpp:300
Dec 31 10:53:29 collabora coolwsd[783]: kit-00783-00696 2022-12-31 10:53:29.347963 -0500 [ kit_spare_003 ] ERR  mknod(/opt/cool/child-roots/Q011lXWcQqd6JKsM//tmp/dev/urandom) failed. Mount must not use nodev flag. (EPERM: Operation not permitted)| common/JailUtil.cpp:312
Dec 31 10:53:54 collabora coolwsd[709]: Forced Exit with code: 0
Dec 31 10:53:54 collabora coolwsd[709]: kit-00709-00696 2022-12-31 10:53:54.761138 -0500 [ kitbroker_002 ] FTL  Forced Exit with code: 0| common/Util.cpp:1117
Dec 31 10:53:55 collabora coolwsd[792]: /usr/bin/coolmount: forced unmount of [/opt/cool/child-roots/YusWWkirppN2wquq/lo] failed: Permission denied.
Dec 31 10:53:55 collabora coolwsd[794]: /usr/bin/coolmount: forced unmount of [/opt/cool/child-roots/YusWWkirppN2wquq] failed: Permission denied.
Even with these errors the document opens just fine on cloud dot domain1 when it is pointed at collabora dot mydomain. The document fails to load on cloud dot domain1 when it is pointed at collabora2 dot mydomain, and fails to load on cloud dot domain2 when pointed at either collabora instance.
8: On collabora2 dot mydomain I also get these errors in journalctl when I attempt to open a document and it fails to load. I am leaving the errors that show up on both instances in case the sequence helps diagnose anything.
Dec 31 11:02:59 collabora2 coolwsd[635]: kit-00635-00510 2022-12-31 11:02:59.991314 -0500 [ kit_spare_003 ] ERR  mknod(/opt/cool/child-roots/daVducP88W8Nmkhw//tmp/dev/random) failed. Mount must not use nodev flag. (EPERM: Operation not permitted)| common/JailUtil.cpp:300
Dec 31 11:02:59 collabora2 coolwsd[635]: kit-00635-00510 2022-12-31 11:02:59.991556 -0500 [ kit_spare_003 ] ERR  mknod(/opt/cool/child-roots/daVducP88W8Nmkhw//tmp/dev/urandom) failed. Mount must not use nodev flag. (EPERM: Operation not permitted)| common/JailUtil.cpp:312
Dec 31 11:03:29 collabora2 coolwsd[503]: wsd-00503-00634 2022-12-31 11:03:29.624351 -0500 [ docbroker_002 ] ERR  WOPI::CheckFileInfo failed for URI [https://cloud.domain2.net/index.php/apps/richdocuments/wopi/files/671_ocdap12jokzu?access_token=VFiLJxEwmxzISPUBG08GUH76Lr8nEtHc&access_token_ttl=1672538578000]: 0 . Headers:         Body: []| wsd/Storage.cpp:687
Dec 31 11:03:29 collabora2 coolwsd[503]: wsd-00503-00634 2022-12-31 11:03:29.624555 -0500 [ docbroker_002 ] ERR  loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2339
Dec 31 11:03:29 collabora2 coolwsd[503]: wsd-00503-00634 2022-12-31 11:03:29.624615 -0500 [ docbroker_002 ] ERR  Failed to add session to [https://cloud.domain2.net:443/index.php/apps/richdocuments/wopi/files/671_ocdap12jokzu] with URI [https://cloud.domain2.net/index.php/apps/richdocuments/wopi/files/671_ocdap12jokzu?access_token=VFiLJxEwmxzISPUBG08GUH76Lr8nEtHc&access_token_ttl=1672538578000]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:2301
Dec 31 11:03:29 collabora2 coolwsd[503]: wsd-00503-00634 2022-12-31 11:03:29.624671 -0500 [ docbroker_002 ] ERR  Storage error while starting session on https://cloud.domain2.net:443/index.php/apps/richdocuments/wopi/files/671_ocdap12jokzu for socket #19. Terminating connection. Error: WOPI::CheckFileInfo failed: | wsd/COOLWSD.cpp:4734
Dec 31 11:03:29 collabora2 coolwsd[503]: wsd-00503-00634 2022-12-31 11:03:29.631761 -0500 [ docbroker_002 ] ERR  #31: Read failed, have 0 buffered bytes (ECONNRESET: Connection reset by peer)| net/Socket.hpp:1133
Dec 31 11:03:29 collabora2 coolwsd[640]: /usr/bin/coolmount: forced unmount of [/opt/cool/child-roots/vpNptFYoRj8GewNe/lo] failed: Permission denied.
Dec 31 11:03:29 collabora2 coolwsd[642]: /usr/bin/coolmount: forced unmount of [/opt/cool/child-roots/vpNptFYoRj8GewNe] failed: Permission denied.
Dec 31 11:03:30 collabora2 coolwsd[643]: kit-00643-00510 2022-12-31 11:03:30.299400 -0500 [ kit_spare_004 ] ERR  mknod(/opt/cool/child-roots/UUTkZdJLthVfvRD5//tmp/dev/random) failed. Mount must not use nodev flag. (EPERM: Operation not permitted)| common/JailUtil.cpp:300
Dec 31 11:03:30 collabora2 coolwsd[643]: kit-00643-00510 2022-12-31 11:03:30.299612 -0500 [ kit_spare_004 ] ERR  mknod(/opt/cool/child-roots/UUTkZdJLthVfvRD5//tmp/dev/urandom) failed. Mount must not use nodev flag. (EPERM: Operation not permitted)| common/JailUtil.cpp:312
I have gone over the configuration files and file and directory permissions on all 4 containers and everything seems to match perfectly whether it is a working combination or not.
I also spun up a full Collabora VM in case the containerization was causing anything. I get the same errors there so that’s not it.
I have rebuilt the Collabora LXC multiple times following the official directions and several online tutorials in case there was a missing step, and no matter how I go through it nothing I create works with either cloud dot domain1 or cloud dot domain2. At this point I would be ready to say that it will never work except that I have indisputable evidence that it’s possible since collabora dot domain is still working with cloud dot domain1.
Any ideas what would be causing the storage errors and other errors referenced in the log?
What else can I check here to get this working? Is there anything else I can be checking on the nextcloud side to further investigate?
So I discovered something new which has me even more confused.
cloud dot domain1 has an IP of x.x.30.207
collabora dot mydomain has an IP of x.x.30.206
cloud dot domain2 has an IP of x.x.205
collabora2 dot mydomain has an IP of x.x.30.204
My Caddy reverse proxy is at x.x.30.201
As noted in my first post, with this setup cloud dot domain worked with collabora dot mydomain but no other combinations did.
I found that if I changed the IP of collabora dot mydomain to anything besides x.x.30.206, and update the proxy to forward correctly, Office on cloud dot domain1 stopped working. I know the proxy is routing to the new IP correctly because browsing to https://collabora.mydomain.net/hosting/discovery still returns the same information.
I have also discovered that if I shut down collabora dot mydomain, and then change the IP of collabora2 dot mydomain to x.x.30.206, I can then point cloud dot domain1 at collabora2 dot mydomain and it works! Unfortunately cloud2 dot domain still will not work.
Oddly enough, after changing collabora2 dot mydomain back to x.x.30.204 and restarting collabora dot mydomain I can now connect to either collabora or collabora2 from cloud dot domain1, but cannot connect to either of them from cloud dot domain2.
This leads me to believe that I have both instances of collabora configured correctly but for some reason cloud dot domain2 has some configuration difference that I have been unable to discover which is causing it to fail. I will post about this on the Nextcloud forums but would still be interested in hearing if anyone else is using a similar setup and how they have gotten it working.
likely you have some networking issue. take a look at this article and work through troubleshooting steps:
Thank you! This helped me pin down and resolve the issue.
Everything panned out until this step:
from Collabora verify access to Nextcloud UI (from console run `curl https://cloud.mydomain/status.php` )
I found that neither collabora server would get a response to this from cloud dot domain2
After examining a packet capture I found that the traffic was being routed to my router and disappearing into a black hole, rather than going to my reverse proxy, which pointed to a DNS issue. Every other way I could test DNS everything appeared to be correct, but when I ran out of other ideas I simply deleted the DNS entry for cloud dot domain2 and then added it back, and now this is working! I don’t know what changed but your link got me there and I appreciated it!
