Sync-in Server on openmediavault 8
Openmediavault (OMV) is an open-source network attached storage (NAS) solution based on Debian Linux.
Sync-in is an open-source platform to store, share, collaborate, and sync files.
Among many other features, Sync-in includes WebDAV integration, as well as collaborative documents editing through integrations with Collabora Online and OnlyOffice. Openmediavault offers a wide range of network storage related services, as well as Kubernetes and Compose plugins for installing containerized apps.
This guide describes the steps towards installing Sync-in Server and Collabora Online as separate docker containers on an openmediavault 8 system, using its Docker Compose plugin as well as Nginx Proxy Manager (NPM) to expose the private network Web services to the internet.
Background
The Sync-in Server installation guide describes an elaborate hands-on process of downloading the latest release, issuing curl commands, modifying the configuration file ‘envrionment.yaml’, modifying the file ‘compose.yaml’ and issuing commands, all of which not being my cuppa tea.
As no Sync-in compose file is offered, I set towards attempting to integrate this process into openmediavault Compose. I had hopes of incorporating the ‘environment.yaml’ into compose environment variables, but alas that will not do, as Sync-in components will require access to this file during the setup process. As a result, this guide will involve some manual steps, as well as editing the Sync-in configuration file ‘environment.yaml’.
Prerequisites
- An openmediavault 8 NAS set up and running
- With Docker Compose plugin installed
- With Nginx Proxy Manager docker container installed and running
- Remote access to the NAS using Filezilla or WinSCP
Outline of steps
- Installation of Sync-in docker using Compose
- Proxy Host configuration for Sync-in using NPM
- Installation of Collabora Online docker using Compose
- Proxy Host configuration for Collabora Online using NPM
1. Installation of Sync-in docker using Compose
- Download the latest ‘sync-in-compose.zip’ from Sync-in server releases to your PC
- Also download the full Sync-in ‘environment.dist.yaml’ configuration template
- Open your openmediavault workbench - Services - Compose - Files
- Create a new Compose file called ‘sync-in-docker’
- Copy the contents of the ‘docker-compose.yaml’ from the zip file into the OMV Compose File editor
- Save the newly created compose file for now
- Compose will now have created a folder ‘/appdata/sync-in-docker’ with some files
- Use Filezilla/WinSCP to remote access this folder ‘/appdata/sync-in-docker’
- Copy the contents of the downloaded ‘sync-in-compose.zip’ in there, which will result in the following structure:
/appdata/sync-in-docker/
├── config
│ ├── collabora
│ │ └── docker-compose.collabora.yaml
│ ├── nginx
│ │ ├── collabora.conf
│ │ ├── docker-compose.nginx.yaml
│ │ ├── nginx.conf
│ │ └── onlyoffice.conf
│ ├── onlyoffice
│ │ └── docker-compose.onlyoffice.yaml
│ └── sync-in-desktop-releases
│ ├── docker-compose.sync-in-desktop-releases.yaml
│ └── update.sh
├── docker-compose.yaml
└── environment.yaml
- (Much of this will not be used, but does offer a nice reference)
- Skipping the default minimal setup and going full whammy right away;
open the file ‘environment.yaml’ and replace its full contents with that of the downloaded ‘environment.dist.yaml’ - Search for the following items and edit these ALL_CAPS valueas with your own (random generated) ones:
mysql:
url: 'mysql://root:ALPHANUMERIC_DB_KEY@mariadb:3306/sync_in'
auth:
encryptionKey: 'ALPHANUMERIC_ENCRYPTION_KEY'
token:
access:
secret: 'ALPHANUMERIC_ACCESS_KEY'
refresh:
secret: 'ALPHANUMERIC_REFRESH_KEY'
applications:
files:
dataPath: /app/data # Sync-in internal data path. Needs to be exposed to SMB share in Compose
sampleDocuments: [opendocument, microsoft]
enabled: true
externalServer: https://collabora.YOUR-DOMAIN.TLD
- Return to the OMV workbench - Services - Compose - Files
- Edit the compose file ‘sync-in-docker’ as follows, changing the ALL_CAPS credentials for your own:
include:
# - ./config/nginx/docker-compose.nginx.yaml # Not installed, as we'll be using Nginx Proxy Manager (NPM)
# - ./config/collabora/docker-compose.collabora.yaml # To be installed separately, not included
# - ./config/onlyoffice/docker-compose.onlyoffice.yaml # To be installed separately, not included
# Enable the next line when applications.appStore.repository in environment.yaml is set to 'local'
# - ./config/sync-in-desktop-releases/docker-compose.sync-in-desktop-releases.yaml
sync_in:
image: syncin/server:2
container_name: sync-in
restart: always
- PUID=${{ uid:"appuser" }} # omv user 'appuser'
- PGID=${{ gid:"users" }} # omv usergroup 'users'
- TZ=${{ tz }} # omv system time zone
- INIT_ADMIN=true
- INIT_ADMIN_LOGIN=SYNC-IN-ADMIN # AVOID $, / or other special characters that may trigger undesired parsing
- INIT_ADMIN_PASSWORD=SYNC-IN-PASS # AVOID $, / or other special characters that may trigger undesired parsing
- 8080:8080 # External port:Internal port as defined in environment.yaml
- ./environment.yaml:/app/environment/environment.yaml # IMPORTANT: environment.yaml is required for sync-in internals
- ${{ sf:"data" }}/sync-in:/app/data # omv share 'data'/sync-in:internal dataPath as defined in environment.yaml
# Location for desktop releases if appStore is set to local in environment.yaml
- ${{ sf:"data" }}/sync-in/desktop_releases:/app/static/releases:ro
depends_on:
- mariadb
logging:
driver: json-file
options:
max-size: 25m
max-file: 5
- sync_in_network
- web-proxy # Common docker bridge network re. Nginx Proxy Manager
mariadb:
image: mariadb:11
container_name: mariadb
restart: always
command: --innodb_ft_cache_size=16000000 --max-allowed-packet=1G
MYSQL_ROOT_PASSWORD: ALPHANUMERIC_DB_KEY # Same ALPHANUMERIC_DB_KEY as in mysql.url in environment.yaml
MYSQL_DATABASE: sync_in
- mariadb_data:/var/lib/mysql
- sync_in_network
sync_in_network:
name: sync_in_network # IMPORTANT: Prevent automatic prefixing of the docker network name
driver: bridge
web-proxy: # Common docker bridge network re. Nginx Proxy Manager
external: true
data:
mariadb_data:
desktop_releases:
- Save the compose file
- Compose Check for issues, Compose Pull and Compose UP
If all is well, Sync-in should be accessible through http://YOUR-SERVER-IP:8080 using above ADMIN credentials.
2. Proxy Host configuration for Sync-in
- Open your Nginx Proxy Manager (NPM) instance
Note: NPM and Sync-in share the same docker bridge network ‘web-proxy’, so we can reference Sync-in by its container name - Create a new Proxy Host:
- Details:
- Domain name: sync-in.YOUR-DOMAIN.TLD
- Scheme: http
- Forward hostname/IP: sync-in
- Forward port: 8080
- Option: Block common exploits
- Option: Websockets support
- SSL:
- SSL Certificate: sync-in.YOUR-DOMAIN.TLD
- Option: Force SSL
- Option: HTTP/2 Support
- Option: HSTS enabled
- Details:
- Save
If all is well, Sync-in will now be accessible as well through https://sync-in.YOUR-DOMAIN.TLD.
3. Installation of Collabora Online docker using Compose
- Create a new Compose file called ‘collabora’ with the following contents:
code:
container_name: collabora
image: collabora/code
restart: always
- user=${{ uid:"appuser" }} # omv user 'appuser'
- username=COLLABORA-ADMIN # AVOID $, / or other special characters that may trigger undesired parsing
- password=COLLABORA-PASSWORD # AVOID $, / or other special characters that may trigger undesired parsing
- dictionaries=de_DE en_GB en_US es_ES fr_FR it nl pt_BR pt_PT ru
# extra_parms (adapted from sync-in collabora compose)
- extra_params=--o:ssl.enable=false --o:ssl.termination=true --o:logging.disable_server_audit=true --o:admin_console.enable=true
- domain=collabora.YOUR-DOMAIN.TLD
- 9980:9980 # Standard port redirection
tty: true # keep the container running, equivalent to -t command line option
cap_drop: # capabilities drop (as per sync-in collabora compose)
- ALL
cap_add: # capabilities add (as per sync-in collabora compose)
- SYS_CHROOT
- SYS_ADMIN
- FOWNER
- CHOWN
logging:
driver: json-file
options:
max-size: 25m
max-file: 5
# volumes: # IMPORTANT: TO BE UNCOMMENTED LATER ON
# - ./coolwsd/coolwsd.xml:/etc/coolwsd/coolwsd.xml:rw # mount local copy of coolwsd.xml config file
- sync_in_network # Common docker bridge network re. Sync-in
sync_in_network:
external: true
web-proxy:
external: true
The following steps are neccessary to make a copy of the docker internal Collabora configuration file into a location that is better accessible. For this the Collabora docker container needs to be UP.
- Use Filezilla/WinSCP to remote access OMV’s /appdata/collabora
- Create a subfolder ‘coolwsd’
- Use the context menu option “Static Custom Commands” - “Enter” and paste the command:
docker cp collabora:/etc/coolwsd/coolwsd.xml ./coolwsd/coolwsd.xml - Check if the file
/appdata/collabora/coolwsd/coolwsd.xmlis in place - Ambitious people can get their hands dirty with advanced Collabora configuration. I didn’t find anything appealing.
- With
/appdata/collabora/coolwsd/coolwsd.xmlin place, Filezilla/WinSCP can be closed
Return to your openmediavault workbench - Services - Compose - Files
- Docker Compose DOWN collabora
- Open the collabora compose file and remove the # comment marks in front of the following two lines:
- Make sure that all indents are consistent, as this is a requirement for compose.yaml files
- Compose Check for issues and Compose UP
4. Proxy Host configuration for Collabora
Note: NPM and Collabora share the same docker bridge network ‘web-proxy’, so we can reference collabora by its container name - Create a new Proxy Host:
- Details:
- Domain name: collabora.YOUR-DOMAIN.TLD
- Scheme: http
- Forward hostname/IP: collabora
- Forward port: 9980
- Custom Locations:
- /browser/
- Scheme: http
- /hosting/
- Scheme: http
- /cool/
- Scheme: http
- /browser/
- SSL:
- SSL Certificate: collabora.YOUR-DOMAIN.TLD
- Option: Force SSL
- Details:
- Save
- In the NPM Proxy Hosts list you can click the newly created host ‘collabora’ and it will open with a mere ‘OK’, indicating its status.
Collabora in itself is a quiet servant
If all is well, you can now create new OpenDocument or Microsoft Office files in Sync-in and open them in Collabora Online.
Result
Sync-in and Collabora Online are now installed as separate docker containers in openmediavault 8 Compose and proxied and SSL-terminated by Nginx Proxy Manager.
The two containers can be managed from Compose. Take note that Collabora is dependant upon sync_in_network, meaning that Collabora can only be UP-ed after Sync-in, and Sync-in cannot be DOWN-ed if Collabora is still up.
Therefor observe the following UP-DOWN cycle:
- UP Sync-in
- UP Collabora
- DOWN Collabora
- DOWN Sync-in
