Add Collabora to Nextcloud's Docker Nginx+LetsEncrypt example
I’ve been fumbling for the past few days to integrate Collabora/CODE into the docker compose example from Nextcloud. The specific example I’m trying to use includes Nginx for reverse proxy, LetsEncrypt for SSL cert, Postgres for DB.
I’m able to get Nextcloud and the Collabora server to communicate using their own network using http without involving the proxy but then found out that if you’re running Nextcloud with SSL, then you must run Collabora with SSL as well.
version: '3'
  app:
    container_name: ns-app
    image: nextcloud:fpm-alpine
    restart: unless-stopped
      - nextcloud:/var/www/html
      - office
      - default
      - POSTGRES_HOST=db
      - REDIS_HOST=redis
      - NEXTCLOUD_ADMIN_USER=Josh
      - NEXTCLOUD_ADMIN_PASSWORD=Pass
      - NEXTCLOUD_TRUSTED_DOMAINS=ns-collabora home.domain.com
    env_file:
      - db.env
    depends_on:
      - db
      - redis
      - collabora
  web:
    container_name: ns-web
    build: ./web
      - nextcloud:/var/www/html:ro
      - VIRTUAL_HOST=home.domain.com
      - LETSENCRYPT_HOST=home.domain.com
      - LETSENCRYPT_EMAIL=josh.g.elias@pm.me
    depends_on:
      - app
      - proxy
      - default
  db:
    container_name: ns-db
    image: postgres:latest
      - db:/var/lib/postgresql/data
    env_file:
      - db.env
  redis:
    container_name: ns-redis
    image: redis:alpine
  cron:
    container_name: ns-cron
    entrypoint: /cron.sh
    depends_on:
      - db
      - redis
  proxy:
    container_name: ns-proxy
    build: ./proxy
      - 80:80
      - 443:443
    labels:
      com.github.jrcs.letsencrypt_nginx_proxy_companion.nginx_proxy: "true"
      - certs:/etc/nginx/certs:ro
      - vhost.d:/etc/nginx/vhost.d
      - html:/usr/share/nginx/html
      - /var/run/docker.sock:/tmp/docker.sock:ro
      - proxy
  letsencrypt-companion:
    container_name: ns-letsencrypt-companion
    image: nginxproxy/acme-companion
      - acme:/etc/acme.sh
      - /var/run/docker.sock:/var/run/docker.sock:ro
      - proxy
    depends_on:
      - proxy
    container_name: ns-collabora
    image: collabora/code:latest #-arm64
      - extra_params=--o:ssl.enable=false
      - 9980:9980
      - office
  db:
  nextcloud:
  certs:
  acme:
  vhost.d:
  html:
  proxy:
  office:
I’m not really sure where to go from this point. My requests to Collabora must be https so they have to go through the proxy. As far as I know though, that nginx/companion setup terminates ssl so I’m not sure how that’s going to work…
I’ll leave my NGINX config here too
worker_processes auto;
error_log  /var/log/nginx/error.log warn;
pid        /var/run/nginx.pid;
events {
    worker_connections  1024;
http {
    include       /etc/nginx/mime.types;
    default_type  application/octet-stream;
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    access_log  /var/log/nginx/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    # Prevent nginx HTTP Server Detection
    server_tokens   off;
    keepalive_timeout  65;
    #gzip  on;
    upstream php-handler {
        server app:9000;
    server {
        listen 80;
        # HSTS settings
        # WARNING: Only add the preload option once you read about
        # the consequences in https://hstspreload.org/. This option
        # will add the domain to a hardcoded list that is shipped
        # in all major browsers and getting removed from this list
        # could take several months.
        #add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
        # set max upload size
        client_max_body_size 512M;
        fastcgi_buffers 64 4K;
        # Enable gzip but do not remove ETag headers
        gzip on;
        gzip_vary on;
        gzip_comp_level 4;
        gzip_min_length 256;
        gzip_proxied expired no-cache no-store private no_last_modified no_etag auth;
        gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
        # Pagespeed is not supported by Nextcloud, so if your server is built
        # with the `ngx_pagespeed` module, uncomment this line to disable it.
        #pagespeed off;
        # HTTP response headers borrowed from Nextcloud `.htaccess`
        add_header Referrer-Policy                      "no-referrer"   always;
        add_header X-Content-Type-Options               "nosniff"       always;
        add_header X-Download-Options                   "noopen"        always;
        add_header X-Frame-Options                      "SAMEORIGIN"    always;
        add_header X-Permitted-Cross-Domain-Policies    "none"          always;
        add_header X-Robots-Tag                         "none"          always;
        add_header X-XSS-Protection                     "1; mode=block" always;
        # Remove X-Powered-By, which is an information leak
        fastcgi_hide_header X-Powered-By;
        # Path to the root of your installation
        root /var/www/html;
        # Specify how to handle directories -- specifying `/index.php$request_uri`
        # here as the fallback means that Nginx always exhibits the desired behaviour
        # when a client requests a path that corresponds to a directory that exists
        # on the server. In particular, if that directory contains an index.php file,
        # that file is correctly served; if it doesn't, then the request is passed to
        # the front-end controller. This consistent behaviour means that we don't need
        # to specify custom rules for certain paths (e.g. images and other assets,
        # `/updater`, `/ocm-provider`, `/ocs-provider`), and thus
        # `try_files $uri $uri/ /index.php$request_uri`
        # always provides the desired behaviour.
        index index.php index.html /index.php$request_uri;
        # Rule borrowed from `.htaccess` to handle Microsoft DAV clients
        location = / {
            if ( $http_user_agent ~ ^DavClnt ) {
                return 302 /remote.php/webdav/$is_args$args;
        location = /robots.txt {
            allow all;
            log_not_found off;
            access_log off;
        # Make a regex exception for `/.well-known` so that clients can still
        # access it despite the existence of the regex rule
        # `location ~ /(\.|autotest|...)` which would otherwise handle requests
        # for `/.well-known`.
        location ^~ /.well-known {
            # The rules in this block are an adaptation of the rules
            # in `.htaccess` that concern `/.well-known`.
            location = /.well-known/carddav { return 301 /remote.php/dav/; }
            location = /.well-known/caldav  { return 301 /remote.php/dav/; }
            location /.well-known/acme-challenge    { try_files $uri $uri/ =404; }
            location /.well-known/pki-validation    { try_files $uri $uri/ =404; }
            # Let Nextcloud's API for `/.well-known` URIs handle all other
            # requests by passing them to the front-end controller.
            return 301 /index.php$request_uri;
        # Rules borrowed from `.htaccess` to hide certain paths from clients
        location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/)  { return 404; }
        location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console)                { return 404; }
        # Ensure this block, which passes PHP files to the PHP process, is above the blocks
        # which handle static assets (as seen below). If this block is not declared first,
        # then Nginx will encounter an infinite rewriting loop when it prepends `/index.php`
        # to the URI, resulting in a HTTP 500 error response.
        location ~ \.php(?:$|/) {
            # Required for legacy support
            rewrite ^/(?!index|remote|public|cron|core\/ajax\/update|status|ocs\/v[12]|updater\/.+|oc[ms]-provider\/.+|.+\/richdocumentscode\/proxy) /index.php$request_uri;
            fastcgi_split_path_info ^(.+?\.php)(/.*)$;
            set $path_info $fastcgi_path_info;
            try_files $fastcgi_script_name =404;
            include fastcgi_params;
            fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
            fastcgi_param PATH_INFO $path_info;
            #fastcgi_param HTTPS on;
            fastcgi_param modHeadersAvailable true;         # Avoid sending the security headers twice
            fastcgi_param front_controller_active true;     # Enable pretty urls
            fastcgi_pass php-handler;
            fastcgi_intercept_errors on;
            fastcgi_request_buffering off;
        location ~ \.(?:css|js|svg|gif)$ {
            try_files $uri /index.php$request_uri;
            expires 6M;         # Cache-Control policy borrowed from `.htaccess`
            access_log off;     # Optional: Don't log access to assets
        location ~ \.woff2?$ {
            expires 7d;         # Cache-Control policy borrowed from `.htaccess`
        location /remote {
            return 301 /remote.php$request_uri;
        location / {
            try_files $uri $uri/ /index.php$request_uri;
