Date: 2026-05-27
Present:
- Caolan, Andria, Andras, Leif, Stephan, Szymon, Michael S, Tomaz, Miklos
Completed action items
File a github issue for the report builder cleanup (Miklos)
File a github issue for the vcl XML-based theming cleanup (Tomaz)
- https://github.com/CollaboraOnline/online/issues/15826 instead (qt removal)
Pending action items
- File a github issue for the canvas / slideshow cleanup (Thorsten)
Monorepo status
CI: Android is now added (Adria)
- release branch, moving from github to gerrit: in progress
CI, still to be added on main: --enable-coplugin, fuzzer, lighthouse
then github online.git: refer to gerrit
Releases (Andras)
CODE 26.04: first RC is tagged already
this week: RC2
Patch review
- Week 22: 220(+17)
- Week 22: 67(-7)
- Week 22: Ardev Prisec, cookiespter, xzlhxc
- Week 22: Caolán McNamara (70), Szymon Kłos (47), Miklos Vajna (42), Noel Grandin (32), Mike Kaganski (14), Stephan Bergmann (11), Tor Lillqvist (11), Mohit Marathe (8), Michael Stahl (7), Tomaž Vajngerl (7)
Bug reporting
- Week 22: 17(+1)
Jenkins / CI update (Szymon)
- need to update tool, it doesn’t work now (api call returns 403)
Week 22: Success rate is 30%, failed builds are 35/50
lot of flatpak jobs are queued (Adria)
- will add more builders to process the backlog faster
Did a tweak to use ccache, it was silently not used (Caolan)
Weird “ci passed”, but it didn’t run everything issue
this only happens when Jenkins crashes (Andras)
config is now set so this won’t be indexed again, so Jenkins won’t get out-of-memory
could we get a failure when some sub-jobs are not built? (Stephan)
- Don’t know off the top of the head (Andras)
Crash testing (Caolan)
2026-05-19 282 (-401, +163)
2026-05-05 547 (-471, +286)
- various fixed, build in progress
–quickstart argument was removed, script used it, didn’t actually execute anything, fixed now
- still using URP, be aware of it before removing URP
TTT talks
Cleanups
Java removal, when will it happen? (Leif)
- It was never there, just currently it’s build-time-disabled (Miklos)
What’s cooking
Michael S
working on an RTF import fix around linked paragraph / character styles
difference between fake property from table style vs real property
Stephan
Noel has an idea around OUString, to change the underlying storage to UTF-8
measuring the effects to see what’s the cost/benefit
Checking dirty pages
What tool do you use? (Caolan)
I tried perf probe on the kernel do_wp_page symbol
Andras
Release Engineering
Options dialog in CODA
Szymon
working on performance regressions (slowness, delay found on testing call)
promising: https://gerrit.collaboraoffice.com/c/online/+/3361
biggest problem, typing and moving comment anchor: https://github.com/CollaboraOnline/online/issues/15845 (in progress)
Quikee
Working on vector rendering, testing each primitive, adding JS renderer for this
- Also a test framework for this
Miklos
- https://github.com/CollaboraOnline/online/issues/15821 “Copying slides between presentations: non-matching slide size copy is not handled”
Caolán
stop refreshing SlideTransitionPane on every shape change, impress perf improvement effort
a11y coverage for impress, notebookbar, sidebars and “common” dialogs merged/in-review. Next impress-only dialogs
