Date: 2026-07-15
Present:
- Szymon, Miklos, Adria, Caolan, Michael S, Tomaz, Noel, Miklos
Completed action items
Only consider online.git main changes when counting gerrit changes (Miklos)
Jenkins: Install PrioritySorter and re-start at the weekend (Adria/Timar)
need to plan this, not yet done; will do it when upgrading Jenkins anyway
ticket is file, no need to track it here anymore (Adria)
Pending action items
Release Engineering update (Adria)
Releases
next: COOL 26.04 next week (Andras)
development can continue on main branch
- Need to explicitly port to 26.04, again
Patch review
Week 29: 220(-64)
The delta is probably not this large, we now exclude non-online or non-main changes (Miklos)
- Week 29: 4(-2)
- Week 29: DatVex, FarmYard Gaming
- Week 29: Caolán McNamara (59), Miklos Vajna (31), Michael Stahl (24), Noel Grandin (20), Tomaž Vajngerl (18), Stephan Bergmann (12), Mike Kaganski (9), Szymon Kłos (7), Andras Timar (7), Tor Lillqvist (6)
Bug reporting
- Week 29: 12(+0)
Jenkins / CI update (Andras)
better state (12 → 17% clean pass)
no cypress test which fails much more than others,
Mohit fixed writer3/reconnect_spec.js it seems
Week 29: Success rate is 34%, failed builds are 33/50
Week 29: Turnaround time is 1 hr 40 min (median of last 48 SUCCESS/FAILURE builds)
Last week CI was out Thu/Fri (Adria)
The fermat builder is now back
Preparing a new almalinux9 builder on another builder, to improve capacity
One new executor for Windows in VM
Crash testing (Caolan)
2026-07-15: 92 (-79, +0)
- progress on the new crashes, and some more of those hopefully fixed in the next pending run
2026-07-08: 171 (-3, +115)
- unfortunate increase in calc issues, various fix efforts merged
TTT talks
What’s cooking
Stephan
- vacation
Quikee
editeng hyperlink handling: turning that from a field into character attributes
have a patch, but need to consider compatibility
this now works nicely when the URL is long enough to not fit into a single line
Miklos
- https://github.com/CollaboraOnline/online/issues/16002 “Writer markdown paste: unexpected join of bullets”
Caolán
new thought on taking 2 minutes off the windows build
CODA-Q Presentations
fix a crash on full-screen presentations
keep last frame visible on slide-end
auto-start videos on slide start
Adrià
Windows Garnder new executors monitoring and pre-warm
Almalinux9 in mersenne – ccache prefetch with sample jobs
VM to execute k6 performance tests
Szymon
done some logs review with weird error in saving, added fix proposal
trying mocha tests for clipboard code:
(fragile, lots of special cases)
working on rendering corruption in Calc
could be edited vs static cell dimension rectangle difference (on tile edge?)
testing now…
Andras
- excused
Michael M
- traveling
Michael S
helped Stephan with GPG removal
security fix backporting & build fixing
