Date: 2026-07-22
Present:
- Adria, Regina, Caolan, Michael M, Michael S, Noel, Stephan, Szymon, Miklos
Completed action items
Pending action items
Documentation on coext ODF extensions (Regina)
See <https://forum.collaboraonline.com/t/cool-tc-meeting-agenda-2026-07-22-16-00-cest/4885/2>
ODF requires documentation for the coext namespace
- LO documents the loext namespace in the TDF wiki
Idea was to copy the relevant pages from the TDF wiki to somewhere on COOL infra (Michael S)
perhaps in git
haven’t gotten around to do that yet
some lightweight markup would be ideal, to have copy easy from/to markdown
dev-notes/ already has developer documentation, hosting it there would be an option (Miklos)
Suggest to came up with a proposal for next week (Michael S)
Releases
COOL 26.04 this week, cp-26.04.2-3 is tagged already
development can continue on main branch
- Need to explicitly port to 26.04, again
Patch review (Miklos)
- Week 30: 174(-46)
- Week 30: 3(-1)
- Week 30: Eli Xu
- Week 30: Caolán McNamara (72), Miklos Vajna (61), Noel Grandin (28), Michael Stahl (17), Tomaž Vajngerl (17), Tor Lillqvist (9), Szymon Kłos (7), Sarper Akdemir (6), Stephan Bergmann (6), Mike Kaganski (5)
Bug reporting
- Week 30: 12(+0)
Jenkins / CI update (Adria)
Week 30: Cypress clean pass: 21%, 567/723 have at least one “retry”
Better than last week
The Windows build broke this week (Regina)
–disable-pch gives you the config which is tested in Jenkins (Miklos)
CI uses ccache, not pch
It is *believed* that ccache and enable-pch don’t work together. But I wonder if that is true (Caolan)
If pch breaks, it’s easy to fix it (Michael S)
Open the pch file, the top of the file has a comment with a commandline to re-run, then it works
Week 30: Success rate is 34%, failed builds are 33/50
Week 30: Turnaround time is 3 hr 16 min (median of last 30 SUCCESS/FAILURE builds)
New Windows instance is added, almalinux9 agents are added (Adria)
Almost all the jobs have more than one host to build on
Crash testing (Caolan)
2026-07-22: 55 (-37, +0)
- more good progress
2026-07-15: 92 (-79, +0)
- progress on the new crashes, and some more of those hopefully fixed in the next pending run
TTT talks
What’s cooking
Stephan
Having working cypress tests locally now (with -j2)
Visual testing finds differences locally where it passes on CI
trying to make a toplevel ‘make check’ work; CI only runs parts of ‘make check’ in separate sub-jobs
Back to scripting / collaboration
Miklos
- https://github.com/CollaboraOnline/online/issues/16018 “Advertise markdown in the discovery XML”, should now be able to open .md files in COOL
Caolán
looking at if the bottlenecks in the non-graphical tests
seems parallelism can be improved there, both inside and outside engine/
Adrià
K6 VM in mersenne for performance and load tests, connected to bee jenkins
configuring new windows agent (gardner) to build coc-25.04 and coc-26.04 builds (online main already working)
**Creating branded CIB Office from co-25.04 branch
Szymon
working on missing invalidations of the rows geometry in Calc
Michael S
poppler and libxml2 updates
libxml2, cmake: does cmake do its own parallelism? (Caolan)
- Not checked (Michael S)
