In coolwsd.xml there is config for Feature Restriction and Feature Locking…
I referred to this video https://www.youtube.com/watch?v=myvXdVNJypY&ab_channel=CollaboraOnline as well where it is described.
and have prepared and save the code in coolwsd.xml file but its not working…
<feature_lock>
<locked_hosts allow="true">
<fallback read_only="false" disabled_commands="true"/>
</locked_hosts>
<locked_commands>.uno:Bold</locked_commands>
<is_lock_readonly>false</is_lock_readonly>
</feature_lock>
<restricted_commands>.uno:Italic</restricted_commands>
none of them is working. Setup environment NextCloud plus collab/code
Hello @ANKUSHJAIN91,
For the feature lock or restriction to function, it’s essential that our Collabora build includes the --enable-feature-lock flag. online/configure.ac at master · CollaboraOnline/online · GitHub
for example:
./configure --enable-silent-rules --with-lokit-path=${LOCOREPATH}/include \
--with-lo-path=${LOCOREPATH}/instdir \
--enable-debug --enable-cypress --enable-feature-lock
Could you please share your configuration details? Have you enabled this flag in your setup?
Thank you,
@ANKUSHJAIN91 I’d like to mention an additional point:
- If you require feature restriction, you’ll also need to include
--enable-feature-restriction for it to function properly.
Apologies for missing this earlier.
Thanks Darshan for replying back
here is my config in collwsd
<feature_lock>
</locked_hosts>
</feature_lock>
do I need to set below while creating the collabora docker container ??
–with-lo-path=${LOCOREPATH}/instdir
–enable-debug --enable-cypress --enable-feature-lock
like this ??
version: ‘3’
code:
image: collabora/code:latest
restart: always
- password=${COLLABORA_PASSWORD}
- username=${COLLABORA_USERNAME}
- aliasgroup1=https://****:443
- server_name=*****
- extra_params=--o:ssl.enable=true
**- enable-feature-lock = true**
- 9980:9980
- proxy
proxy:
external: true
@ANKUSHJAIN91 You need to pass this flag in the same way you handle other flags like SSL. Please conduct some research and use a trial-and-error approach to understand how it is configured in coolwsd.xml using Docker variables.
@ANKUSHJAIN91, you can mount a volume in Docker to include your custom coolwsd.xml settings.
For example:
- /path/to/your/coolwsd.xml:/etc/coolwsd/coolwsd.xml
