Property wopi host allow not working/filtering
Hello
I am running CODE on dedicated ubuntu 20 with apache2 reverse proxy; installed with packages for ubuntu.
If I set in coolwsd.xml the wopi-host-option
(-host desc=“hostname to allow or deny.” allow=“true”-)scheme://hostname:port(-/host-)
(- instead of <
with right or wrong server names I can always open documents from our Nextcloud server. This means that everybody can use our CODE server.
What did I overlook?
Thanks for reading and answering.
@uliulmer You need to enable groups options then only it will consider the host entries
Let me paste the example configuration:
          <alias_groups mode="groups">
                <group>
                    <host allow="true">https://mydomain.com:443</host>
                </group>
            </alias_groups>
More info why mode needs to be changed to groups check description in coolwsd.xml about alias_groups
Let me know if It works as expected : )
More info on sdk: Configuration — SDK https://sdk.collaboraonline.com/ documentation
Thank you very much, it didn’t work
I can still access from an different server name (alias) and Admin Console shows both wopi hosts.
Is there a possibility
  • to check the configuration
  • to see with config properties are in the running coolwsd
    Thanks a lot
forgot to change <!– (and end of comment) to
now it works
Thank you very much
@uliulmer glad it worked : )
