I’ve just inherited a Collabora codebase and trying to understand how the ui_defaults input works.
I’d ideally like to start the PowerPoint/ Presentations app in compact mode but I’m unable to get the following to work.
<form id="office_form" name="office_form" target="office_frame" action="@Model.ActionUri" method="post" style="display: none;">
<input name="access_token" value="@Model.AccessToken" type="hidden" />
<input name="access_token_ttl" value="@Model.AccessTokenTtl" type="hidden" />
<input name="ui_defaults" value="UIMode=compact;" type="hidden" />
</form>
@section scripts
<script type="text/javascript">
document.getElementById('office_form').submit();
This was based off the following help topic - Making sure you're not a bot!
Any help would be very much appreciated
