I hope that the user cannot zoom in and out of the excel document, and the opened excel is the size ratio I specify.
Hey @FLG292,
Welcome to the forum. ![]()
I’m not sure I understand.
What exactly are you trying to disable and why? Can you maybe use a screenshot to explain what you mean?
If I’m understanding you correctly, you want someone:
- To be able to open a spreadsheet (ODS file)
- To be forced at XX% zoom level by default
- For example, 125% zoom.
- And not be able to change it?
Zoom is very important for other devices—like on Mobile devices—or for Accessibility reasons (users with poor eyesight must be able to make the fonts much larger).
I don’t understand why a key feature should be disabled, but maybe I don’t understand your use-case or context.
