Large spreadsheet fails to load, is there a timeout?
In my nextcloud installation which uses a standalone CODE instance (not the Nextcloud built-in) most spreadsheets open fine. However, on spreadsheet always fails to open. This spreadsheet is quite complex with many interlinked formulas. It opens fine in Libreoffice locally. Is it possible that there is some kind of timeout happening when I try to open it? If so, can I adjust this to make it bigger to see if this solves the issue?
Hi @crobar thanks for reporting this. Let’s try to gather some info:
  • What’s your CODE and Nextcloud version?
  • Could you please paste here what you see in your web browser console (F12 → Console)
  • Also could you upload that spreadsheet document? (so we can test it?)
Nextcloud 24.0.3
Nextcloud Office 6.2.0
CODE 22.05.5-2
CODE is installed on the same machine as the Nextcloud instance.
Console log from Chromium below. Generated by navigating to the folder containing the spreadsheet in the Files app, then clearing the console and clicking on the file.
Unfortunately I can’t share the spreadsheet publicly, I could maybe share privately.
VM427:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
    at JSON.parse (<anonymous>)
    at window._notify_push_ws.onmessage (index.js:136:45)
window._notify_push_ws.onmessage @ index.js:136
globals.js:62 $ is deprecated: The global jQuery is deprecated. It will be removed in a later versions without another warning. Please ship your own.
Tt @ globals.js:62
get @ globals.js:93
_onClickFile @ merged-index.js?v=a212353c-50:4936
ge @ _executeBound.js:8
(anonymous) @ bind.js:10
(anonymous) @ restArguments.js:16
dispatch @ jquery.js:5430
f.handle @ jquery.js:5234
Tt @ globals.js:62
get @ globals.js:93
_onClickFile @ merged-index.js?v=a212353c-50:4947
Tt @ globals.js:62
get @ globals.js:93
Tt @ globals.js:62
get @ globals.js:93
getActions @ merged-index.js?v=a212353c-50:3108
getDefaultFileAction @ merged-index.js?v=a212353c-50:3204
getCurrentDefaultFileAction @ merged-index.js?v=a212353c-50:3176
_onClickFile @ merged-index.js?v=a212353c-50:4954
Tt @ globals.js:62
get @ globals.js:93
getActions @ merged-index.js?v=a212353c-50:3112
Tt @ globals.js:62
get @ globals.js:93
getActions @ merged-index.js?v=a212353c-50:3121
Tt @ globals.js:62
get @ globals.js:93
getActions @ merged-index.js?v=a212353c-50:3127
Tt @ globals.js:62
get @ globals.js:93
_notifyUpdateListeners @ merged-index.js?v=a212353c-50:2967
action @ merged-index.js?v=a212353c-50:3020
_onClickFile @ merged-index.js?v=a212353c-50:4957
Tt @ globals.js:62
get @ globals.js:93
elementToFile @ merged-index.js?v=a212353c-50:5411
fileList.elementToFile @ merged-index.js?v=a212353c-50:12420
e.elementToFile @ share.js:115
e.elementToFile @ filesplugin.js:129
getModelForFile @ merged-index.js?v=a212353c-50:4657
Ca @ FilesActionHandler.js:35
action @ merged-index.js?v=a212353c-50:3023
Tt @ globals.js:62
get @ globals.js:93
action @ merged-index.js?v=a212353c-50:3026
Tt @ globals.js:62
get @ globals.js:93
_onClickFile @ merged-index.js?v=a212353c-50:4965
ConsoleLogger.js:33 [INFO] viewer: Opening viewer for file  {app: 'viewer', uid: 'rcrozier', path: '/REOS-SHARED/Financial/Management Accounts and Projections/Projections Master Template v2.xlsx'}
[Violation] Forced reflow while executing JavaScript took 48ms
ConsoleLogger.js:29 [DEBUG] viewer: Fetching additional files... {app: 'viewer', uid: 'rcrozier'}
Tt @ globals.js:62
get @ globals.js:93
(anonymous) @ Office.vue:178
u @ runtime.js:63
(anonymous) @ runtime.js:294
(anonymous) @ runtime.js:119
z @ collabora.js:48
i @ collabora.js:48
Promise.then (async)
z @ collabora.js:48
i @ collabora.js:48
z @ collabora.js:48
i @ collabora.js:48
(anonymous) @ collabora.js:48
mounted @ Office.vue:162
We @ vue.runtime.esm.js:1863
un @ vue.runtime.esm.js:4235
insert @ vue.runtime.esm.js:3158
_ @ vue.runtime.esm.js:6390
bo.nodeOps @ vue.runtime.esm.js:6609
e._update @ vue.runtime.esm.js:3963
r @ vue.runtime.esm.js:4081
bn.get @ vue.runtime.esm.js:4495
bn.run @ vue.runtime.esm.js:4570
An @ vue.runtime.esm.js:4326
(anonymous) @ vue.runtime.esm.js:1989
et @ vue.runtime.esm.js:1915
Ke @ vue.runtime.esm.js:1942
it @ vue.runtime.esm.js:1999
(anonymous) @ vue.runtime.esm.js:4418
bn.update @ vue.runtime.esm.js:4560
de.notify @ vue.runtime.esm.js:730
set @ vue.runtime.esm.js:1055
Cn.set @ vue.runtime.esm.js:4644
(anonymous) @ Viewer.vue:386
u @ runtime.js:63
Ka @ Download.vue?b226:19
(anonymous) @ Download.vue?b226:19
openFile @ Viewer.vue:344
file @ Viewer.vue:256
bn.run @ vue.runtime.esm.js:4584
value @ Viewer.js:183
Ca @ FilesActionHandler.js:40
capabilities.js:35 OC.getCapabilities is deprecated and will be removed in Nextcloud 21. See @nextcloud/capabilities
getCapabilities @ capabilities.js:35
(anonymous) @ Office.vue:201
u @ runtime.js:63
z @ collabora.js:48
i @ collabora.js:48
load @ Office.vue:190
(anonymous) @ Office.vue:184
u @ runtime.js:63
z @ collabora.js:48
i @ collabora.js:48
z @ collabora.js:48
i @ collabora.js:48
z @ collabora.js:48
i @ collabora.js:48
u @ runtime.js:63
index.js:46 No OC found
getLanguage @ index.js:46
value @ gettext.js:45
26932 @ l10n.js:3
a @ bootstrap:19
13084 @ legacy-loader.js:30
a @ bootstrap:19
(anonymous) @ startup:4
a.O @ chunk loaded:25
(anonymous) @ startup:5
index.es.js:2337 Proxying an event bus of version 2.1.1 with 1.3.0
t @ index.es.js:2337
70903 @ index.es.js:3314
a @ bootstrap:19
71894 @ requesttoken.js:11
a @ bootstrap:19
22200 @ index.js:25
a @ bootstrap:19
13084 @ index.js:323
a @ bootstrap:19
jquery-migrate.min.js:2 JQMIGRATE: Migrate is installed, version 3.4.0
n @ bootstrap:19
n @ bootstrap:19
22200 @ index.js:25
n @ bootstrap:19
(anonymous) @ make namespace object:6
(anonymous) @ document.js:628
Tt @ globals.js:62
get @ globals.js:93
(anonymous) @ document.js:87
Tt @ globals.js:62
get @ globals.js:93
(anonymous) @ document.js:603
script?v=1:133 Uncaught TypeError: Cannot read properties of null (reading 'parentNode')
    at script?v=1:133:23
    at script?v=1:136:7
(anonymous) @ script?v=1:133
(anonymous) @ script?v=1:136
session-heartbeat.js:103 session heartbeat polling started
postMessage.tsx:57 PostMessageService.sendPostMessage parent loading
Tt @ globals.js:62
get @ globals.js:93
initSession @ document.js:521
(anonymous) @ document.js:619
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
(anonymous) @ jquery.js:3872
l @ jquery.js:3500
fireWith @ jquery.js:3630
fire @ jquery.js:3638
l @ jquery.js:3500
ready @ jquery.js:4110
setTimeout (async)
(anonymous) @ jquery.js:4131
(anonymous) @ jquery.js:28
19755 @ jquery.js:14
a @ bootstrap:19
13084 @ windows-phone.js:30
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
initSession @ document.js:523
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
document.js:220 Waiting for page to render…
Tt @ globals.js:62
get @ globals.js:93
onStartup @ document.js:503
(anonymous) @ document.js:626
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
showEditor @ document.js:230
(anonymous) @ document.js:219
setTimeout (async)
showEditor @ document.js:219
loadDocument @ document.js:531
(anonymous) @ document.js:526
l @ jquery.js:3500
add @ jquery.js:3559
initSession @ document.js:525
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
showEditor @ document.js:232
setTimeout (async)
l @ jquery.js:3500
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
url.js:39 [getWopiUrl] https://nextcloud.reoptimizesystems.com/index.php/apps/richdocuments/wopi/files/635217_ocgcv9nemegb
Tt @ globals.js:62
get @ globals.js:93
showEditor @ document.js:251
setTimeout (async)
l @ jquery.js:3500
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
setTimeout (async)
l @ jquery.js:3500
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
showEditor @ document.js:254
setTimeout (async)
l @ jquery.js:3500
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
showEditor @ document.js:258
setTimeout (async)
l @ jquery.js:3500
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
Tt @ globals.js:62
get @ globals.js:93
showEditor @ document.js:333
setTimeout (async)
l @ jquery.js:3500
c @ jquery.js:3766
u @ jquery.js:3834
setTimeout (async)
l @ jquery.js:3500
l @ jquery.js:3500
setTimeout (async)
a @ bootstrap:19
a @ bootstrap:19
script?v=1:70 Uncaught TypeError: Cannot read properties of null (reading 'addEventListener')
    at HTMLBodyElement.<anonymous> (script?v=1:70:26)
    at T (sideMenu.js?v=a212353c-50:24:259)
(anonymous) @ script?v=1:70
T @ sideMenu.js?v=a212353c-50:24
setTimeout (async)
setTimeout (async)
328 @ sideMenu.js?v=a212353c-50:24
n @ sideMenu.js?v=a212353c-50:1
(anonymous) @ sideMenu.js?v=a212353c-50:1
VM454:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
10[Violation] Added non-passive event listener to a scroll-blocking <some> event. Consider marking event handler as 'passive' to make the page more responsive. See <URL>
bundle.js:1 Blocked autofocusing on a <textarea> element in a cross-origin subframe.
onAdd @ bundle.js:1
_layerAdd @ bundle.js:1
whenReady @ bundle.js:1
addLayer @ bundle.js:1
initialize @ bundle.js:1
NewClass @ bundle.js:1
L.map @ bundle.js:1
(anonymous) @ bundle.js:1
[Violation] Forced reflow while executing JavaScript took 43ms
postMessage.tsx:57 PostMessageService.sendPostMessage loolframe {"MessageId":"Host_PostmessageReady","SendTime":1660205091902,"Values":{}}
VM465:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
[Violation] Forced reflow while executing JavaScript took 37ms
VM467:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM469:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM471:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM473:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM475:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM477:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM479:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
2bundle.js:1 missing popover data
closePopover @ bundle.js:1
setTimeout (async)
onJSDialog @ bundle.js:1
fire @ bundle.js:1
_onJSDialog @ bundle.js:1
_onMessage @ bundle.js:1
showSnackbar @ bundle.js:1
_onSocketClose @ bundle.js:1
VM481:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM483:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
Office.vue:198 FAILED
(anonymous) @ Office.vue:198
setTimeout (async)
(anonymous) @ Office.vue:197
u @ runtime.js:63
z @ collabora.js:48
i @ collabora.js:48
u @ runtime.js:63
z @ collabora.js:48
i @ collabora.js:48
z @ collabora.js:48
i @ collabora.js:48
z @ collabora.js:48
i @ collabora.js:48
u @ runtime.js:63
VM485:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM487:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM489:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM491:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM493:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM495:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM497:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM499:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM501:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM503:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
core-main.js?v=a212353c-50:2 [Violation] 'setInterval' handler took 50ms
VM505:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM507:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM509:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM511:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM513:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM515:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM517:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
VM519:1 Uncaught SyntaxError: Unexpected token w in JSON at position 0
There was more but post length is limited to 32000 characters and I assume the FAILED office error is the interesting one.
Screenshot
Yes, there is a setting in /etc/coolwsd/coolwsd.xml, <per_document> / <limit_load_secs>, which is 100 by default. You could disable the limit by changing it to 0, and see if the file can be opened then.
@bearon thanks, I tried that, and it didn’t help.
However, I did some more investigation and the plot has thickened. If I move the spreadsheet to another folder it opens fine! I discovered this by first noticing that none of the spreadsheets in the particular folder appear to be opening in CODE. If I move them elsewhere they open, if I move them back they stop opening!
I definitely have all the required permissions to edit this folder etc. The folder is a subfolder of a group folder (but I doubt it’s relevant). Spreadsheets also seem to fail to open in subfolders of this folder. The folder tree looks like this:
I then tried to create a spreadsheet in this folder by going to ±>New Spreadsheet in nextcloud that also fails. I tried to create a spreadsheet called test_CODE_opening_issue.ods. After the failure the file is present in the directory but cannot be opened in CODE. After syncing locally, it seemed I could open it in libreoffice, but I didn’t test extensively, and the libreoffice spinner kept spinning after i opened it, and I closed the file before it stopped, so I don’t know if there is any corruption.
Further to this spreadsheets in another path won’t load:
REOS-SHARED/Business Documentation/Board Meetings and Minutes/Board Meeting 2022-08-17
Is there an issue with path length? Or spaces in paths or something?
I created a github issue here
