How to enable AI features in code 26.04?
Hi
I use a dedicated code server for my nextcloud setup. Code run in a debian VM and is up to date.
However I don’t see the AI options, to enable them and choose provider like in the Desktop client.
I’ve added enable.ai in my coolwsd.xml file but it doesn’t change anything. What am I doing wrong to enable the embedded AI features of CODE 26.04? Not talking of Nextcloud assistant or anything external to Collabora.
Thanks!
Hi @hayvan96,
Welcome to the forum!
Based on your description, it looks like the AI functionality is currently disabled in your Collabora Online configuration.
In the 26.04 packages, you should find an <ai> section in /etc/coolwsd/coolwsd.xml under <config>. Make sure AI is enabled:
<ai>
    <enabled type="bool">true</enabled>
    <allow_user_settings type="bool">true</allow_user_settings>
    <api_url type="string"></api_url>
    <api_key type="string"></api_key>
    <model type="string"></model>
</ai>
After enabling it, there are two ways to configure the provider:
  • Per-user provider: Keep allow_user_settings set to true and leave api_url, api_key, and model empty. After restarting Collabora Online, users should be able to configure their own AI provider from the settings dialog.
  • Central provider: Configure api_url and model (and api_key if required). The endpoint needs to provide an OpenAI-compatible /v1/chat/completions API. This can be a provider such as Ollama, vLLM, LM Studio, OpenAI, etc. You can set allow_user_settings to false if you want to prevent users from changing the provider settings.
Once the configuration is changed, restart coolwsd.
Also, the AI sidebar will only appear when a provider is actually configured. In other words, all of these need to be true:
  • ai.enabled is set to true.
  • A base URL and model are configured, either by the user or centrally.
  • The user is logged in. AI is not available for anonymous users accessing a public share link.
  • The integration does not disable AI through CheckFileInfo.
For Nextcloud, there should be nothing additional required on the richdocuments side, as it does not send DisableAISettings.
Also, enable.ai is not a valid configuration key, so it will simply be ignored.
If you can share your current <ai> section from coolwsd.xml (with the API key removed), we can take a look at the configuration and see if anything is missing.
Thanks it worked, I had found these ai.enable instructions over the internet. I sometimes get a HTTP 404 answer when chatting (with Mistral), but it seems to work though
