How to insert vector images into collabora
Peek 2024-02-29 16-17
The .svg can be inserted from the outside and behaves correctly. It cannot be inserted from within Collabora Writer - which only displays .png. Why?
Hey @LeHarry, thanks for the question. :slight_smile:
Sounds like a great enhancement request:
  • Insert > Image should support SVG
Q1. Do you have a Github account?
If not, that’s okay. Just let me know and then I can submit one on your behalf.
Would also be helpful if you:
  • Share a sample SVG image + an ODT file with the SVG inside.
  • Give the exact Help > About info.
    • This will be your exact Collabora Online version info.
  • Give you Nextcloud version / richdocuments info too.
This will help making it easier for devs to test+debug+potentially add this feature. :slight_smile:
