dispatch.executeDispatch(frame, url, ‘’, 0, args) The returned result doesn’t seem to have any practical use. Don’t I need to add a listener or something similar to get the actual return result?
@gulixiang have you checked INCOMING response in console ?
In simple local setup we have see the INCOMING response of every Uno command dispatch in console like this =>
Also, can you give me more info about what is the scenario here ? What exact thing you want to achieve with the returned result ?
@darshan Thank you for your reply. I know that the console can be viewed, but that’s not what I want. I wrote a Python script that calls a UNO COMMAND, and I want to get the same return result in the Python script as I would see in the console.
@gulixiang oh sorry i totally misinterpret the problem. As i did some browsing, i found this com.sun.star.bridge.UnoUrlResolver, it may help you to get the response of a uno command.
For example ( Just a sudo code, I am not much familiar with python
import uno
def run_uno_command():
local_context = uno.getComponentContext()
resolver = local_context.ServiceManager.createInstanceWithContext(
"com.sun.star.bridge.UnoUrlResolver", local_context)
ctx = resolver.resolve("uno:socket,host=localhost,port=2002;urp;StarOffice.ComponentContext")
smgr = ctx.ServiceManager
desktop = smgr.createInstanceWithContext("com.sun.star.frame.Desktop", ctx)
document = desktop.getCurrentComponent()
dispatcher = smgr.createInstanceWithContext("com.sun.star.frame.DispatchHelper", ctx)
command = ".uno:WordCount"
args = ()
result = dispatcher.executeDispatch(document.getCurrentController(), command, "", 0, args)
return result
output = run_uno_command()
print(output)
This may not be an exact thing, but let me know if it helps ![]()
And also check here a java example given in this page: LibreOffice Developer's Guide: Chapter 2 - Professional UNO - The Document Foundation Wiki
Search for term: com.sun.star.bridge.UnoUrlResolver
@darshan Hi after testing, it still doesn’t work. The returned result is None.
Hrm, that resolve() would be for connecting to a remote soffice process from pyuno, I’m not sure that’s relevant for the COOL python scripting, which is meant to be in-process.
I’m also not sure if .uno:WordCount is meant to return a value.
If it does, what you probably want is to dispatch with an XDispatchResultListener. See here for a C++ example:
I.e. if you want to get feedback on when the command the command is dispatched, you want dispatchWithNotification() and not dispatch(), I guess.
Hi @vmiklos Yes, this is what I want. The awkward thing is that I couldn’t find the relevant API on the Python side to implement it
