Hi everyone, I’m working on a document bookmarking feature where users can save references to specific content in embedded Collabora Online documents. The feature needs to work with PDF, DOCX, XLSX, and PPTX files in strict read-only mode. I have text search and highlighting working, but the viewport doesn’t automatically scroll to show the highlighted content.
Current working solution
Text search and highlighting works using postMessage
function findAndHighlightText(searchText) {
const iframe = document.getElementById('collabora-iframe');
iframe.contentWindow.postMessage({
MessageId: 'Action_Find',
Values: {
SearchItem: {
SearchString: { type: 'string', value: searchText },
Backward: { type: 'boolean', value: false },
FindAll: { type: 'boolean', value: false }
Current behavior: Text gets found and highlighted in yellow, but Collabora doesn’t scroll to show it
The problem
I have the coordinates where the text was originally located:
const originalCoordinates = { x: 1006, y: 1296 };
But I can’t get Collabora to scroll to those coordinates programmatically.
What I’ve tried (all failed)
PostMessage scroll commands - no API available
// These MessageId types don't seem to exist
MessageId: 'Action_ScrollTo', // Not valid
Values: { x: 1006, y: 1296 }
MessageId: 'UI_ScrollToPosition', // Not valid
UNO commands - limited positioning support
// These don't provide viewport control
MessageId: 'uno:.uno:GoToPage',
Values: { Page: 1 }
Workarounds that partially help
1. Document reload with search parameters
function reloadWithSearch(searchText) {
const url = new URL(iframe.src);
url.searchParams.set('search', searchText);
url.searchParams.set('highlight', 'true');
iframe.src = url.toString();
// Follow up with search command after reload
setTimeout(() => {
findAndHighlightText(searchText);
}, 3000);
This doesn’t actually work reliably - the reload approach was something I hoped would work but it doesn’t provide consistent viewport positioning. Collabora loads the document but doesn’t automatically scroll to highlighted search results.
2. Multiple search strategies
function enhancedSearch(searchText) {
// Try regular find
// Try find with replace dialog (sometimes scrolls better)
setTimeout(() => {
MessageId: 'Action_FindReplace',
Values: {
SearchItem: {
}, 500);
Questions
Is there a postMessage command for viewport scrolling that I’m missing from the documentation?
Are there URL parameters that control initial scroll position when loading a document?
Can I simulate keyboard shortcuts like Ctrl+F to open Collabora’s native find dialog?
Is this a known limitation with any planned fixes or workarounds?
Environment details
Collabora CODE
iframe embedding with postMessage API
WOPI host for document serving
Strict read-only document mode (no modifications allowed)
Target formats: PDF, DOCX, XLSX, PPTX
Has anyone solved this viewport positioning challenge with embedded Collabora?
