Nextcloud/Collabora/Docker not working without IPv4 Address?
Hi, i have the Nextcloud /Colabora Docker setup. Recently I moved my installation to a Proxmox VM which has only IPv6 (because IPv4 is depreciated).
I have my COCS docker container up and running and it can be accessed from my next cloud instance as before.
But now I see the following error and within next cloud I get the error page could not be loaded:
ERR  Failed to connect to XXX (EADDRNOTAVAIL: Cannot assign requested address)| net/NetUtil.cpp:128
Can you confirm, that the docker variant only works with an IPv4 DNS entry?
Ok found out that its needed to enable IPv6 support than it works like a charm
Welcome @solick to the forum :wave:
Network settings
Collabora Online can use IPv4, IPv6 or both. By default it uses both. See the net.proto setting config file.
More info
