Problem moving from 21.11.2.4 to 21.11.3.3.1
Everthing works fine with 21.11.2.4, but if I try to use 21.11.3.3.1 I get the following errors.
I first get a pop up statying that Collabora cannot open my file, then it gets stuck on this window:
I’m only updating the docker image and I’m not changing anything else.
I looked at the SDK documentation and I didn’t notice anything different regarding the reverse proxy settings [Apache].
Any suggestions?
Same thing for me, using Nextcloud 23 with Nginx
The 21.11.3.3.1 container seems to boot up, and I can get in to the admin panel. It seems from that panel I can see Nextcloud can’t make the connection to the document server anymore.
Going back to container 21.11.2.4 resolved the issue.
Is there another change that needs to be made to the reverse proxy server?
Same here, on Nextcloud 22, the new Collabora on docker either hangs on ‘connecting… 0%’, or says "can’t connect to document’.
Reverting to 21.11.2.4 makes it work again.
21.11.3.4.1 fixed this issue for me.
I can confirm 21.11.3.4.1 works fine for me as well…
Yup fixed it for me as well
