I’m trying to setup the test Collabora+NextCloud deployment as described here, using the freshly released 6.4.14.2 doker image. I launched the CODE and NextCloud containers exactly as prescribed, set up the Collabora Online server in Nextcloud by using my machine IP on local network (192.168.1.122), and then created an ODS document in NextCloud. The result is that the document cannot be opened in CODE, with various error messages ranging from “Cleaning up the document from the last session” to the infamous “Well, this is embarassing” and finally “The server has been disconnected”. The CODE logs say:
wsd-00001-00165 2021-11-05 15:32:53.687934 [ docbroker_011 ] WRN Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:682
wsd-00001-00165 2021-11-05 15:32:53.688008 [ docbroker_011 ] ERR #30: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00165 2021-11-05 15:32:53.688032 [ docbroker_011 ] ERR #30: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00165 2021-11-05 15:32:53.688061 [ docbroker_011 ] ERR WOPI::CheckFileInfo failed for URI [http://localhost/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt?access_token=MCGqgNd7Xz0XAMWDluAoYQz8uXCEef0z&access_token_ttl=0]: 0 . Headers: Body: []| wsd/Storage.cpp:715
wsd-00001-00165 2021-11-05 15:32:53.688126 [ docbroker_011 ] ERR loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1926
wsd-00001-00165 2021-11-05 15:32:53.688146 [ docbroker_011 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt] with URI [http://localhost/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt?access_token=MCGqgNd7Xz0XAMWDluAoYQz8uXCEef0z&access_token_ttl=0]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1888
wsd-00001-00165 2021-11-05 15:32:53.688165 [ docbroker_011 ] ERR Storage error while starting session on /index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt for socket #22. Terminating connection. Error: WOPI::CheckFileInfo failed: | wsd/LOOLWSD.cpp:3612
wsd-00001-00165 2021-11-05 15:32:53.688269 [ docbroker_011 ] WRN Ignoring attempted read from 22| ./net/Socket.hpp:1021
wsd-00001-00165 2021-11-05 15:32:53.688278 [ docbroker_011 ] ERR Invalid or unknown session [025] to remove.| wsd/DocumentBroker.cpp:1969
wsd-00001-00035 2021-11-05 15:32:54.088134 [ websrv_poll ] WRN DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2161
wsd-00001-00035 2021-11-05 15:32:54.088300 [ websrv_poll ] ERR Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt].| wsd/LOOLWSD.cpp:3641
wsd-00001-00035 2021-11-05 15:32:54.088342 [ websrv_poll ] ERR #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00035 2021-11-05 15:32:54.088376 [ websrv_poll ] ERR #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00035 2021-11-05 15:32:54.088393 [ websrv_poll ] WRN Socket #29 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:765
wsd-00001-00035 2021-11-05 15:32:54.088417 [ websrv_poll ] ERR #29: attempted to remove: 756 which is > size: 0 clamped to 0| ./net/Socket.hpp:1120
wsd-00001-00035 2021-11-05 15:32:54.088445 [ websrv_poll ] WRN Ignoring attempted read from 29| ./net/Socket.hpp:1021
wsd-00001-00035 2021-11-05 15:32:54.088465 [ websrv_poll ] ERR #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00035 2021-11-05 15:32:54.500462 [ websrv_poll ] WRN DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt] that is marked to be destroyed. Rejecting client request.| wsd/LOOLWSD.cpp:2161
wsd-00001-00035 2021-11-05 15:32:54.500559 [ websrv_poll ] ERR Error while handling Client WS Request: Failed to create DocBroker with docKey [/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt].| wsd/LOOLWSD.cpp:3641
wsd-00001-00035 2021-11-05 15:32:54.500581 [ websrv_poll ] ERR #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00035 2021-11-05 15:32:54.500599 [ websrv_poll ] ERR #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00035 2021-11-05 15:32:54.500608 [ websrv_poll ] WRN Socket #29 is shutting down but 64 bytes couldn't be flushed and still remain in the output buffer.| ./net/WebSocketHandler.hpp:765
wsd-00001-00035 2021-11-05 15:32:54.500631 [ websrv_poll ] ERR #29: attempted to remove: 756 which is > size: 0 clamped to 0| ./net/Socket.hpp:1120
wsd-00001-00035 2021-11-05 15:32:54.500653 [ websrv_poll ] WRN Ignoring attempted read from 29| ./net/Socket.hpp:1021
wsd-00001-00035 2021-11-05 15:32:54.500669 [ websrv_poll ] ERR #29: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00030 2021-11-05 15:32:55.688567 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2248
wsd-00001-00167 2021-11-05 15:32:56.525504 [ docbroker_012 ] WRN Waking up dead poll thread [HttpSynReqPoll], started: false, finished: false| ./net/Socket.hpp:682
wsd-00001-00167 2021-11-05 15:32:56.525614 [ docbroker_012 ] ERR #30: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00167 2021-11-05 15:32:56.525655 [ docbroker_012 ] ERR #30: Socket write returned -1 (EPIPE: Broken pipe)| ./net/Socket.hpp:1284
wsd-00001-00167 2021-11-05 15:32:56.525713 [ docbroker_012 ] ERR WOPI::CheckFileInfo failed for URI [http://localhost/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt?access_token=MCGqgNd7Xz0XAMWDluAoYQz8uXCEef0z&access_token_ttl=0&permission=edit]: 0 . Headers: Body: []| wsd/Storage.cpp:715
wsd-00001-00167 2021-11-05 15:32:56.525883 [ docbroker_012 ] ERR loading document exception: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1926
wsd-00001-00167 2021-11-05 15:32:56.525948 [ docbroker_012 ] ERR Failed to add session to [/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt] with URI [http://localhost/index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt?access_token=MCGqgNd7Xz0XAMWDluAoYQz8uXCEef0z&access_token_ttl=0&permission=edit]: WOPI::CheckFileInfo failed: | wsd/DocumentBroker.cpp:1888
wsd-00001-00167 2021-11-05 15:32:56.526009 [ docbroker_012 ] ERR Storage error while starting session on /index.php/apps/richdocuments/wopi/files/135_oc0j1uhi7ezt for socket #21. Terminating connection. Error: WOPI::CheckFileInfo failed: | wsd/LOOLWSD.cpp:3612
wsd-00001-00167 2021-11-05 15:32:56.526258 [ docbroker_012 ] WRN Ignoring attempted read from 21| ./net/Socket.hpp:1021
wsd-00001-00167 2021-11-05 15:32:56.526296 [ docbroker_012 ] ERR Invalid or unknown session [028] to remove.| wsd/DocumentBroker.cpp:1969
wsd-00001-00030 2021-11-05 15:32:58.526729 [ prisoner_poll ] WRN Prisoner connection disconnected but without valid socket.| wsd/LOOLWSD.cpp:2248
I read tons of posts reporting similar problems, but none for the quick tryout setup. Since the procedure is extremely simple I believe I followed it correctly, but still it doesn’t work, so I’d say either my system is flawed or the quick tryout instructions are.
Any help/suggestion is greatly appreciated, thanks in advance.
